Hi Ive been compiling code for a while now and making changes to setting etc. and uploading with no issue, now i am getting an error when compiling "sketch to big" please help here is the code below, but nothing has changed since last update ??
ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardHeater( Port2,260,265 );
ReefAngel.StandardFan( Port8,270,275 );
ReefAngel.DosingPumpRepeat( Box1_Port1,0,1440,1 );
ReefAngel.DosingPumpRepeat( Box1_Port2,5,1440,8 );
ReefAngel.Portal( "jcondello","NUMBER7" );
int x,y;
// I/O Expansion
byte bkcolor;
x = 14;
y = 8;
for ( int a=0;a<6;a++ )
ReefAngel.LCD.DrawCircleOutline( x+(a*20),y,4,COLOR_MEDIUMORCHID );
if ( ReefAngel.IO.GetChannel(a) ) bkcolor=COLOR_WHITE; else bkcolor=COLOR_GRAY;
ReefAngel.LCD.FillCircle( x+(a*20),y,2,bkcolor );
// Parameters
ReefAngel.LCD.DrawMonitor( 15, 19, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 19, ReefAngel.Params );
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,49,53, "SAL:" );
ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.Salinity,COLOR_DARKKHAKI,73,53, 10 );
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,68, "PHE:" );
ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_MEDIUMSEAGREEN,39,68, 100 );
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,68, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,68, ReefAngel.WaterLevel.GetLevel() );
// Main Relay Box
ReefAngel.LCD.DrawOutletBox( 12, 82, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 99, TempRelay );
// Date and Time
Arduino Sketch To Big Issue ??? HELP !
- Sacohen
Re: Arduino Sketch To Big Issue ??? HELP !
Do you have the RA or RA+?
I see the DCPumps in there. Did you just add that?
The DCPump code added a lot to the libraries and most of the time that is the cause of your problem.
You may need to upgrade to the RA+ or go back to an older library.
jcondello
I do have the ra+ but the issue is when compiling not uploading ??
- Sacohen
Make sure. You have the Aurduino ser to RA + and not RA. It may have gotten changed by accident.
jcondello
yes thank you thats all it was
jcondello
can you help put with setting the RA to send data to the portal i have added the user name & portal Key to the code but have not had any luck with it, i can use the portal switching on/off but cant get the ra to send data, i also have the Wifi dongle attached & work thank you
jcondello
never mind just got it going thank you !
- Sacohen
No problem. It's usually something simple like that.
