Single Ato interval
Ask in here.
PostPosted: Mon Jul 21, 2014 1:44 pm
Hi. I'm using RA+ singleato with 1hour interval. Is there a way to reduce The interval? 30 minutes will be fine. Thx
Inviato dal mio GT-I9505 utilizzando Tapatalk
PostPosted: Mon Jul 21, 2014 1:54 pm
Why not just disable with zero? Do you get that much evaporation in 30minutes?
PostPosted: Mon Jul 21, 2014 2:16 pm
In summer with fans i do and it lowers the skimmer level... And i can't disable for safety reasons. No way to set it between 0 and 1hour?
PostPosted: Mon Jul 21, 2014 2:39 pm
Not with the SingleATO in our libraries. You can certainly create one with the same framework and change the settings to use minutes instead of hours.
I've been using SingleATO with hour interval disabled for 4 years without ever having any problems.
That feature is mainly targeted to those that have heavy turbulence in the water and not as safety feature.
Why do you think disabling would not work?
PostPosted: Mon Jul 21, 2014 3:30 pm
I didn't realize there was a timeout built in. Here's what I use. This is using internal memory for timeout, etc.
Up top in the globals section:
static time_t LastATO=millis();    // For de-bounced ATO
Down in the loop()
// Debounced ATO code. Activate ATO no more than every 60 seconds (60000 milliseconds).
    if (!ReefAngel.LowATO.IsActive()) LastATO=millis();
    if (millis()-LastATO<60000 && millis()-LastATO>10)
    ReefAngel.Relay.Off(TopOff);
    ReefAngel.SingleATOLow(TopOff);
HTH,
PostPosted: Tue Jul 22, 2014 2:27 pm
Thanks a Lot Colin. Is there a way to put something in the code that set The maximum Ato time?
Example: activate ato for a maximum of 5 seconds not more then once every 30 minutes.?
PostPosted: Tue Jul 22, 2014 2:38 pm
It would take new code.
Why would you only want it to run for 5 seconds? You could run dry if you do it like that.
PostPosted: Tue Jul 22, 2014 2:41 pm
5 seconds was just for example :-)
PostPosted: Tue Jul 22, 2014 2:51 pm
What I'm not understanding is the reason why every 30 minutes?
Why not just let the ATO do its job on demand with a max run time of x seconds?
PostPosted: Tue Jul 22, 2014 2:54 pm
rimai wrote:What I'm not understanding is the reason why every 30 minutes?
+1
Next
Return to How do I code ...
Users browsing this forum: Google [Bot] and 4 guests
