Wifi help
nevets9333
Wifi help
I got my wifi attachment when I ordered the RA and set it up, everything was working fine. I have had it for a couple weeks. A couple of days ago it just stopped working. The green light was still a slow blink as if everything was fine, but it wouldn't let me connect from home or away anymore. I tried to set it up again through the wifi utility, but now I can't get it to work at all. It says false on the first 3 lines. What could have caused it to stop working? I haven't changed any of the settings since it was originally set up. Please help!
- cosmith71
Re: Wifi help
Have you tried a re-boot?
nevets9333
Re: Wifi help
Do you mean just unplug and plug back in?
- cosmith71
Re: Wifi help
Yup.
- Contact:
Re: Wifi help
sometimes my wifi module gets "stuck". i just unplug it from my controller and plug it back in and it works fine. doesn't happen all the time, but happens from time to time.
Christo
Re: Wifi help
Yip!! Happens to me too!! Just unplug and plug it back in!!binder wrote:sometimes my wifi module gets "stuck". i just unplug it from my controller and plug it back in and it works fine. doesn't happen all the time, but happens from time to time.
nevets9333
Re: Wifi help
I tried that, but no luck. After 10 secs it came back to the slow blink of the green light. I go to the portal and get
Connection Status:
Unreachable Address
Connection Status:
Unreachable Address
Re: Wifi help
Maybe the IP address changed? If you're getting slow green blinks then your connected...
