PaulTurner911 Code
Re: PaulTurner911 Code
Just adding a link to Paul's most recent code, since there's about 15 pages of me and Steve troubleshooting his... lol
http://forum.reefangel.com/viewtopic.php?p=32040#p32040
Paulturner911
Post by Paulturner911 »
lnevo wrote:Just adding a link to Paul's most recent code, since there's about 15 pages of me and Steve troubleshooting his... lol
You SIR are a gentleman and a scholar!!! :)
Just paypal'd Roberto some money for a second jeabo adapter, pumps and harness should arrive soon, patience is a virtue.
Lee, Id like to be in the same boat as Scohen running them antisync and retaining current functionality.
Sorry to beat a dead horse, but could you please run down the duration and speed setup again?!? I think I remember duration in the portal does nothing, but speed has a variance that is defined somewhere hardcoded to make the pump run from 25%-75%. Just dont remember where to define this value and what it should be.
Thank you!!
Maybe Lee can add more to it, or explain it better, but this is what I have in my code of the speed variable.
ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),20,true );    // ElseMode on sync mode, Portal Speed Setting +/- 20%
Speed is Speed and Duration is Duration. You have nothing in your code that will make anything change versus what's set in the portal. No Variance that I can find. You only had one pump... so would not even mean anything to you initially...
I sent you how to activate the second pump in the anti-sync mode... You just need to define the channel and what it is going to be Sync/Anti-Sync.
Lee
Paulturner911
Got it.
You make it sound so simple.
And make me feel like an ass for asking.
There is something that we used to limit the pumps range of power, effectivly stopping the pump from running full power. For whatever reason I thought it had to do with speed and duration.
Paulturner911
lnevo wrote:Speed is Speed and Duration is Duration. You have nothing in your code that will make anything change versus what's set in the portal. No Variance that I can find. You only had one pump... so would not even mean anything to you initially...
Lee
// Change this to what you want your min/max based on vortech speed
// This is for those functions that take both, but only one memory slot.
int minOffset=25;
int maxOffset=25;
This is what I was thinking....isnt this where you would define the range of the pump (in relation to portal speed)?
PORTAL SPEED=60(currently) +/-25
Pump should run 35-85?
I must not have the correct understanding (not uncommon)
Trying to refresh my noodle.
We never did fix the problem.
I think you said you were going to fix it on the back end.
I can start a new thread for that issue if you want.
Lol what was the issue that you couldnt set the % on the 2nd pump differently?
Paulturner911
Badass! Got everything working, just need the pump!
I also added my skimmer to the feed mode and water change so it power cycles instead of running when its not needed. Added Long Pulse to the random...atleast it didnt give me an error, so I think I did :)
Thanks for the help!
I hadnt touched this stuff in ages, had to do the drivers and software install again since I replaced the HD on my PC. Kinda started to sweat for a min, but it all worked out :)
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.DayLights( Port1 ); // Return Pump
ReefAngel.StandardFan( Port2 ); // Canopy Fans
ReefAngel.ActinicLights( Port3 ); // Actinic LEDS
//Port4 Kalk/ATO
//Port5 Kalk Stir
ReefAngel.DayLights( Port6 );//Port 6 Skimmer
ReefAngel.DayLights( Port7 ); // MH 1
ReefAngel.DayLights( Port8 ); //MH 2
//Moonlight Phase 9pm-10am (CH4-CH5)
if ( (hour() >=10) && (hour() <21) )
ReefAngel.PWM.SetChannel( 4,(0) );
ReefAngel.PWM.SetChannel( 5,(0) );
//Over Flow Protection
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.Off(Port1);
//ATO Protection
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.Off(Port4);
//Kalk Dose 60sec @ 11pm-12pm (every 15min)
if (hour() >=23 || hour() < 12)
ReefAngel.Relay.Set(Port4, now()%900<60);
//Kalk Stir 12pm-1pm
if (hour() >=12 & hour() < 13)
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.Off(Port5);
///// Place your custom code below here
static int rmode;
byte modes[] = { ReefCrest, TidalSwell, ShortPulse, LongPulse, NutrientTransport };
changeMode=false;
static unsigned long feeding;
if (now()-feeding<900) {
  // First 15 minutes after feeding mode stops. Return Pump is off
  // First 15 minutes after feeding mode stops. Smart_NTM
} else if (now()-feeding<4500) { // 15 minutes plus 1 hour
  // Continue NTM for the next 60 minutes (75 minutes total)
} else if (now()%SECS_PER_DAY<30600 || now()%SECS_PER_DAY>=81000) { // 8:30am / 10:30pm
  // Night mode (go to 30%)
  ReefAngel.DCPump.Speed=30;
  ReefAngel.DCPump.Mode=modes[rmode];  // Put the mode to the random mode :)
} else {
Paulturner911
Right back at it of course...
Added else mode after hacking around with SaCohens code.
lnevo wrote:Lol what was the issue that you couldnt set the % on the 2nd pump differently?
That was one issue, but the one that didn't get resolved is that the portal shows every option available to the RA when it is in Else Mode.
I started a new thread so we don't fill up Paul's thread with this issue,
http://forum.reefangel.com/viewtopic.php?f=12&t=4696
Paulturner911
if (rmode==Else) {
    ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),25,true );    // ElseMode on sync mode, Portal Speed Setting +/- 20%
  } else {
Should this call "else" when "constant" is selected?
Its constant because we want the pump set at the speed that elsemode calculates. We could also put it in Custom mode here but then you would have to call the pwm commands directly.
Paulturner911
OK, I was trying to replicate his portal issue showing EVERYTHING, since I am running pretty much the same code.
Lee, If you get a min, please glance over my code and tell me if you see any issues in the stuff I cut and pasted from Sacohens code. Like I said, it uploaded :) Ive run feedmode and all seemed well.
Ill keep an eye out for else mode and wonky portal display. Is it only the day (in my case) that random calls ELSEMODE that the portal shows this?
Where is it?
Paulturner911
lnevo wrote:Where is it?
Sorry Lee, I must have neglected to attach it. Ill plug it in later this evening.
Everything seems ok, I just took my old code and added a few things I saw in Sacohens code that seemed like it was needed for Else mode.
Just kept clicking away and reading bits and pieces of threads.
Paulturner911
This is current:
//Port4 Kalk/ATO
//Port5 Kalk Stir
//ATO Protection
static int rmode;
// Add Else Mode definition..
const int Else=16;
byte modes[] = { Lagoon, Else, ReefCrest, TidalSwell, ShortPulse, LongPulse, NutrientTransport };
changeMode=false;
  if (rmode==Else) {
    ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),25,true );    // ElseMode on sync mode, Portal Speed Setting +/- 25%
  } else {
} else {
ReefAngel.Portal( "paulturner911" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
  static unsigned long LastChange=millis();        // Set the inital time that the last change occurred
  static int Delay = random( 500, 3000);           // Set the initial delay
  static int NewSpeed = MidPoint;                  // Set the initial speed
  static int AntiSpeed = MidPoint;                 // Set the initial anti sync speed
  if ((millis()-LastChange) > Delay)               // Check if the delay has elapsed
    Delay=random(500,5000);                        // If so, come up with a new delay
    int ChangeUp = random(Offset);                 // Amount to go up or down
    if (random(100)<50)                            // 50/50 chance of speed going up or going down
    LastChange=millis();                           // Reset the time of the last change
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
Change this line
  if (rmode==Else) {
to
  if (modes[rmode]==Else) {
Paulturner911
Paulturner911
Current code below. I am having an issue with the 2 DC pumps, sometimes the screen on the controller shows values but the pumps arent working. Its random, maybe an issue with else mode?
How can I activate else mode to see?
//Port4 Kalk/ATO
//Port5 Kalk Stir
//ATO Protection
static int rmode;
const int Else=16;
changeMode=false;
  } else {
} else {
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
Remove everything else from the list of options except else mode and then that will be the one that it chooses.
Paulturner911
I'm not sure how to.
No way to call it from a memory location manually?
Ok, I think I understand.
Change this...
To this...
byte modes[] = { Else };
Paulturner911
Could someone refresh my memory on how to have Relay 6 run constant, unless Im in feed mode?
I didnt realize it but when I added the skimmer it runs on the same schedule as my MH lamps. I would like it to be on all of the time unless its in feed mode.
Any help is greatly apprerciated.
Thank you
You need 2 things....
This in // Ports toggled in Feeding Mode
ReefAngel.FeedingModePorts = Port6Bit;
And then in // Ports that are always on
If you want to delay the start after feeding mode by 10 min so your main pump gets up to speed and your water leve gets back to normal you can add this in the loop section...
ReefAngel.Relay.DelayedOn( Port6,10 );
Paulturner911
Great! Thank you
Paulturner911
I HAVE PICKED UP A NEW TANK!!!
Im wondering if I should just run the wizard and start over, but cut and paste some "custom lines" ??? Please advise which would be easier.
Ditching a few things -
MH (port7&8)
FANS (port2)
ACTINIC (port3)
I have a few things that Id like to add-
3 Ecoray112DX whites/red (port7) Actinics (port8)
Chiller (port2) Should function similar to the fan settings? * NEEDS TO SHUT DOWN IN FEED/WATERCHANGE MODES
Skimmer (port3) ** Id like it off for 2 hours after feedmode activation
ANY AND ALL INPUT IS WELCOMED AND VERY APPRECIATED
I would keep what you have and go in and manually cut out what you don't want.
Then use the wizard to create the code you want to add and paste it in to your existing code.
Paulturner911
Ill give it a try!! thanks
