I/O expansion added to wizard.
Trevenator
I have the I/O expansion but have not been able to use it.
I don't know how to program.
Will it ever be added to the wizard?
Also when will more pump modes be added?
I have gone back to using my stock jebo controllers to use else mode.
The reef crest mode sucks in that the lowest I have ever seen is 80%
It would be nice if it varied the flow from 30% to 100%
Trevenator
Re: I/O expansion added to wizard.
Sorry I accidentally put this under the hardware requests. Can I to have it put down in the software requests area.
Else mode has been added and will be in the next release.
I agree we need conditional statements in the wizard, but I just find it hard to wrap my head around it because there are so many options of what you can do.
- Sacohen
Maybe put some basic conditional statements and then people with little or nor coding experience (like myself) can use that as a basis to get started.
For example I'm sure I can set up the basics of my automated water change system, buy I'm going to want to put some conditional statements like if WL is <5% don't do AWC or if NSW is in mixing mode don't run AWC.
Veeresh
I also suggest that we should able to use the IO expansion to cater for OUTPUT as well. I hope the wizard can include this request.
The OUTPUT can be used to set Alarm (buzzer) , LED alert and other third party devices.
Veeresh
Just my two cents worth
Veeresh
Trevenator
Yes The output to be used to set Alarm (buzzer) would help what I want to do.Veeresh wrote:I also suggest that we should able to use the IO expansion to cater for OUTPUT as well. I hope the wizard can include this request.
Veeresh
Float switch in Cal and alk container. Buzzer or email turns on when they get low.
Float switch in Skimmer cup. Turn off Skimmer and turn on buzzer and email if cup gets full.
For all those float switches i would recommend the multi water level sensor.,
Trevenator
Not sure. How do I find out?rimai wrote:What revision is your board?
Trevenator
Just ordered the Multi-Channel Water Level Expansion will use that to monitor the levels of my Cal - Alk - vinegar - vodka.
I already have the single Water Level Expansion on my ato.
Would still like a float switch on my skimmer cup and be able to shut it off and send a email when its full.
For your skimmer cup, use this:
ReefAngel.Relay.Set(Port1,ReefAngel.IO.GetChannel(0)); // Set port 1 according to I/O channel 0
Trevenator
It says reef angel plus main unit 2.1rimai wrote:Open the enclosure. It will be written in the pcb.
Trevenator
Yes, starting on 2.0 version, you can easily use any port as output too. You just need to code it so the module knows you are using as output.
You need to add this to the end of your code:
Then, in your code, you can set any channel on the I/O module like this:
void SetIOChannel(byte channel, byte value)
Wire.beginTransmission(I2CIO_PCF8574);
Wire.write(value<<channel);
Wire.endTransmission();
SetIOChannel(0,1); // Set channel 0 to on
Veeresh
Hi Roberto
My IO Expansion module rev is 2.2
I have added the following coding
in the setup I called the following codes
// init IO port 1 to 3
// Testing phase
SetIOChannel(1,1); // Set channel 1 to on
SetIOChannel(2,1); // Set channel 2 to on
SetIOChannel(3,0); // Set channel 3 to off
SetIOChannel(4,0); // Set channel 4 to off
SetIOChannel(5,0); // Set channel 5 to off
and in the loop
if (hour()>=0 && hour()< 17 )
unsigned long currentMillis = millis();
if ( currentMillis - previousMillis >= intervaltimer )
if (FanOffStatus == false)
FanOffStatus = true; // variable set to off the fan
previousMillis = currentMillis;
intervaltimer = 30000 ;
SetIOChannel(4,1); // Set channel 4 to on
SetIOChannel(5,0); // Set channel 5 to on
FanOffStatus = false; // variable set to on the fan
previousMillis = currentMillis ;
intervaltimer = 5000 ;
SetIOChannel(4,0); // Set channel 4 to on
SetIOChannel(5,1); // Set channel 5 to on
ReefAngel.Relay.Off( Port3 );
ReefAngel.Relay.On( Port3 );
I'm just wanted to test the IO module to in port 4 and 5 to toggle between ON and OFF stage. and I noticed that all my port are at +5V including port 4 an 5. There is no toggling in voltage in port and 4 and 5. Looks like the RA is not IO module is set to OUTPOT module. Please advise
// Testing phase
and in the loop
I'll have to check when I get to the office.
Sent from my SM-G900P using Tapatalk
I'm not so sure why it is not working for you.
This is what I tested:
Channel 0 goes high and low every second.
if (millis()%2000<1000)
SetIOChannel(0,1);
SetIOChannel(0,0);
