RMC's Humble Code Abode
PostPosted: Mon Jun 30, 2014 1:59 pm
Hi all - this is a preemptive thread to track all future code efforts.
My aquarium is a 92 gallon Bow front corner with 3 strings of LED's (controlled by a small typhoon led controller), a 30g sump + 5g refugium. I dose Kalk in the top off water.
Full tank shot: http://i.imgur.com/SZp7WEP.jpg
    ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.AddPHExpansion();  // pH Expansion Module
    ReefAngel.AddWaterLevelExpansion();  // Water Level Expansion Module
    ReefAngel.FeedingModePorts = Port2Bit | Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.LightsOnPorts = Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port8Bit;
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port5 );
    ReefAngel.StandardFan( Port1,800,810 );
    ReefAngel.Relay.DelayedOn( Port2,10 );
    ReefAngel.DosingPumpRepeat( Port3,0,20,60 );
    ReefAngel.DosingPumpRepeat( Port7,0,20,30 );
    ReefAngel.StandardLights( Port8,11,0,19,0 );
    ReefAngel.PWM.SetDaylight( PWMParabola(8,0,20,30,15,100,15) );
    ReefAngel.PWM.SetActinic( PWMParabola(10,30,20,30,15,100,15) );
I'm using the basic Reef Angel Plus package and will start by controlling:
  • (Port 1) Canopy fan when temperature exceeds 81 degrees. Otherwise keep it off to minimize evaporation
  • (Port 2) Skimmer - turn off for water changes / feeding - delay 10 minutes
  • (Port 3) ATO - (External relay / float to prevent overflow) turn on for 1 minute every 20 minutes
  • (Port 4,5,6) Jebao 45 + Jebao 25 + Return - turn off during feeding / water changes
  • (Port 7) a small circulation pump in the sump used to prevent detritus buildup - turn on for 30 seconds every 20 minutes
  • (Port 8) Extra string of LED's which turns on mid day
  • Testing the PWM output with 2 LED strings (blue + white/red/green)
In the future I'd like to:
  • Control the Jebao pumps (softer night mode / alternate modes day to day / simulate storm surges)
  • Add a more powerful DC return pump and vary the flow
  • Add a DC pump to the refugium to decrease flow to a trickle at night
  • Create a chilled + stirred feeder tank and dose cyclopeeze throughout the day
  • PWM Addon: control all lights using the RA + weather pattern / moonlight
  • Wifi Module - monitor the aquarium while away
  • Maybe humidity sensor under the stand with a ventilation fan
PostPosted: Mon Jun 30, 2014 2:05 pm
Awesome!! Tank looks good :)
PostPosted: Mon Jun 30, 2014 3:09 pm
Move that wifi module up in your priority list! Otherwise great start! You can also save yourself 2 relay ports. You dont *need* the jaebos plugged in.
PostPosted: Mon Jun 30, 2014 3:29 pm
Hi Inevo - you're right, I could have the return pump + 2 jebaos on a splitter; however I do want them to turn off during feeding time.
Also, right now I don't have anything else to automate. Hopefully that will change soon ;)
PS: thank you to the mod for fixing my link and not berating me for sneaking a URL past the filter.
PostPosted: Mon Jun 30, 2014 3:33 pm
RMc wrote:PS: thank you to the mod for fixing my link and not berating me for sneaking a URL past the filter.
Yeah, I think it is 5 post. You are almost there!!!
Just to complement what lnevo recommended, you can also turn off the DC/Jebao pumps using only the dimming signal and that way you can always leave them plugged into the wall.
PostPosted: Wed Jan 14, 2015 7:39 pm
Believe it or not I just got around to reprogramming my RA...whew...took a little bit of plugging and unplugging and com port foolery and getting the TTL on the right pins...but! the code is in.
PostPosted: Tue Jan 27, 2015 7:13 am
Having some trouble with inconsistent relay activity.
http://pasteboard.co/EExwAhl.png
My ATO (#3 green) and a small circulation pump (#7 blue) are supposed to be turning on for 60/30 seconds every 20 minutes.
However, if you look at the relay activity it seems that they're not consistently doing so. Both are set to "auto" as viewed on the portal.
Any ideas?
PostPosted: Tue Jan 27, 2015 7:53 am
You will not see the results in the portal accurately as the portal only sends updates every 5 minutes and the status is sent at the time. If the port is already off you will not see that it was on.
Roberto, I have an idea how we can address this, going to open an issue to discuss the options...
PostPosted: Wed Jan 28, 2015 9:25 am
Another Q: on the portal, is there a way to see PH and temp on separate graphs so that changes are more readily apparent? Both of mine just look like flat lines because of the vertical scaling.
PostPosted: Wed Jan 28, 2015 9:49 am
Yup. Just click on the labels at the top to turn them on and off.
Next
Return to My PDE/INO file
