Looking for Reef Angel +
Sobos Reef
Re: Looking for Reef Angel +
News update. The DM155E fixtures are NOT able to be used with any 3rd party controller. Reef Radiance just released a new light called the DM-155C which IS controllable by the Apex. Not sure about Reef keeper or Reef Angel tho.
Now I really don't know what to do :/
Using Tapatalk
Sobos Reef
Using Tapatalk
- Sacohen
I stumbled across your thread to them on Reef2Reef.
Sorry about that.
So getting back to your original question on whether or not the get the Analog or PWM version.
It looks like your just going to be using the Jebao pumps on it and they can work with either.
To control the Jebao and future LED lights you would need to get the dimming module.
The new dimming modules have jumpers in them so that you can change from Analog to PWM and even from 0-10v to 0-5v.
I would suggest getting the PWM RA+ for 2 reasons.
1) most things are going to PWM lately.
2) the PWN head unit is a little less expensive then the analog.
Sorry about that.
Sobos Reef
okay thanks for that! I still want to get this controller, just not sure what I wanna do with the lights nowSacohen wrote:I stumbled across your thread to them on Reef2Reef.
Sorry about that.
Using Tapatalk
Flip the lights.. Get the controllable one. Apex uses 0-10V analog
- Sacohen
Get it.
Use the 2 dimming ports on the head unit for the Jebao pumps the get the dimming module if you get new lights.
Sobos Reef
So sell the lights? Get the controllable lights and buy an apex ? Did I get that right? Lol
Using Tapatalk
- Sacohen
If the lights are analog, like Lee says then get the RA analog, get the lights cut the ends off and connect the lights to the RA. You only need the dimming module if you are going to have more tba. 2 controllable devices.
Sobos Reef
okay, I must've been hit in the head today bc I'm not picking this up Lol youre saying to cut the cords on my lights???Sacohen wrote:If the lights are analog, like Lee says then get the RA analog, get the lights cut the ends off and connect the lights to the RA. You only need the dimming module if you are going to have more tba. 2 controllable devices.
I don't wanna cut anything Lol plug and play works for me. if I have to change lights then so be it. I don't wanna risk ruining something if I don't have to tho.
Using Tapatalk
- Sacohen
The Apex use an RJ-45 or Ethernet connector.
The RA uses a different type of connection for the main unit or bare wires for the dimming module.
Sobos Reef
Ohh.. well if I get the controllable lights then I won't have to cut the wires most likely right?Sacohen wrote:The Apex use an RJ-45 or Ethernet connector.
Using Tapatalk
- Sacohen
No. The controllable lights will work on the Apex without cutting them, but to use them in the RA it's a different connection. Something can be made to plug the RJ-45 from the lights into so you wouldn't gave to cut the ends off.
Sobos Reef
Alright this just got so confusing for me really fast. looks like I gotta go back to the drawing board first. thanks for all your help guys, I really appreciate it even if I don't understand it lolSacohen wrote:No. The controllable lights will work on the Apex without cutting them, but to use them in the RA it's a different connection. Something can be made to plug the RJ-45 from the lights into so you wouldn't gave to cut the ends off.
Using Tapatalk
howaboutme
I will try to elaborate since I'm on a desktop.
Basically what Sacohen is saying is that most things that can be controlled by an Apex can be controlled by an RA. The only difference is the connection point (or the plug from the lights to the controller). Apex uses an ethernet connection, just like your router. But an RA uses a different connection. The modification you will have to do (and there are plenty of threads on it) is to cut the ethernet connection off and attach the relevant RA plug. Roberto (or others) can direct you on which connection to buy at Radioshack or Ebay.
Hope that helps explain it a bit better. It sound harder than it is..though I've never tried it myself...
Jack
- Sacohen
I'll try to explain it with images later today when I'm at home.
Dont sweat it, it probably wont come with the wire to connect to the apex anyway...you'll most likely need to modify an ethernet cable...not that tough. We're here to walk you through it
I would recommend getting the dimming module. You'll have three fixtures with two channels. You'll be able to do a nice sunrise/sunset with separate controlability.
Get the PWM reef angel and you'll use that for the jaebos.
I'm seriously contemplating flipping my lights as well...its just that I paid so little for mine, it'll be a decent upgrade
decisions decisions...
- Sacohen
The Apex uses this type of connection and RJ-45 or Ethernet.
The RA uses what I call a 2 pin header connection. I don't know the actual name of it but it looks like this.
Or if it's going to the dimming module just bare wire that screw in.
If the lights come with the Apex connection I can take an ethernet jack and put the correct end coming off of it so you don't have to cut the end off of yours.
Lee is probably right and it wouls not come with the RJ-45 end on it.
Sobos Reef
Okay now it makes sense Lol sorry about that, between work and this forum, I got lost somehow Lol thanks!
Using Tapatalk
- Sacohen
Good. Glad to help.
Hey Sobos, ReefRadiance is selling an upgrade kit for existing DM-155e fixtures. I think that would be the best route to go if you haven't done anything yet...
Sobos Reef
Hey! Yes I was talking with them for awhile about what I was going to do! Ive decided to buy the upgrade kits eventually and then just buy an Apex since that's the only controller that's been proven to work so far with them. Thanks for the heads up tho!lnevo wrote:Hey Sobos, ReefRadiance is selling an upgrade kit for existing DM-155e fixtures. I think that would be the best route to go if you haven't done anything yet...
Using Tapatalk
There is no difference between how the Apex controls a dimmer and the ReefAngel. The Apex is simply 0-10V analog signal which the RA can do just fine. However I understand your hesitance. We are here to help however you go.
Regardless, If you could please keep us posted on the upgrade kit, I'm very interested to see what it comes with, how it works and some pics on the installation. Thanks for your help in advance.
Sobos Reef
No problem. Its still up in the air. I may not be getting the upgrade kits for awhile tho. Ran into a few financial snags so I'll have to save up for them anyways.lnevo wrote:There is no difference between how the Apex controls a dimmer and the ReefAngel. The Apex is simply 0-10V analog signal which the RA can do just fine. However I understand your hesitance. We are here to help however you go.
Using Tapatalk
