Hi Guys,
Today my reef angel froze, so I unplugged it and plugged it in and it wouldn't boot up.
If I disconnect the wifi it starts and works fine (without wifi). Once I start the reef angel I can plug in the wifi and it will flash green and blue.
The wifi is up and working for other devices. The internet is up and working.
My IP address is the same. I have an extra wifi cable and I swapped that out with no luck.
So I guess first off, I guess I never paid attention, what are the lights supposed to do? Is it supposed to flash green and blue over and over?
Then I guess next anyone have any advice on next steps?
WiFi Issue
Re: WiFi Issue
Green flashing is normal. Blue is that it is not connected to the wifi network.
Can you connect to it using a serial terminal such as Tera Term or putty?
tpriscu
Re: WiFi Issue
I apologize , I dont know what tera term or putty is.
