Single Ato interval
mrwlf
Single Ato interval
Hi. I'm using RA+ singleato with 1hour interval. Is there a way to reduce The interval? 30 minutes will be fine. Thx
Inviato dal mio GT-I9505 utilizzando Tapatalk
Re: Single Ato interval
Why not just disable with zero? Do you get that much evaporation in 30minutes?
mrwlf
In summer with fans i do and it lowers the skimmer level... And i can't disable for safety reasons. No way to set it between 0 and 1hour?
Not with the SingleATO in our libraries. You can certainly create one with the same framework and change the settings to use minutes instead of hours.
I've been using SingleATO with hour interval disabled for 4 years without ever having any problems.
That feature is mainly targeted to those that have heavy turbulence in the water and not as safety feature.
Why do you think disabling would not work?
- cosmith71
I didn't realize there was a timeout built in. Here's what I use. This is using internal memory for timeout, etc.
Up top in the globals section:
Down in the loop()
HTH,
static time_t LastATO=millis(); // For de-bounced ATO
// Debounced ATO code. Activate ATO no more than every 60 seconds (60000 milliseconds).
if (!ReefAngel.LowATO.IsActive()) LastATO=millis();
if (millis()-LastATO<60000 && millis()-LastATO>10)
ReefAngel.Relay.Off(TopOff);
ReefAngel.SingleATOLow(TopOff);--Colin
mrwlf
Re: R: Single Ato interval
Thanks a Lot Colin. Is there a way to put something in the code that set The maximum Ato time?
Example: activate ato for a maximum of 5 seconds not more then once every 30 minutes.?
- cosmith71
It would take new code.
Why would you only want it to run for 5 seconds? You could run dry if you do it like that.
mrwlf
5 seconds was just for example
What I'm not understanding is the reason why every 30 minutes?
Why not just let the ATO do its job on demand with a max run time of x seconds?
+1rimai wrote:What I'm not understanding is the reason why every 30 minutes?
- cosmith71
It's beyond what I know how to do.mrwlf wrote:5 seconds was just for example![]()
Here's exactly what you want. Only diff is the example the timeout is 300 seconds and i set the runtime to 305 seconds to make sure the timeout could get triggered in case the reservoir went dry or pump issue. So i would just make sure the runtime parameter is equal to or higher then the ato timeout arg.
http://forum.reefangel.com/viewtopic.ph ... 14b#p39364
mrwlf
Because every time i put my hands in the sump it keep triggering on and off The ATO...rimai wrote:What I'm not understanding is the reason why every 30 minutes?
mrwlf
lnevo wrote:Here's exactly what you want. Only diff is the example the timeout is 300 seconds and i set the runtime to 305 seconds to make sure the timeout could get triggered in case the reservoir went dry or pump issue. So i would just make sure the runtime parameter is equal to or higher then the ato timeout arg.
This is what i need, i will try it soon. Thanks!
