problem reef angel not fuction
marco3020
Post by marco3020 »
Hello everyone st ammattina I wake up and find it all off my reef angel, pumps etc. I press the joistic turns on and there is a red light and I see 2 green door (connected ceiling) but does not turn on the ceiling light, and other ports green but do not go what can I do?
I tried to reload the code and it says on the card problems help me
Re: problem reef angel not fuction
Look for any signs of water damage.
marco3020
Post by marco3020 »
I do not see signs of water, the controller turns on but does not go nowhere, I tried to recharge code originario.ma wrong, I tried to uninstall and reinstall sw and recharge code problems but says the board solezione search site on Arduino
help me please :(
marco3020
Post by marco3020 »
I tried to open the relay box and now tells me when I load error uploading as photos, reef angel and remain green in the door 6:08 sketch Fitting something but if they do not go nowhere, what do I do I'm desperate, I have a ceiling that without the pwm output does not turn on: (
there is a hard reset or a soft reset to try?
Make sure you have the correct board and serial port selected.
marco3020
Post by marco3020 »
how do I verify this? tells me com port 3
Choose another listed port until you find the one that works.
marco3020
Post by marco3020 »
how do I choose which port to use? me alone with 3
marco3020
Post by marco3020 »
see problems
marco3020
Post by marco3020 »
help me please!!!!
Unplug the cable from the computer and see what ports you have then.
Which Reef Angel do you have? Standard or Plus?
If nothing works, your cable or your head unit may have gone bad. Check for water damage.
marco3020
Post by marco3020 »
i have ra standard
marco3020
Post by marco3020 »
ecco le foto
Did you try picking the other option?
Reef Angel Controller instead of Reef Angel Controller w/ optiboot?
It's worth a shot. I don't know which version you have.
Do you have the wifi attachment?
marco3020
Post by marco3020 »
I tried both Angel reef plus that controller Wi-Fi, same thing, I do not have Wi-Fi
You need to test the cable to make sure it is working.
Without the wifi attachment, you will need to use something else that you can connect to the cable.
It's either the cable or the head unit.
marco3020
Post by marco3020 »
and what should I do listen.
marco3020
Post by marco3020 »
up help me please :(
If you don't have anything to test the cable, it will be hard to find if the problem is the cable or your controller.
I'm leaning towards the controller though.
PM if you would like to send it back for analysis.
marco3020
Post by marco3020 »
how to test the cable? I have a tester if it helps, but I have to figure out how to test
You can use it to communicate with another device that accepts serial TTL level, such as the WiFi attachment, the RF expansion or another arduino board.
Sent from my SM-G900P using Tapatalk
marco3020
Post by marco3020 »
I do not have any of the three, I only arduino ati omega 25 60 okay?
Yes. You can use arduino mega. Google how to wire them up.
marco3020
Post by marco3020 »
and then as the text? I have no EPR ​​programs do
marco3020
Post by marco3020 »
marco3020
Post by marco3020 »
I tried to uninstall everything and delete all folders from the ra pc, I updated USB ports pc, and I see that as soon as the sketch Fitting ttl cable to the PC do not recognize the sound and at this point I do not think it's the cable and not ttl I know what it is, now I get this error.
I think it is your head unit then.
marco3020
Post by marco3020 »
and what should I do? and a week that I'm ra is so I need a solution!, I'm regretting to have bought this product and recommended it to others, because then there is no assistance
We've all been trying to help you out here.
Don't BS that there is no assistance. Your language barrier makes it tough too. I barely understand a few posts from you in this thread. If we don't understand what you write to us, how do you expect us to reply back?
If it is the head unit, you should replace it or send it back for us to look at it.
