ReEfnWrX's INO
ReEfnWrX
ReEfnWrX's INO
Post by ReEfnWrX »
Had yet another HD failure, time to stop playing Russian Roulette.
////// Notes
/// PWM Random Wave Mode
/// Parabola
/// NTM
/// CarbPhos
/// Coral Acclimation Code
/// WP40 Delay when return pump turns on
////// Memory Locations used by all formulas
#define Mem_B_AcclDay  100 // Acclimation Day
#define Mem_B_AcclDuration  101 // Days in Accl Cycle
#define Mem_B_SlopeStart  102 // Slopestart for White and Blue channels
/////// Memory Locations used by Blue Formula
#define Mem_B_AcclStartEndBlue  105    // Acclimation starting Slope end%
#define Mem_B_SlopeEndBlue  106    // slope End%
////// Memory Locations used by White Formula
#define Mem_B_AcclStartEndWhite  110 // Acclimation starting Slope end%
#define Mem_B_SlopeEndWhite  111    // Slope End%
    ReefAngel.AddStandardMenu();  // Add Standard Menu
/////    ReefAngel.AddPHExpansion();  // pH Expansion Module
    ReefAngel.FeedingModePorts = Port3Bit;
    ReefAngel.WaterChangePorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port8Bit;
    ReefAngel.LightsOnPorts = Port2Bit | Port4Bit | Port8Bit;
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port7 );
//Custom Port Labels
ReefAngel.CustomLabels[0]="Heater";
ReefAngel.CustomLabels[1]="BlueLED";
ReefAngel.CustomLabels[2]="ReturnPump";
ReefAngel.CustomLabels[3]="WhiteLED";
ReefAngel.CustomLabels[4]="KalkATO";
ReefAngel.CustomLabels[5]="CarbPhos";
ReefAngel.CustomLabels[6]="WP40";
ReefAngel.CustomLabels[7]="Refugium";
    ReefAngel.StandardHeater( Port1 );
    ReefAngel.StandardLights( Port2,9,1,22,29 );
    ReefAngel.StandardLights( Port4,10,1,21,29 );
    ReefAngel.SingleATO( true,Port5,1800,1 );
    ReefAngel.StandardLights( Port8,20,30,11,0 );
    ReefAngel.Relay.DelayedOn( Port7,3 );
    JebaoRandomMode();
    MediaFilter();
    LEDschedule();
    WP40Delay();
    ReefAngel.Portal("ReEfnWrX","*******");
void JebaoRandomMode() {
  static unsigned long feeding;
if (now()%SECS_PER_DAY<28800 || now()%SECS_PER_DAY>=81000) { // 10pm -> 10am
  ReefAngel.PWM.SetDaylight( ElseMode(35,0,true) );   // Night mode (go to 30%)
  ReefAngel.PWM.SetActinic( ElseMode(35,0,false) );
else if (now()%SECS_PER_DAY>=28800 && now()%SECS_PER_DAY<=81000) {    //  10:30am - 10:30 pm
  static byte randMode=10;
  if (now()%SECS_PER_DAY==28800 || now()%SECS_PER_DAY==46800 || now()%SECS_PER_DAY==55800 || now()%SECS_PER_DAY==64800  || now()%SECS_PER_DAY==73800) randMode=random(1,11);
  if (randMode==1) {
    ReefAngel.PWM.SetDaylight( SineMode(35,60,85,true) );
    ReefAngel.PWM.SetActinic( SineMode(35,60,85,false) );    // Sine 40-75
  }  if (randMode==2) {
    ReefAngel.PWM.SetDaylight( ElseMode(50,15,true) );              // Else 40-80
    ReefAngel.PWM.SetActinic( ElseMode(50,15,false) );
  }  if (randMode==3) {
    ReefAngel.PWM.SetDaylight( TidalSwellMode(60,true) );               // Tidal 80
    ReefAngel.PWM.SetActinic( TidalSwellMode(60,false) );
  }  if (randMode==4) {
    ReefAngel.PWM.SetDaylight( LongPulseMode(35,55,60,true) );   // Long 25-65
    ReefAngel.PWM.SetActinic( LongPulseMode(35,55,60,false) );
  }  if (randMode==5) {
    ReefAngel.PWM.SetDaylight( ReefCrestMode(50,20,true) );                   // Reef 45-65
    ReefAngel.PWM.SetActinic( ReefCrestMode(50,20,false) );
  }  if (randMode==6) {
    ReefAngel.PWM.SetDaylight( SineMode(32,55,180,true) );                        // Sine 30-70
    ReefAngel.PWM.SetActinic( SineMode(32,55,180,false) );
  }  if (randMode==7) {
    ReefAngel.PWM.SetDaylight( ElseMode(60,10,true) );              // Else 35-65
    ReefAngel.PWM.SetActinic( ElseMode(60,10,false) );
  }  if (randMode==8) {
    ReefAngel.PWM.SetDaylight( TidalSwellMode(65,true) );               // Tidal 80
    ReefAngel.PWM.SetActinic( TidalSwellMode(65,false) );
  }  if (randMode==9) {
    ReefAngel.PWM.SetDaylight( LongPulseMode(35,60,900,true) ); // Long 40-50
    ReefAngel.PWM.SetActinic( LongPulseMode(35,60,900,false) );
  }  if (randMode==10) {
    ReefAngel.PWM.SetDaylight( ReefCrestMode(40,10,true) );                  // Reef 35-55
    ReefAngel.PWM.SetActinic( ReefCrestMode(40,10,false) );
      feeding=now();
      ReefAngel.PWM.SetDaylight( LongPulseMode(0,40,10,false) );
      ReefAngel.PWM.SetActinic( LongPulseMode(0,65,10,false) );
if (now()%SECS_PER_DAY>=34200 && now()%SECS_PER_DAY<43200) {
    ReefAngel.PWM.SetDaylight( NutrientTransportMode(0,70,400,false) );
    ReefAngel.PWM.SetActinic( NutrientTransportMode(0,80,400,false) );
void MediaFilter() {
// if  ((now()%SECS_PER_DAY>=34200 && now()%SECS_PER_DAY<=46800) || (now()%SECS_PER_DAY>=79200 && now()%SECS_PER_DAY<=86399))  {
if  (now()%SECS_PER_DAY>=36000 && now()%SECS_PER_DAY<=48600) {
else ReefAngel.Relay.Off( Port6 );
void LEDschedule() {
////////// LED Dimming Acclimation Cycle and your standard LED schedule
////////// Variables used for all channels
  byte acclDay = InternalMemory.read(Mem_B_AcclDay);            // What day in the acclimation cycle it is
  byte acclDuration = InternalMemory.read(Mem_B_AcclDuration);  // Acclimation Duration in days
  byte startPercent = InternalMemory.read(Mem_B_SlopeStart);    // Normal start% being used by all 3 channels
////////// Blue Channel Variables
  byte acclStartEndBlue = InternalMemory.read(Mem_B_AcclStartEndBlue); // Starting End% for Acclimation cycle
  float acclendPercentBlue = InternalMemory.read(Mem_B_SlopeEndBlue);  // Your target Blue end% once acclimation is complete
////////// Blue Channel Formula
  float acclPercentPerDayBlue = (acclendPercentBlue - acclStartEndBlue) / acclDuration;  // How much your Blue end% rises per acclimation day
  float acclFactorBlue = acclDay * acclPercentPerDayBlue;      // endPercentBlue will be offset by this much. If acclDay = 0 then this value will be 0
  byte endPercentBlue = acclendPercentBlue - acclFactorBlue;   // Your final Blue end% for the day
////////// White Channel Variables
  byte acclStartEndWhite = InternalMemory.read(Mem_B_AcclStartEndWhite);  // Starting End% for Acclimation cycle
  float acclEndPercentWhite = InternalMemory.read(Mem_B_SlopeEndWhite);   // Your target White end% once acclimation is complete
////////// White Channel Formula
  float acclPercentPerDayWhite= (acclEndPercentWhite - acclStartEndWhite) / acclDuration;  // How much your White end% rises per acclimation day
  float acclFactorWhite = acclDay * acclPercentPerDayWhite;      // endPercentWhite will be offset by this much. If acclDay = 0 then this value will be 0
  byte endPercentWhite = acclEndPercentWhite - acclFactorWhite;
////////// Your standard PWM Dimming code using the variables above to determine start% and end%
  ReefAngel.PWM.SetChannel( 2, PWMParabola(9,0,22,0,startPercent,endPercentBlue,0) ); // BLUE Right
  ReefAngel.PWM.SetChannel( 3, PWMParabola(9,30,22,30,startPercent,endPercentBlue,0) ); // BLUE Left
  ReefAngel.PWM.SetChannel( 1, PWMParabola(10,0,21,0,startPercent,endPercentWhite,0) ); // White Right
  ReefAngel.PWM.SetChannel( 0, PWMParabola(10,30,21,30,startPercent,endPercentWhite,0) ); // White Left
////////// At the end of the day, we need to decrement the acclimation counter.
  static boolean acclCounterReady=false; // We need a boolean so we only do this once per day
  if (now()%SECS_PER_DAY!=0) acclCounterReady=true; // If it's not midnight we'll get the boolean ready
  if (now()%SECS_PER_DAY==0 && acclCounterReady && acclDay>0) { // It's midnight, our bool is true and acclDay is more than 0
  acclDay--; // Reduce the counter
  acclCounterReady=false; // Reset the boolean flag
  InternalMemory.write(Mem_B_AcclDay,acclDay); // Update memory
void WP40Delay() {
static unsigned long lastPortOff=now()-180;
static boolean lastPortStatus=true;
if (!lastPortStatus && ReefAngel.Relay.Status(Port3))
  lastPortOff=now();
lastPortStatus=ReefAngel.Relay.Status(Port3);
ReefAngel.Relay.Set(Port7,now()-lastPortOff>180);
////////// Static's only initialize the first time they are called
  static unsigned long LastChange=millis();        // Set the inital time that the last change occurred
  static int Delay = random(2000,3000);           // Set the initial delay - default 500, 3000
  static int NewSpeed = MidPoint;                  // Set the initial speed
  static int AntiSpeed = MidPoint;                 // Set the initial anti sync speed
  if ((millis()-LastChange) > Delay)               // Check if the delay has elapsed
    Delay=random(2000,10000);                        // If so, come up with a new delay - default - 500, 5000
    int ChangeUp = random(Offset);                 // Amount to go up or down
    if (random(100)<50)                            // 50/50 chance of speed going up or going down
    LastChange=millis();                           // Reset the time of the last change
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
ReEfnWrX
Re: ReEfnWrX's INO
Post by ReEfnWrX »
////// Notes
/// Parabola
/// NTM
/// CarbPhos
//// Changes made in this version
/// Switch WP40 to port 6
/// Increase Pump Speeds
/// Add default blue/White value
/// Change pump modes
    ReefAngel.FeedingModePorts = Port3Bit | Port5Bit;
    ReefAngel.WaterChangePorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port7Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port7Bit;
ReefAngel.CustomLabels[4]="ATO";
ReefAngel.CustomLabels[5]="WP40";
ReefAngel.CustomLabels[6]="CarbPhos";
    ReefAngel.StandardLights( Port2,10,0,22,0 );
    ReefAngel.StandardLights( Port4,11,0,21,0 );
    ReefAngel.Relay.DelayedOn( Port6,3 );
    JebaoRandomMode();
    MediaFilter();
    LEDschedule();
    WP40Delay();
    ReefAngel.Portal("ReEfnWrX","**********");
      feeding=now();
      ReefAngel.PWM.SetDaylight( LongPulseMode(0,45,10,false) );
else if (now()%SECS_PER_DAY>=34200 && now()%SECS_PER_DAY<43200) { // 9:30am - 12pm
else if (now()%SECS_PER_DAY<28800 || now()%SECS_PER_DAY>=81000) { // 10:30pm -> 8am
    ReefAngel.PWM.SetDaylight( ReefCrestMode(40,10,false) );      // Reef 40-80
else if (now()%SECS_PER_DAY>=28800 && now()%SECS_PER_DAY<=81000) {    //  8am - 10:30 pm
  static byte randMode=3;
  if (now()%SECS_PER_DAY==28800 || now()%SECS_PER_DAY==43200 || now()%SECS_PER_DAY==48600 || now()%SECS_PER_DAY==54000  || now()%SECS_PER_DAY==59400 || now()%SECS_PER_DAY==64800 || now()%SECS_PER_DAY==70200 || now()%SECS_PER_DAY==75600 || now()%SECS_PER_DAY==81000) randMode=random(1,6);
//                        8am                          12pm                         1:30pm                       3pm                           4:30pm                       6pm                          7:30pm                       9pm                          10:30pm
    if (randMode==1) {
    ReefAngel.PWM.SetDaylight( SineMode(35,80,85,false) );
    ReefAngel.PWM.SetActinic( SineMode(35,80,85,false) );        // Sine 35-90
    ReefAngel.PWM.SetDaylight( ElseMode(60,20,false) );           // Else 50-90
    ReefAngel.PWM.SetActinic( ElseMode(60,20,false) );
    ReefAngel.PWM.SetDaylight( TidalSwellMode(80,false) );        // Tidal 75
    ReefAngel.PWM.SetActinic( TidalSwellMode(80,false) );
    ReefAngel.PWM.SetDaylight( LongPulseMode(40,80,60,false) );   // Long 30-80
    ReefAngel.PWM.SetActinic( LongPulseMode(40,80,60,false) );
    ReefAngel.PWM.SetDaylight( ReefCrestMode(60,15,false) );      // Reef 40-80
    ReefAngel.PWM.SetActinic( ReefCrestMode(60,15,false) );
else ReefAngel.Relay.Off( Port7 );
  byte defaultpercentblue;
if (now()%SECS_PER_DAY>36000 & now()%SECS_PER_DAY<79200) { // 10am -> 10pm
defaultpercentblue=0;
else if (now()%SECS_PER_DAY<36000 || now()%SECS_PER_DAY>79200) { // 10pm -> 10am
defaultpercentblue=13;
byte defaultpercentwhite;
  if (now()%SECS_PER_DAY>39600 & now()%SECS_PER_DAY<75600) { // 11am -> 9pm
  defaultpercentwhite=0;
else if (now()%SECS_PER_DAY<39600 || now()%SECS_PER_DAY>75600) { // 9pm -> 11am
defaultpercentwhite=13;
  ReefAngel.PWM.SetChannel( 2, PWMParabola(10,0,22,0,startPercent,endPercentBlue,defaultpercentblue) ); // BLUE Right
  ReefAngel.PWM.SetChannel( 3, PWMParabola(10,0,22,0,startPercent,endPercentBlue,defaultpercentblue) ); // BLUE Left
  ReefAngel.PWM.SetChannel( 1, PWMParabola(11,0,21,0,startPercent,endPercentWhite,defaultpercentwhite) ); // White Right
  ReefAngel.PWM.SetChannel( 0, PWMParabola(11,0,21,0,startPercent,endPercentWhite,defaultpercentwhite) ); // White Left
void WP40Delay() {
  lastPortOff=now();
ReefAngel.Relay.Set(Port6,now()-lastPortOff>180);
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
ReEfnWrX
Re: ReEfnWrX's INO
Post by ReEfnWrX »
So, I have code that randomly selects different modes at set times in the day... My WP's are dimmed by my Actinic/Daylight channels.
I just noticed that whenever I override Port 8 to turn on... My Daylight/Actinic ports get overridden to 35%???????
Port 8 is a std light port... Can anyone tell me why this is happening?
Re: ReEfnWrX's INO
Thats what the lights on port does. Think 35 is in memory somewhere. Check your setup function.
ReEfnWrX
Re: ReEfnWrX's INO
Post by ReEfnWrX »
I was not using Lights on, I was turning on the individual port by itself.
Re: ReEfnWrX's INO
My understanding is that when you turn on one of the ports in the LightsOn definition, then it will set the dimming channels to a specified percentage. I could be wrong though...
Re: ReEfnWrX's INO
Yes, you are correct.
ReEfnWrX
Re: ReEfnWrX's INO
Post by ReEfnWrX »
Ah, well that certainly explains it. Thank you both!
Re: ReEfnWrX's INO
Roberto, where would that default % get set? and where is that overriden, I can't find it?
I had thought that my assumption was wrong after looking closer at the code.
Re: ReEfnWrX's INO
Inside ReefAngel.cpp:
	if (LightRelayOn && LightsOverride)
		PWM.SetActinic(InternalMemory.LEDPWMActinic_read());
		PWM.SetDaylight(InternalMemory.LEDPWMDaylight_read());
Re: ReEfnWrX's INO
Ahh ok. that makes sense nothing about LightsOnPorts in that code block.
Re: ReEfnWrX's INO
There is a check some likes up:
	for (int l=0;l<8;l++)
		if (LightsOnPorts & 1<<l)
			if (ReefAngel.Relay.RelayMaskOn & 1<<l) LightRelayOn=true;
Re: ReEfnWrX's INO
Ahh ok.
So the best way to disable this behavior from what I found would be to define
ReefAngel.PWM.LightsOverride = false;
Re: ReEfnWrX's INO
Yes, that was the idea, but I'm not sure if we ever made that work as intended.
