no tool menu
liverock
no tool menu
Post by liverock »
ive been tryig to setup my reefangel installer on my mac book pro but everytime i check the audrino app there is no tool menu listed, so i can't open the wizard or do anyother funtions. i tried to reinstall numerous times and it shows the same screen. I can load it onto my old dell computor and it shows the tool menu, but i don't really use it anymore. any suggestions
Re: no tool menu
Can you post a screenshot?
liverock
Re: no tool menu
Post by liverock »
see attachmet sketch jun22 when downloaded on my other computer there is a tool menu on the 2nd line, on apple there is none. if this is how its supposed to be how do i get the wizard like on windows
Re: no tool menu
Not the code...
I'd like to see where you said there is no tool menu.
liverock
Re: no tool menu
Post by liverock »
i am notmaking a code. i took a picture of my windows screen you can see that a entire line is missinfg that has thefile edit sketch tools help icons that if you go into the tools you can accesss the wizard
Re: no tool menu
Well, the attachment above wasn't the screenshot, but I can see the screenshot this time.
The tools menu is right there in the screenshot though.
liverock
Re: no tool menu
Post by liverock »
that other pic was from my windows computer, see attached for screen shot off my mac book. you will see no tool bar, i am not trying to make a code that is the screen that apears when 1st entering audrino and i can't get the wizard or anything else.
Re: no tool menu
The menu on MacOSX is on the top of the screen and not on the window.
liverock
Re: no tool menu
Post by liverock »
don't i look stupid. but there is no wizrd in the tool menu. is it somewhere else ?
Re: no tool menu
If it is not there, it probably means you did not move the arduino folder in the disk image into your documents folder.
Please check the manual for more info about how to move the folders to the correct place.
liverock
Re: no tool menu
Post by liverock »
Thanks. i don't think i did that when i reinstalled it this morning. i'll redo it and hopefully that works. thanks again.
