Head unit no longer graphs
caliman
Post by caliman »
My head unit no longer graphs pH and temp. It hasn't done that in some time.
Anyone know where to look to fix this?
Here is my code:
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port7Bit;
    ReefAngel.Relay.On( Port7 );
    ReefAngel.MoonLights( Port2 );
    ReefAngel.ActinicLights( Port3 );
    ReefAngel.DayLights( Port4 );
    ReefAngel.RF.UseMemory = true;
    ReefAngel.Portal( "caliman", "498y" );
    int x,y;
    // Parameters
    ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params,
    ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params );
    // ORP
    ReefAngel.LCD.DrawText( COLOR_PALEVIOLETRED,DefaultBGColor,49,54, "ORP:" );
    ReefAngel.LCD.DrawText( COLOR_PALEVIOLETRED,DefaultBGColor,73,54, ReefAngel.Params.ORP );
    // pH Expansion
    ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,75, "PHE:" );
    ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_MEDIUMSEAGREEN,39,75, 100 );
    // Main Relay Box
    ReefAngel.LCD.DrawOutletBox( 12, 95, TempRelay );
    // Date and Time
Re: Head unit no longer graphs
Maybe it is your browser.
I can see your chart just fine.
http://forum.reefangel.com/status/chart ... &filter=ph
caliman
Post by caliman »
It is fine in the browser - I am talking about the display on the head unit. It used to graph on its own.
Ahh...
I got it now, sorry for misunderstanding the question :oops:
The graph was replaced with a whole new screen with additional screens that can be switched over using the left and right of the joystick.
If you still want to get the graphs back, we can do it without a problem, but you would loose all these new screens too.
caliman
Post by caliman »
Interesting - what are these screens you speak of? :)
I have pushed left and right on the joystick to no avail - do I have to hold it there for a few seconds to activate the new screen?
Just revisited your code.
You are missing both options in the code :(
So, to make it easy for you, here are revised ones:
2014 Screens:
    ReefAngel.Use2014Screen();
And the same code with the graph. (I have to tested the code to make sure there is nothing in the way of the graph)
    int x,y;
    // Parameters
    // ORP
    // pH Expansion
    // Main Relay Box
    // Date and Time
  ReefAngel.LCD.DrawGraph(5, 5);
Let me know if it works now.
