No control
Cromanon
No control
Hello, today I lost communication from the application of my phone and try by the RA I realize that does not turn the display, disconnect the AC RA for 10 minutes but no change. Can you help me? Thank you.
Re: No control
Is the green power LED lit?
Do you get 3 blinks on the red status led when you apply power?
Cromanon
Re: No control
Yes when plug on power 3 time on red led and steady on green led
Cromanon
Re: No control
No change. Blink red led when upload but display is off and no comunication with app.
Cromanon
Re: No control
Just blink first led from left to right
Cromanon
Re: No control
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardLights( Port1,11,0,23,0 );
ReefAngel.StandardLights( Port2,12,0,16,0 );
ReefAngel.StandardLights( Port3,20,0,10,0 );
ReefAngel.Relay.DelayedOn( Port6,4 );
ReefAngel.Relay.DelayedOn( Port7,2 );
ReefAngel.SingleATO( true,Port8,240,0 );
ReefAngel.Portal( "cromanon" );
Cromanon
Re: No control
Cromanon
Re: No control
just for second check, I reenter the ssid and pass in wifi , but no change.
Re: No control
Green blink on the wifi attachment means it is connected, so I don't think it's that.
It is sounding like head unit issue.
Is the controller switching relays on/off and just not responding to wifi or you don't hear it click relays at all?
Test it with your ATO float switch. Move it up and down. Does Port8 turn on/off?
Cromanon
Re: No control
yes, I move float sw and sound a click.
Re: No control
So, it seems the controller is operational and just the screen is malfunctioning, but the wifi should work too.
I'd check for water damage.
