PDE File with a few extras
dedvalson
Post by dedvalson »
Hi,
Here is my current PDE File.
It has a few extras such as:
1. Reuse of the same PWM port to run moonlights at night and LEDs by day.
2. Automatic skimmer clean out.
3. Shutdown the skimmer if the water level is too high.
4. A "High Noon" phase for the white LEDs that turns them on extra hard in the middle of the day.
5. The top fans run periodically to clear out humidity from the enclosed hood.
6. Use of a single relay to run white and blue LEDs.
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
// Labels for the web banner
#include <avr/pgmspace.h>
prog_char id_label[] PROGMEM = "edvalson";
prog_char probe1_label[] PROGMEM = "Water";
prog_char probe2_label[] PROGMEM = "Lights";
prog_char probe3_label[] PROGMEM = "Room";
prog_char relay1_label[] PROGMEM = "ATO";
prog_char relay2_label[] PROGMEM = "LEDS";
prog_char relay3_label[] PROGMEM = "FANS";
prog_char relay4_label[] PROGMEM = "WAVES";
prog_char relay5_label[] PROGMEM = "SKIMMER";
prog_char relay6_label[] PROGMEM = "SKUPPER";
prog_char relay7_label[] PROGMEM = "HEATER";
prog_char relay8_label[] PROGMEM = "SUMP";
relay3_label, relay4_label, relay5_label, relay6_label, relay7_label, relay8_label,
#define ATO Port1
#define LEDS Port2
#define FANS Port3
#define WAVEMAKERS Port4
#define SKIMMER Port5
#define SKUPPER Port6
#define HEATER Port7
#define SUMP Port8
byte whitePwmSlope = 0;
byte bluePwmSlope = 0;
boolean runSkimmer = true;
#define START_HIGH_NOON 14
#define END_HIGH_NOON 17
   // Initialize and start the web banner timer
   ReefAngel.Timer[4].SetInterval(180); // set interval to 180 seconds
   ReefAngel.Timer[4].Start();
    ReefAngel.Relay.On(SUMP);
    ReefAngel.Relay.On(WAVEMAKERS);
    ReefAngel.OverheatShutoffPorts = B00000000;
    ReefAngel.FeedingModePorts = B00001000;
    ReefAngel.WaterChangePorts = B10011000;
    ReefAngel.StandardHeater(HEATER);
    // run the fans for 1 minute every half hour to keep the humidity out of the hood
    if (minute()%30 == 0)
      ReefAngel.Relay.On(FANS);
      ReefAngel.StandardFan(FANS);
    // figure out the light slopes
    bluePwmSlope  = PWMSlope(InternalMemory.StdLightsOnHour_read(),InternalMemory.StdLightsOnMinute_read(),InternalMemory.StdLightsOffHour_read(),InternalMemory.StdLightsOffMinute_read(),0,InternalMemory.LEDPWMActinic_read(),90, bluePwmSlope);
    // if we are in the high noon phase of the day, ramp the whites clear up to 100, ignoring the value in memory. I wish we had a 3rd value in memory
    if (hour() >= START_HIGH_NOON && hour() <= END_HIGH_NOON)
      whitePwmSlope = PWMSlope(START_HIGH_NOON, 0 , END_HIGH_NOON, 0 , InternalMemory.LEDPWMDaylight_read(), 100, 20, whitePwmSlope);
      whitePwmSlope = PWMSlope(InternalMemory.MHOnHour_read(),InternalMemory.MHOnMinute_read(),InternalMemory.MHOffHour_read(),InternalMemory.MHOffMinute_read(),0,InternalMemory.LEDPWMDaylight_read(),60, whitePwmSlope);
    // if either  PWM slopes are on, turn on the lights
    if (bluePwmSlope >= 5 || whitePwmSlope >= 10)
        ReefAngel.PWM.SetDaylight(whitePwmSlope);
        ReefAngel.PWM.SetActinic(bluePwmSlope);
        ReefAngel.Relay.On (LEDS);
    // otherwise if it is really night, turn on moonlights
    else if (whitePwmSlope < 5)
        ReefAngel.Relay.Off (LEDS);
    // but if it is just getting close to night turn off the daylight(moonlight) to avoid a brief flash of white light
        ReefAngel.PWM.SetDaylight(0);
    runSkimmer = true;
    // clean out the skimmer for one minute every 4 hours.
    if ((hour()%4)==0)
      if (minute()==0)
        ReefAngel.Relay.On(SKUPPER);
      else if (minute() == 1)
        runSkimmer = false;
        ReefAngel.Relay.Off(SKUPPER);
    // If the High ATO isn't active turn off the ATO and the Skimmer
    // this means the water level is too high.
    // This should only happen if things go wrong
    if (!ReefAngel.HighATO.IsActive())
      ReefAngel.Relay.Off(ATO);
      runSkimmer = false;
      ReefAngel.SingleATOLow (ATO);
    // update the skimmer with the runSkimmer value
    if (runSkimmer)
      // let things settle down before the skimmer turns on.
      ReefAngel.Relay.DelayedOn(SKIMMER, 5);
      ReefAngel.Relay.Off(SKIMMER);
    // write it all to the relays
    ReefAngel.Relay.Write();
   // Web Banner stuff
     ReefAngel.WebBanner();
cain
Re: PDE File with a few extras
Post by cain »
wuts the code for hi noon?
wolfador
Post by wolfador »
cain wrote:wuts the code for hi noon?
John
ReefAngel and ReefAngel-HD developer
If the RA iOS app has helped please consider a donation
cain
Post by cain »
so hi noon is from 2pm to 5pm?
3hrs?
ty.
dedvalson
Post by dedvalson »
Hi,
Yes, that is correct. My whites come on to full brightness for 3 hours than go back down to where I normally run them at 60%. Actually if you look at the code though, it doesn't quite exactly that. Starting at 1400 hours (2:00) it starts ramping from 60 to 100 over a 20 minute period of time. It then stays there till 16:40 (20 minutes before 5:00) where it starts ramping back down to 60 over a period of 20 minutes.
Don
