It's 8.1rimai wrote:Can you check which relay box revision you have?
It will be printed in the pcb.
I did this to quiet down my power supplycosmith71 wrote:Update!
I've been running these for a few months now.
I have 8 LDD drivers running open-air on top of the canopy. They run hot, but much less than the rated max. I used a Genssi 48V DC 7.3A 350W Regulated Switching Power Supply from Amazon. I've had no problems, but the fan is kinda noisy when it switches on.
LED list is as follows (all Cree):
RB x32
Blue x8
UV x10
NW x10
No lenses. Lights 6-8" off the water. I have a Crocea clam on the bottom which is doing great, as well as a ton of LPS at all levels. I have a soccer ball sized green pavona mid level towards the back. Zoas, softies, etc. Everything is doing well. I'm going to load up the acclimation code and try some more SPS.
I used the Rapid LED driver boards. I don't recommend them. They use a spring-loaded connector which doesn't hold the wires very well. I'd much rather have the screw down kind.
Thanks for all the input! I'll try to get a FTS after the lights come on.
Yep, it plugged right in and considering its a bigger fan it spins slower and creates more air...just a bit more bulkycosmith71 wrote:Lee: Thanks!
Pandimus: You replaced the built-in fan? There's a thought.
