Hi,
I just purchased the Rope Leak Detector expansion kit. Upon following the instructions in the Quick Start Manual, I cannot find "CustomMainScreen_RopeLeakDetector" under Example Codes.
Where is this code?
DanInDoha
Where is CustomMainScreen_RopeLeakDetector ?
Re: Where is CustomMainScreen_RopeLeakDetector ?
Just use the wizard. It's what you will end up doing anyway.
newtoke
I used the wizard and the only screen I see is in the menus to clear a leak. Is there a main screen notification as well?
Yes, when leak is detected.
If you scroll the screens, you will also see the Leak status together with the ATO statuses.
Just use the joystick and move left or right.
