getting error
jack
getting error
Greetings,
I am trying to upload the new codes from reef angel wizard as have changed few equipements but its not letting me
when i go into software it says generate and upload... i click then it says wait for few seconds and than it says
AN ERROR HAS OCCURED. PLEASE TRY AGAIN.
what shall be the reason ?
please lemme know asap as have changed lights and need to get it on .....
jack
Re: getting error
2014 Main Screen
Standard Menu
Binary sketch size: 54,856 bytes (of a 258,048 byte maximum)
2014 Main Screen
Standard Menu
jack
Re: getting error
it says this.... tried it to upload another way around also....
jack
Re: getting error
did checked the serial port ....
i have RA+
i have RA+
jack
Re: getting error
rimai any luck ?? what shall be done ??
thanks
thanks
KRavEN
Re: getting error
Communication error you're getting indicates that the RA isn't responding to the serial commands telling it to reset and go into programming mode. Most likely the problem is with the connection between the computer and the RA via the USB TTL cable if the RA is working normally when connected to the relay.
Did the serial port number change on the computer? Does the RA power properly when only the USB TTL cable is attached? Is the correct serial port and RA type selected in the arduino IDE?
Can you try holding the reset button on the RA, hit program in the IDE, and release the reset button as soon as you see "Rebooting Reef Angel Controller"? Sometimes this is needed if you get bad code on the controller causing it to spit a lot of output to the serial or it's in a reboot loop.
If none of that works and you have a USBAsp you can hook that to the ICSP header on the RA. Then set the programmer in the arduino IDE to USBAsp and select program bootloader in the arduino IDE. This will reprogram the bootloader and get the RA back to a un-programmed state bypassing the serial port connection as a possible problem. Once it's in this state then try to program as normal through the serial port and it should work.
jack
Re: getting error
hello KRavEN thanks for the detailed reply but sorry to say i am not at all techno geek and didn't got what are you trying to explain me... so to try something different as a last resort.. i downloaded the software to my sisters laptop and attached it to my RA+ and to my surprise it worked perfectly and i uploaded the code...
so now the problem comes with my MAC my sisters laptop is windows so is there any problem with my apple OS ??
thanks for your time guys
KRavEN
Re: getting error
I don't have much experience with apple but it sounds like a problem with the driver for the USB TTL cable.
- Contact:
Re: getting error
what port do you have selected? if you have the wrong port chosen on your mac, it won't work and you can get similar errors that you are receiving.
please check the port and post back what port you are using.
Sent from my Moto X
Sent from my Moto X
jack
Re: getting error
hello i am back
@ binder there is no option coming to select the port in my mac tried it many times
also uninstalled the software couple of times and reinstalled but same issues
Re: getting error
I think its under the tools menu. Look for Serial port, its def there on Mac
jack
Re: getting error
ohkie zoo there are 6 ports
which to choose ??
which to choose ??
Re: getting error
usually it's something like tty.usbserial-XXXX or something like that. What are the ports you have listed?
jack
Re: getting error
there are these many port on my system
/dev/tty.bluetooth-incomming-port
/dev/cu.bluetooth-incomming-port
/dev/tty.bluetooth-modem
/dev/cu.bluetooth-modem
/dev/tty.dharmensiphone-wireless
/dev/cu.dharmensiphone-wireless
hope this helps
hope this helps
Re: getting error
Your cable USB cable is not listed.
Are you sure that you have installed the drivers according to the manual instructions?
jack
Re: getting error
yes i am sure i installed everything according to the manuals ...
than what do i need to do ??
- Contact:
Re: getting error
odd question but im going to ask the obvious. is the usb cable plugged into your mac before you launch arduino? if it is not, when arduino launches the port is not found and no ports are selected and it does not automatically select it when the cable is plugged in.
i know that was a silly question for me to ask but i wanted to ask it anyways just to make sure we were not overlooking the obvious.
- Contact:
Re: getting error
another question, what version of os x are you running? 10.9, 10.8, 10.7, etc?
Re: getting error
This is the step that installs the drivers in your MacOSX.
Can you check if your Mac has any peripherals without drivers?
Did you try another USB port?
You are positively sure that you did this, correct?You will also need to install the USB TTL cable drivers. Double-click the file FTDIUSBSerialDriver_10_4_10_5_10_6 and follow the instructions on each step. A restart of your computer will be necessary to finish the driver installation.
jack
Re: getting error
@binder yes it was plugged before.... i am using mac OS X 10.9.4
@rimai i positively did that but i never restart my computer so might that be a problem ? what i ll do is today once free delete all the old data of the software and restart the computer again install it restart than connect to RA and than start Audrino
previously i use to work the same way but never had any issues
Re: getting error
Could it be that the USB cable got damaged?
Can you check for any stripped wire?
jack
Re: getting error
nope thats not a problem if the cable is damaged than i would not be able to connect it via another computer....
Re: getting error
Ahh, so you can upload from another computer... I may have missed that.
That is definitely a driver not installed correctly then.
Does your OS recognize the cable when plugged?
jack
Re: getting error
ll chi it later for that
but roberto one serious problem
my relay stopped working
it was in front of me that it stopped and i had a spare relay so that i could change it immidiately else my tank would have gone without lights/chiller/pump/skimmer every thing means everything for 2 days...
so what found be the possible reason of relay not working. i am really having a bad day
jack
Re: getting error
Yes sir the entire box not working
But the controller in connection to that working
So i had this extra relay expansion that i had bought but havent used it
Quickly took it out an joined it
And to my luck its working
So what could have gone wrong ??
Re: getting error
Not so sure. Did the breaker pop?
Are you sure it was not the cable that got loose?
If not any of those, PM to send it back and I'll take a look at it?
