The below is for a now broken down tank:
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port8Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.CustomLabels[0]="ATO Pump";
ReefAngel.CustomLabels[1]="Skimmer";
ReefAngel.CustomLabels[2]="LEDWhite";
ReefAngel.CustomLabels[3]="LEDBlue";
ReefAngel.CustomLabels[4]="WP25";
ReefAngel.CustomLabels[5]="DoserAlk";
ReefAngel.CustomLabels[6]="Unused";
ReefAngel.CustomLabels[7]="Heater";
ReefAngel.DayLights( Port3 );
ReefAngel.ActinicLights( Port4 );
ReefAngel.Relay.DelayedOn( Port5 );
ReefAngel.DosingPumpRepeat1( Port6 );
ReefAngel.StandardHeater( Port8 );
if (ReefAngel.DCPump.Mode==Custom)
if ( (now()%SECS_PER_DAY >= 77400) || (now()%SECS_PER_DAY<= 34200) )
ReefAngel.PWM.SetActinic(32); // Constant at 32% on sync mode
else if ( (now()%SECS_PER_DAY >= 34200) && (now()%SECS_PER_DAY<= 48600) )
ReefAngel.PWM.SetActinic(36); // Constant at 36% on sync mode
else if ( (now()%SECS_PER_DAY >= 48600) && (now()%SECS_PER_DAY<= 77400) )
ReefAngel.PWM.SetActinic( ElseMode(41,8,true)); // Else on sync mode, 41 +/- 8%
////DoserAlk Schedule
if ((hour() > 10) && (hour() < 22)) { // Between 10am and 10pm we will disable Port 6
ReefAngel.Relay.Off(Port6);
////Water change delay for Port 1
static time_t wcTimer;
if (ReefAngel.DisplayedMenu == WATERCHANGE_MODE) wcTimer=now();
if (now()-wcTimer > 0 && now()-wcTimer < 600) {
ReefAngel.Relay.Off(Port1);
else {ReefAngel.SingleATOLow (Port1 );
ReefAngel.Portal( "howaboutme" );
static unsigned long LastChange=millis(); // Set the inital time that the last change occurred
static int Delay = random( 500, 3000); // Set the initial delay
static int NewSpeed = MidPoint; // Set the initial speed
static int AntiSpeed = MidPoint; // Set the initial anti sync speed
if ((millis()-LastChange) > Delay) // Check if the delay has elapsed
Delay=random(500,5000); // If so, come up with a new delay
int ChangeUp = random(Offset); // Amount to go up or down
if (random(100)<50) // 50/50 chance of speed going up or going down
LastChange=millis(); // Reset the time of the last change
if (WaveSync)
return NewSpeed;
return AntiSpeed;
- Able to control pump settings via portal
- When in "custom mode": WP-25 is in else mode between 1:30pm and 9:30pm, constant mode at 32% between 9:30pm and 9:30am and 36% between 9:30am and 1:30pm.
- Doses Alk 12 times a day, once per hour between 10:00pm and 10:00am, controlled via portal
- Added ATO Low code to support my Avast ATO.
This one is for the current tank for record:
// Set to start at 9:45am and run for 10 minutes
#define AUTO_SAL_START_HOUR 9
#define AUTO_SAL_START_MINUTE 45
#define AUTO_SAL_RUN_TIME 10
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port5Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port8Bit;
// Salinity Temp Compensation
ReefAngel.Salinity.SetCompensation(0);
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.CustomLabels[2]="Light";
ReefAngel.CustomLabels[3]="Nero3";
ReefAngel.CustomLabels[4]="Return Pump";
ReefAngel.CustomLabels[5]="Unused";
ReefAngel.StandardLights( Port2 ); // putting skimmer on timer
// First 10 minutes after WC disable ATO for port 1
// Compute the current time
int CurrentTime = NumMins(hour(), minute());
// Compute the starting time for the auto salinity calibration
int AutoSalStartTime = NumMins(AUTO_SAL_START_HOUR, AUTO_SAL_START_MINUTE);
// Compute the ending time for the auto salinity calibration by adding in the run time
int AutoSalEndTime = AutoSalStartTime + AUTO_SAL_RUN_TIME;
// Check if it's time to start the auto salinity calibration
if ( AutoSalStartTime == CurrentTime ) {
// Switch to Salinity Calibration ONLY if we are on the main / default menu
// Don't switch to the calibration menu if we are doing something else (water change, feeding, etc)
if ( (ReefAngel.DisplayedMenu == DEFAULT_MENU) || (ReefAngel.DisplayedMenu == MAIN_MENU) ) {
ReefAngel.ChangeMode = SAL_CALIBRATE_MENU;
// Check if we are at the end of the Run Time for the auto salinity calibration
if ( AutoSalEndTime == CurrentTime ) {
// Simulate a button press ONLY if we are still on the Salinity Calibration menu screen
if (ReefAngel.DisplayedMenu == SAL_CALIBRATE_MENU) {
ButtonPress++;
- Water change pump delay
- Salinity temp compensation
- Put skimmer on timer by setting it to daylight and controlled via portal
- Auto calibrate salinity probe to compensate for having the skimmer on overnight
This one's for my new UNS 75s tank:
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port8Bit;
ReefAngel.CustomLabels[2]="MP10 Left";
ReefAngel.CustomLabels[3]="MP 10 Right";
ReefAngel.CustomLabels[5]="Doser Alk";
ReefAngel.CustomLabels[7]="Inkbird";
ReefAngel.Relay.DelayedOn(Port3 );
ReefAngel.Relay.DelayedOn(Port4 );
//DoserAlk Schedule
;if ((hour() > 10) && (hour() < 22)) { // Between 10am and 10pm we will disable Port 6
