Can you please help with my 3 part dosing? I want to be able to adjust 3 part dose timing via the Portal but it doesn't seem to be working. I've read a few topics and re-wrote my code accordingly but it still doesn't seem to work. I've commented out some of the failsafes to check the base code but it still doesn't consistently turn on.
Basically I'd like:
- to have all 3 pump timing editable via Portal.
- have Calc and Alk/Mag run on alternating time cycles
- make sure all pumps are off (overridden) if PH goes above 8.55
Dosing Portion:
//Dosing
/* if ((hour() >= 8) && (hour() < 20)) { // Between 8am and 8pm we will disable Port 2
ReefAngel.Relay.Off((Alk_pump));
} else { // At night we'll disable Port1
ReefAngel.Relay.Off((Calc_pump));
ReefAngel.Relay.Off((Mag_pump));
ReefAngel.DosingPumpRepeat( Box1_Port1,0,InternalMemory.read(843),InternalMemory.read(812) );
ReefAngel.DosingPumpRepeat( Box1_Port3,5,InternalMemory.read(845),InternalMemory.read(813) );
ReefAngel.DosingPumpRepeat( Box1_Port5,10,InternalMemory.read(934),InternalMemory.read(933) );
if (ReefAngel.Params.PH>855)
ReefAngel.Relay.Off( (Calc_pump) );
ReefAngel.Relay.Off( (Alk_pump) );
ReefAngel.Relay.Off( (Mag_pump) );
*/Code: Select all
#include <SunLocation.h>
#include <Tide.h>
#include <Moon.h>
#include <WiFiAlert.h>
#include <avr/wdt.h>
// Custom menus
#include <avr/pgmspace.h>
prog_char menu1_label[] PROGMEM = "Refugium Light";
prog_char menu2_label[] PROGMEM = "Feeding Mode";
prog_char menu3_label[] PROGMEM = "Water Change";
prog_char menu4_label[] PROGMEM = "Vortech Mode";
prog_char menu5_label[] PROGMEM = "ATO Clear";
prog_char menu6_label[] PROGMEM = "Overheat Clear";
prog_char menu7_label[] PROGMEM = "PH Calibration";
prog_char menu8_label[] PROGMEM = "WLS Calibration";
prog_char menu9_label[] PROGMEM = "Date / Time";
menu4_label, menu5_label, menu6_label,
menu7_label, menu8_label, menu9_label
// Define Custom Memory Locations
#define Mem_B_MoonSlope 100
#define Mem_I_WCFillTime 106
#define Mem_I_Latitude 108
#define Mem_I_Longitude 110
#define Mem_B_TideMin 117
#define Mem_B_TideMax 118
#define Mem_B_PumpOffset 119
#define Mem_B_FeedingRF 120
#define Mem_B_NightRF 121
#define Mem_B_NightSpeed 122
#define Mem_B_NightDuration 123
#define Mem_B_NTMSpeed 124
#define Mem_B_NTMDuration 125
#define Mem_B_NTMDelay 126
#define Mem_B_NTMTime 127
#define Mem_I_CalDP1Vol 128
#define Mem_I_CalDP1Time 130
#define Mem_I_DP1Volume 132
#define Mem_I_CalDP2Vol 134
#define Mem_I_CalDP2Time 136
#define Mem_I_DP2Volume 138
#define Mem_B_TideMode 143
#define Mem_I_CalDP3Vol 154
#define Mem_I_CalDP3Time 156
#define Mem_I_DP3Volume 158
#define Mem_B_PrintDebug 198
#define Mem_B_ResetMemory 199
void init_memory() {
InternalMemory.write(Mem_B_MoonSlope,60);
InternalMemory.write_int(Mem_I_WCFillTime,240);
InternalMemory.write_int(Mem_I_Latitude,31);
InternalMemory.write_int(Mem_I_Longitude,-118);
InternalMemory.write(Mem_B_TideMin,10);
InternalMemory.write(Mem_B_TideMax,30);
InternalMemory.write(Mem_B_FeedingRF,true);
InternalMemory.write(Mem_B_NightRF,false);
InternalMemory.write(Mem_B_NightSpeed,30);
InternalMemory.write(Mem_B_NightDuration,10);
InternalMemory.write(Mem_B_NTMSpeed,65);
InternalMemory.write(Mem_B_NTMDuration,5);
InternalMemory.write(Mem_B_NTMDelay,15);
InternalMemory.write(Mem_B_NTMTime,150);
InternalMemory.write_int(Mem_I_CalDP1Vol,11);
InternalMemory.write_int(Mem_I_CalDP1Time,600);
InternalMemory.write_int(Mem_I_DP1Volume,30);
InternalMemory.write_int(Mem_I_CalDP2Vol,11);
InternalMemory.write_int(Mem_I_CalDP2Time,600);
InternalMemory.write_int(Mem_I_DP2Volume,30);
InternalMemory.write_int(Mem_I_CalDP3Vol,3);
InternalMemory.write_int(Mem_I_CalDP3Time,270);
InternalMemory.write_int(Mem_I_DP3Volume,0);
InternalMemory.write(Mem_B_TideMode,0);
InternalMemory.write(Mem_B_ResetMemory,false);
#define NUMBERS_8x16
// Define Portal Variables
#define Var_Feedings 0
#define Var_DPump1 1
#define Var_DPump2 2
#define Var_AcclDay 3
#define Var_Tide 4
#define Var_TideMode 5
#define Var_LogATO 6
#define Var_WCVol 7
// Define Relay Ports by Name
#define UV_Filter 1
#define ATOSump 2
#define Chiller 3
#define Heater 4
#define Skimmer 5
#define SumpCirc 6
#define ReturnPump 7
#define WaveRight 8
#define Calc_pump Box1_Port1
#define Vortech1 Box1_Port2
#define Alk_pump Box1_Port3
#define Dosing_pump Box1_Port4
#define Mag_pump Box1_Port5
#define WaveLeft Box1_Port6
#define Feeder Box1_Port7
#define ATOres Box1_Port8
#define VO_Cleaning Box2_Port1
#define VO_EnableATO Box2_Port2
#define VO_StartFill Box2_Port3
#define VO_Vacation Box2_Port4
#define VO_AutoFeed Box2_Port5
#define VO_Unused Box2_Port6
#define VO_Calibrate Box2_Port7
#define VO_LockPorts Box2_Port8
//boolean dosing=true;
byte vtechmode;
//boolean bFeeding=false;
// Custom classes
SunLocation sun;
Tide tide;
// Vortech Variables
byte vtMode, vtSpeed, vtDuration;
// Needs to be global for DrawCustomGraph()
int ScreenID=1;
// Setup on controller startup/reset
wdt_enable(WDTO_2S);
//ReefAngel.Timer[1].SetInterval(45);
//ReefAngel.Timer[2].SetInterval(2880);
ReefAngel.InitMenu(pgm_read_word(&(menu_items[0])),SIZE(menu_items)); // Initialize Menu
ReefAngel.FeedingModePorts = Port7Bit | Port5Bit ;
ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port2Bit;
ReefAngel.OverheatShutoffPorts = Port4Bit ;
//ReefAngel.TempProbe = T1_PROBE;
//ReefAngel.OverheatProbe = T1_PROBE;
// Ports that default on
ReefAngel.Relay.On(ReturnPump);
ReefAngel.Relay.On(ATOSump);
ReefAngel.Relay.On(Vortech1);
ReefAngel.Relay.On(SumpCirc);
ReefAngel.Relay.On(Chiller);
randomSeed(now()/SECS_PER_DAY);
if (InternalMemory.read(Mem_B_ResetMemory))
init_memory();
ReefAngel.StandardLights( (WaveRight),6,0,11,30 );
ReefAngel.Relay.DelayedOn( (Skimmer),10 );
ReefAngel.StandardLights( (Skimmer),1,00,22,30 );
ReefAngel.StandardLights( (WaveLeft),11,30,17,30 );
ReefAngel.RF.UseMemory=false;
//Dosing
SetMoon(); // Setup Moon rise/set lighting
SetTide(); // Set High/Low tide properties
SetRF(); // Set Vortech modes
//Temp Heater Overheat
if (ReefAngel.Params.Temp[T1_PROBE]>780) ReefAngel.Relay.Off(Heater);
if (ReefAngel.Params.Temp[T1_PROBE]<760) ReefAngel.Relay.On(Heater);
//Temp2 Heater Overheat
//if (ReefAngel.Params.Temp[T2_PROBE]>780) ReefAngel.Relay.Off(QTH);
//if (ReefAngel.Params.Temp[T2_PROBE]<760) ReefAngel.Relay.On(QTH);
//ATO Res
ReefAngel.WaterLevelATO( Box1_Port8,1800,10,80 );
//Skimmer failsafe
if (ReefAngel.Relay.Status((ReturnPump)) != 1)
ReefAngel.Relay.Off((Skimmer));
// Manual Cleaning mode
if (ReefAngel.Relay.Status((VO_Cleaning)) == 1)
ReefAngel.Relay.On(Port8);
ReefAngel.Relay.On(Box1_Port6);
vtMode = 4; //LongPulse ShortPulse=3
ReefAngel.Portal( "" , "");
void SetMoon() {
// rfi
byte offset=InternalMemory.read(Mem_B_MoonSlope);
byte startD=InternalMemory.read(Mem_B_PWMSlopeStartD);
byte endD=InternalMemory.read(Mem_B_PWMSlopeEndD);
byte timeD=InternalMemory.read(Mem_B_PWMSlopeDurationD);
byte startA=InternalMemory.read(Mem_B_PWMSlopeStartA);
byte endA=InternalMemory.read(Mem_B_PWMSlopeEndA);
byte timeA=InternalMemory.read(Mem_B_PWMSlopeDurationA);
static byte mp=MoonPhase();
if (mp!=MoonPhase()) {
InternalMemory.write(Mem_B_PWMSlopeEndD,mp);
InternalMemory.write(Mem_B_PWMSlopeEndA,mp);
mp=MoonPhase();
moon_init(InternalMemory.read_int(Mem_I_Latitude), InternalMemory.read_int(Mem_I_Longitude));
ReefAngel.PWM.SetDaylight(PWMSlope(Moon.riseH,Moon.riseM,Moon.setH,Moon.setM, startD,endD,timeD,0));
ReefAngel.PWM.SetActinic(PWMSlope(Moon.riseH,Moon.riseM,Moon.setH,Moon.setM, startA,endA,timeA,0));
void SetTide() {
// rfi
byte nightSpeed=InternalMemory.read(Mem_B_NightSpeed);
byte tideMin=InternalMemory.read(Mem_B_TideMin);
byte tideMax=InternalMemory.read(Mem_B_TideMax);
// Set tide offsets
tide.SetOffset(tideMin, tideMax);
// Set tide speed. Slope in/out of Night Mode
tide.SetSpeed(PWMSlope(sun.GetRiseHour()-1,sun.GetRiseMinute(),
sun.GetSetHour(),sun.GetSetMinute(),nightSpeed+tideMin,vtSpeed,120,nightSpeed+tideMin));
// Show tide info on portal
ReefAngel.CustomVar[Var_Tide]=tide.CalcTide();
void SetRF() {
int ntmDelay=InternalMemory.read(Mem_B_NTMDelay)*60;
int ntmTime=InternalMemory.read(Mem_B_NTMTime)*60;
boolean nightRF=InternalMemory.read(Mem_B_NightRF);
boolean feedingRF=InternalMemory.read(Mem_B_FeedingRF);
static time_t t;
vtMode=InternalMemory.RFMode_read();
vtSpeed=InternalMemory.RFSpeed_read();
vtDuration=InternalMemory.RFDuration_read();
if ((now()-t > ntmDelay && now()-t < ntmTime+ntmDelay) && feedingRF) {
// Post feeding mode
vtMode=Smart_NTM;
vtSpeed=InternalMemory.read(Mem_B_NTMSpeed);
vtDuration=InternalMemory.read(Mem_B_NTMDuration);
} else if (!sun.IsDaytime() && nightRF) {
vtMode=Night;
vtSpeed=InternalMemory.read(Mem_B_NightSpeed);
vtDuration=InternalMemory.read(Mem_B_NightDuration);
} else {
if (vtMode!=Night && ReefAngel.RF.Mode==Night)
ReefAngel.RF.SetMode(Night_Stop,0,0);
if (ReefAngel.DisplayedMenu==FEEDING_MODE) {
t=now(); // Run post feeding mode when this counter stops
} else if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE) {
ReefAngel.RF.SetMode(Constant,25,0);
} else {
if ((vtMode==Smart_NTM) || (vtMode==ShortPulse)) vtDuration=InternalMemory.read(Mem_B_NTMDuration);
(vtMode==Custom) ? RFCustom() : ReefAngel.RF.SetMode(vtMode,vtSpeed,vtDuration);
void RFCustom() {
static boolean changeMode;
byte rcSpeed, rcSpeedAS;
// Define new modes
const int BHazard=15;
const int Else=16;
const int Sine=17;
byte tideSpeed=tide.CalcTide();
byte tideMode=InternalMemory.read(Mem_B_TideMode);
float pumpOffset=(float) InternalMemory.read(Mem_B_PumpOffset)/100;
byte RandomModes[]={ ReefCrest, TidalSwell, Smart_NTM, Lagoon, ShortPulse, LongPulse, BHazard, Else, Sine };
if (now()%SECS_PER_DAY!=0) changeMode=true;
if ((now()%SECS_PER_DAY==0 && changeMode)) {
tideMode=random(100)%sizeof(RandomModes);
InternalMemory.write(Mem_B_TideMode,tideMode);
changeMode=false;
ReefAngel.CustomVar[Var_TideMode]=tideMode+1;
switch (RandomModes[tideMode]) {
case ReefCrest: {
rcSpeed=ReefCrestMode(tideSpeed,vtDuration*2,true);
rcSpeedAS=ReefCrestMode(tideSpeed,vtDuration*2,false);
break;
case Lagoon: {
rcSpeed=ReefCrestMode(tideSpeed,vtDuration,true);
rcSpeedAS=ReefCrestMode(tideSpeed,vtDuration,false);
break;
case TidalSwell: {
rcSpeed=TidalSwellMode(tideSpeed,true);
rcSpeedAS=TidalSwellMode(tideSpeed,false);
break;
case Smart_NTM: {
rcSpeed=NutrientTransportMode(0,tideSpeed,vtDuration*50,true);
rcSpeedAS=NutrientTransportMode(0,tideSpeed,vtDuration*50,false);
break;
case ShortPulse: {
rcSpeed=ShortPulseMode(0,tideSpeed,vtDuration*50,true);
rcSpeedAS=ShortPulseMode(0,tideSpeed,vtDuration*50,false);
break;
case LongPulse: {
rcSpeed=LongPulseMode(0,tideSpeed,vtDuration,true);
rcSpeedAS=LongPulseMode(0,tideSpeed,vtDuration,false);
break;
case BHazard: {
rcSpeed=millis()%1200>800?tideSpeed:0;
rcSpeedAS=millis()%1200<400?0:tideSpeed;
break;
case Else: {
rcSpeed=ElseMode(tideSpeed,vtDuration*2,true);
rcSpeedAS=ElseMode(tideSpeed,vtDuration*2,false);
break;
case Sine: {
rcSpeed=SineMode(tideSpeed-tideMin,tideSpeed+tideMin,vtDuration*100,true);
rcSpeedAS=SineMode(tideSpeed-tideMin,tideSpeed+tideMin,vtDuration*100,false);
break;
default: {
rcSpeed=tideSpeed;
rcSpeedAS=tideSpeed;
ReefAngel.RF.SetMode(Custom,rcSpeedAS*pumpOffset,tide.isOutgoing());
ReefAngel.RF.SetMode(Custom,rcSpeed,tide.isIncoming());
void NextRFMode() {
vtMode++;
if (vtMode > 12) {
vtMode=0;
vtSpeed=50; // Constant
} else if (vtMode == 1) {
vtSpeed=40; // Lagoon
} else if (vtMode == 2) {
vtSpeed=45; // Reef Crest
} else if (vtMode == 3) {
vtSpeed=55; vtDuration=10; // Short Pulse
} else if (vtMode == 4) {
vtSpeed=55; vtDuration=20; // Long Pulse
} else if (vtMode == 5) {
vtDuration=InternalMemory.read(Mem_B_NTMDuration); // Smart_NTM
} else if (vtMode == 6) {
vtSpeed=50; vtDuration=10; // Smart_TSM
} else if (vtMode == 7) {
vtMode=9; // Night
} else if (vtMode == 10) {
vtSpeed=65; vtDuration=5; // Storm
} else if (vtMode == 11) {
vtSpeed=45; vtDuration=10; // Custom
if (vtMode!=InternalMemory.RFMode_read())
InternalMemory.RFMode_write(vtMode);
if (vtSpeed!=InternalMemory.RFSpeed_read())
InternalMemory.RFSpeed_write(vtSpeed);
if (vtDuration!=InternalMemory.RFDuration_read())
InternalMemory.RFDuration_write(vtDuration);
// Menu Code
void MenuEntry1() {
// Toggle refugium light between on/auto.
void MenuEntry2() {
ReefAngel.FeedingModeStart();
void MenuEntry3() {
void MenuEntry4() {
NextRFMode();
void MenuEntry5() {
ReefAngel.ATOClear();
void MenuEntry6() {
ReefAngel.OverheatClear();
void MenuEntry7() {
ReefAngel.SetupCalibratePH();
void MenuEntry8() {
ReefAngel.SetupCalibrateWaterLevel();
void MenuEntry9() {
ReefAngel.SetupDateTime();
// Custom Main Screen
void DrawCustomMain() {
const int NumScreens=3;
static boolean drawGraph=true;
// Main Header
// ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 35, 2,"Lee's Reef");
ReefAngel.LCD.DrawDate(5,2);
ReefAngel.LCD.Clear(COLOR_BLACK, 1, 11, 128, 11);
// Param Header
DrawParams(5,14);
switch (ScreenID) {
case 0:
if (drawGraph) { ReefAngel.LCD.DrawGraph(5,40); drawGraph=false; }
break;
case 1: { DrawStatus(5,40); break; }
case 2: { DrawSunMoon(5,40); break; }
// Draw Relays
DrawRelays(12,94);
// Date+Time
// ReefAngel.LCD.DrawDate(5,122);
if (ReefAngel.Joystick.IsLeft()) {
ScreenID--; drawGraph=true;
if (ReefAngel.Joystick.IsRight()) {
ScreenID++; drawGraph=true;
if (ScreenID<0) ScreenID=NumScreens-1;
if (ScreenID>=NumScreens) ScreenID=0;
void DrawCustomGraph() {
if (ScreenID==0)
ReefAngel.LCD.DrawGraph(5, 40);
void DrawParams(int x, int y) {
char buf[16];
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x+5,y,"Temp:");
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x+80, y, "PH:");
// Temp and PH
y+=2;
ConvertNumToString(buf, ReefAngel.Params.Temp[T2_PROBE], 10);
ReefAngel.LCD.DrawText(T2TempColor, DefaultBGColor, x+45, y, buf);
y+=6;
ConvertNumToString(buf, ReefAngel.Params.Temp[T1_PROBE], 10); //Big Number
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+80, y, buf, Num8x16);
y+=5;
ConvertNumToString(buf, ReefAngel.Params.Temp[T3_PROBE], 10);
ReefAngel.LCD.DrawText(T3TempColor, DefaultBGColor, x+45, y, buf);
void DrawStatus(int x, int y) {
int t=x;
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,15,y,"High",Font8x16);
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,85,y,"Low",Font8x16);
ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_GREEN);
} else {
ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_RED);
if (ReefAngel.LowATO.IsActive()) {
ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_GREEN);
} else {
ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_RED);
y+=12;
// Display Water level
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"AT0 Level:"); x+=65;
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.WaterLevel.GetLevel(),DPColor,x,y,1);
x+=5*(intlength(ReefAngel.WaterLevel.GetLevel())+1);
ReefAngel.LCD.DrawText(DPColor, DefaultBGColor, x, y, "%");
y+=12; x=t;
// Vortech Mode
ReefAngel.LCD.DrawText(0,255,x,y,"RF:"); x+=20;
ReefAngel.LCD.Clear(DefaultBGColor,x,y,t+(128-t),y+8);
if (vtMode == 0) ReefAngel.LCD.DrawLargeText(COLOR_GREEN,255,x,y,"Constant");
else if (vtMode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,x,y,"Lagoon");
else if (vtMode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,x,y,"Reef Crest");
else if (vtMode == 3) ReefAngel.LCD.DrawLargeText(COLOR_RED,255,x,y,"Short Pulse");
else if (vtMode == 4) ReefAngel.LCD.DrawLargeText(COLOR_RED,255,x,y,"Long Pulse");
else if (vtMode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,x,y,"Smart NTM");
else if (vtMode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,x,y,"Tidal Swell");
else if (vtMode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,x,y,"Night");
else if (vtMode == 10) ReefAngel.LCD.DrawLargeText(COLOR_BLUE,0,x,y,"Storm");
else if (vtMode == 11) ReefAngel.LCD.DrawLargeText(COLOR_BLUE,255,x,y,"Custom");
y+=10; x=t;
ReefAngel.LCD.DrawText(0,255,x,y,"RF Speed:"); x+=60;
ReefAngel.LCD.Clear(DefaultBGColor,x,y,128,y+8);
ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,x,y,vtSpeed); x+=15;
ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,x,y,"/"); x+=10;
ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,x,y,vtDuration);
y+=10; x=t;
// Display Acclimation timer
if (ReefAngel.CustomVar[Var_AcclDay] > 0) {
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"Acclimation Day:"); x+=100;
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.CustomVar[Var_AcclDay],DefaultFGColor,x,y,1);
} else {
void DrawSunMoon(int x, int y) {
char buf[16];
int t=x;
y+=2;
/// Display Sunrise / Sunset
sprintf(buf, "%02d:%02d", sun.GetRiseHour(), sun.GetRiseMinute());
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"Rise:"); x+=31;
ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,buf);
sprintf(buf, "%02d:%02d", sun.GetSetHour(), sun.GetSetMinute()); x+=36;
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"Set:"); x+=25;
y+=15; x=t;
/// Display Moonrise / Moonset
sprintf(buf, "%02d:%02d", Moon.riseH, Moon.riseM);
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"MR:"); x+=21;
sprintf(buf, "%02d:%02d", Moon.setH, Moon.setM); x+=36;
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"MS:"); x+=21;
ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,buf); x+=36;
if (Moon.isUp) ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,"@");
else ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,"_");
y+=10; x=t;
// MoonPhase
ReefAngel.LCD.DrawText(0,255,x,y,"Moon:");
ReefAngel.LCD.Clear(DefaultBGColor,x+32,y,128,y+8);
ReefAngel.LCD.DrawText(COLOR_MAGENTA,255,x+32,y,MoonPhaseLabel());
y+=10; x=t;
// MoonLight %
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"MoonLights:"); x+=68;
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(),DPColor,x,y,1);
x+=5*(intlength(ReefAngel.PWM.GetDaylightValue())+1);
void DrawRelays(int x, int y) {
// Draw Relays
ReefAngel.LCD.DrawOutletBox(x, y, TempRelay);
y+=12;
y+=12;
TempRelay = ReefAngel.Relay.RelayDataE[1];
TempRelay &= ReefAngel.Relay.RelayMaskOffE[1];
TempRelay |= ReefAngel.Relay.RelayMaskOnE[1];
static unsigned long LastChange=millis(); // Set the inital time that the last change occurred
static int Delay = random( 500, 3000); // Set the initial delay
static int NewSpeed = MidPoint; // Set the initial speed
static int AntiSpeed = MidPoint; // Set the initial anti sync speed
if ((millis()-LastChange) > Delay) // Check if the delay has elapsed
Delay=random(500,5000); // If so, come up with a new delay
int ChangeUp = random(Offset); // Amount to go up or down
if (random(100)<50) // 50/50 chance of speed going up or going down
LastChange=millis(); // Reset the time of the last change
if (WaveSync)
return NewSpeed;
return AntiSpeed;
/* void DelayedOnModes(byte relay) {
static unsigned long startTime=now();
if (startTime==LastStart && ReefAngel.HighATO.IsActive()) {
ReefAngel.Relay.On(relay);
} else {
ReefAngel.Relay.DelayedOn(relay);
*/-J
