Dimming expansion q
pandimus
Dimming expansion q
Post by pandimus »
How do I make channels of my dimming expansion act like actinic, instead of daylights?
Re: Dimming expansion q
There is nothing that says daylight or actinic on the dimming expansion. You connect and use each channel at will.
pandimus
Post by pandimus »
For time, they currently turn on with daylights
You can choose which time each channel is supposed to turn on.
Or are you using internal memory?
pandimus
Post by pandimus »
Internal
You can add an offset after the value you are using.
ReefAngel.PWM.Channel0PWMSlope(30); // Starts 30 minutes earlier and ends 30 minutes later
pandimus
Post by pandimus »
thanks roberto
