Another LDD Question
PostPosted: Mon May 12, 2014 2:04 pm
SO I have a 48v power supply for my LLD Drivers. I was thinking of getting a 350 ma LDD Driver for 4 of my LEDs. I Don't remember but can I use the 48 V power supply or do I need a ~12V power supply? I am trying to jog my brain if the LDD Constant Current Drivers will limit things in the proper way as not to fry my 4 moon light LEDs.
PostPosted: Mon May 12, 2014 7:54 pm
Roberto explained to me that constant current drivers will only supply the necessary forward voltage. So you should be able to use the 48v supply.
PostPosted: Wed May 14, 2014 8:28 am
The LDD's are great at regulating forward voltage. You can even put 1 LED on it and it's OK. Check out the very last graph on the datasheet linked below, and you'll see that it's 87% efficient with 4 LEDs and 48V at 350mA.
350mA * 12V of LEDs = 4.2Watts so you'll get around 0.5W of heat on the LDD with a 87% efficiency.
http://www.meanwell.com/search/LDD-H/LDD-H-spec.pdf
Return to Ask anything here
