Time issues
Kushing
Time issues
Post by Kushing »
Hello, I am having problems with my reef angel, no the plus. I cannot get the time to change and I cannot get the display to not pixel out and be unreadable. I have added this code to get the time feature:
ReefAngel.AddDateTimeMenu();
when I go to change the time it either doesn't take or the screen scrambles up. Code is fine is the reef angel screwed? Thanks
Re: Time issues
Does the display only have problems when you go to change date/time?
Do you have the wifi attachment?
Kushing
Re: Time issues
Post by Kushing »
No wifi attachment, The screen scrambles intermitently. It will not recognize a new time. I can even get to the screen , change it, and it still wont apply to the set up. This mishap is causing me issues because the light schedule is all messed up now and I have Snowflake clowns breeding in this tank and in the middle of their 3 set of fry....I have a feeling the unit memmory is corrupted but any help will be apprciated.
Re: Time issues
Make sure that you move the highlight to the ok button or you would be just canceling it.
The only other way I see that you would be able to set the time without the wifi is to use the Client Suite software that Dave created. Look in the download section.
