My wifi keeps losing connection...the blue light always blinks the proper slow blink, but it keeps not sending info to the internet. I will be able to use the portal and my iPhone for about a day to control my controller, then I will not be able to until I unplug the wifi unit and plug it back in. Then again I can control from my iPhone and the portal. After a day, same thing, no control but blue light still blinking slow .. Then I unplug the wifi unit and plug it back in and I get about a day of control until then again no control. . What is going on? Very frustrating
Have to keep re-booting wifi argh!!
Drew471
Re: Have to keep re-booting wifi argh!!
I had this same problem, then I set up a static ip address for it on my router. Haven't loss connection in over a month. (if you havent yet night as well port forward as well at the same time..
Sent from my SPH-L720 using Tapatalk
psyrob
Thanks Drew, but I have set up a static id already and have port forwarding and have confirmed the port is open...
