Turn on relay when WL is at 100% or >?
This is probably simple for you guys.
I want to turn port 3 on thee main Relay on for 1 hour when WaterLevel 1 of the multi sensor is at 100% or above.
I think this is the basis for it, but I don't know know how to have it turn off after 1 hour.
if (ReefAngel.WaterLevel.GetLevel(1)>=100) ReefAngel.Relay.On(Port3);
Thanks for your help.
89delta
Re: Turn on relay when WL is at 100% or >?
Post by 89delta »
That looks about right. Not sure if you would need an Else statement in there or not also. I know from reading analog or digital pins i've added it.
What you posted will keep the port on as long as the value is equal or above 100. As soon as it does not meet that criteria, it will not keep turning it on. You would want to put in an else statement to turn it off and also add in a timer to ensure that it shuts off after your specified time frame. You will also want to have a failsafe to prevent it from getting reactivated after the 1 hour time delay occurs.
that should be able to get you going in the right direction and maybe give you some tips for your coding. i'm sure others will be able to help more.
What I put will just turn the port on indefinitely, there needs to be something that will turn it off after 1hr.
binder wrote:What you posted will keep the port on as long as the value is equal or above 100. As soon as it does not meet that criteria, it will not keep turning it on. You would want to put in an else statement to turn it off and also add in a timer to ensure that it shuts off after your specified time frame. You will also want to have a failsafe to prevent it from getting reactivated after the 1 hour time delay occurs.
Curt;
I agree with you.
I just have no idea how to code it.
Basically what I want to do is one I refill my ATO reservoir (either manually now or automatically in the future) I want the pump inside the reservoir to turn on for 1 hr (may change that later) to stir up and mix the Kalwasser that is either on the bottom of the reservoir that did not dissolve last time because it was above the saturation point or new Kalkwasser that I add to replenish what has been used up.
time_t stopTime = 0;
if (ReefAngel.WaterLevel.GetLevel(1)<=100) stopTime=now()+3600;
if (stopTime-now() < 3600) { ReefAngel.Relay.On(Port3); } else ReefAngel.Relay.Off(Port4); }
You just may want a flag to set the stopTime... But essentially above is what you want..i believe
Thanks Lee.
I think that is what I want.
Basically the way I read it is if the Water Level is 100% or greater to turn on port 3 and start a 3600 (or 1 hr timer).
The stop time is checking if it is less then 3600 seconds or over and it will either leave port 3 on or turn off what I assume to be Port3 not Port4. Correct?
if (stopTime-now() < 3600) { ReefAngel.Relay.On(Port3); } else ReefAngel.Relay.Off(Port3); }
I tried adding that code to the loop section right before my Auto Feeder code and it seems to be conflicting something.
I get the following error...
expected unqualified-id before 'if'
Here is my code...
#include <Wire.h>fF
#include <RA_NokiaLCD.h>f
// Define Relay Ports by Name
#define Actinic_Lights     1
#define Day_Lights         2
#define Unused             3
#define Pumps              4
#define Sump_Fan           5
#define DeNit_Doser        6
#define DeNit_Pump         7
#define ATO_Pump           8
#define Unused             Box1_Port1
#define Feeder             Box1_Port2
#define Unused             Box1_Port3
#define Unused             Box1_Port4
#define Unused             Box1_Port5
#define Unused             Box1_Port6
#define Unused             Box1_Port7
#define Dummy              Box1_Port8
// Does not need to be global.
// unsigned long ATOUpdate=0;
ReefAngel.WaterChangePortsE[0] = Port1Bit;
//Set Standard Menu
ReefAngel.AddStandardMenu();
ReefAngel.DCPump.ActinicChannel=Sync; // Now you're pump will be affected by the portal settings.
ReefAngel.DCPump.DaylightChannel=AntiSync; // Now you're pump will be affected by the portal settings.
ReefAngel.Relay.On( Pumps );
ReefAngel.Relay.On( Dummy );
  ReefAngel.StandardLights( Actinic_Lights,12,0,22,0 );
  ReefAngel.StandardLights( Day_Lights,13,0,21,0 );
  ReefAngel.StandardLights( Sump_Fan,13,0,21,0 );
  ReefAngel.WaterLevelATO(ATO_Pump,720,28,31);
  if ( hour()>=13 && hour()<21 )
  ReefAngel.PWM.SetChannel( 5, 0 );
  ReefAngel.PWM.SetChannel( 5, PWMSlope(21,0,13,0,0,MoonPhase() ,60,0) );
  //AutoFeeder
static unsigned long autofeeding = 0;
if ((now()%SECS_PER_DAY==64800)) //if it is 6 pm
ReefAngel.FeedingModeStart(); //START FEEDING MODE
if ( autofeeding == 0 ) {
autofeeding = now(); //set the time of the start of feeding to variable feeding
if ((now()-autofeeding>=60) && (now()-autofeeding<=61)) //if between 60 and 61 seconds has past
ReefAngel.Relay.On(Feeder); //TURN FEEDER RELAY ON
ReefAngel.Relay.Off(Feeder); //TURN FEEDER RELAY OFF
} else {
if ( autofeeding > 0 ) {
autofeeding = 0;
  // DeNitrate Routine
int DeNit_Offset=3600;
int DeNit_Repeat=21600;
int DeNit_Doser_Offset=1200;
int DeNit_Doser_Runtime=600;
int DeNit_Pump_Runtime=1200;
int DeNit_ATO_Offtime=1500;
// Pump comes on first
ReefAngel.Relay.Set(DeNit_Pump,(now()-DeNit_Offset)%DeNit_Repeat<DeNit_Pump_Runtime);  // Runs denitrator pump
// Doser comes on second
ReefAngel.Relay.Set(DeNit_Doser,((now()-DeNit_Offset)-DeNit_Doser_Offset)%DeNit_Repeat<DeNit_Doser_Runtime); // Runs denitrator doser
  // Disable ATO
if ( (now()-3600)%21600<DeNit_ATO_Offtime) ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);
  // Delay WL ATO after water change and DeNit_Dosing
  static time_t wcTimer=0;
  if (ReefAngel.DisplayedMenu == WATERCHANGE_MODE) wcTimer=now();
  // First 10 minutes after WC disable ATO
  if (now()-wcTimer >= 0 && now()-wcTimer < 600)
    // Track Salinity low duration
    static unsigned long lastGoodSal;
    static boolean lowSalFlag;
    // Salinity is good, update counter
    if (ReefAngel.Params.Salinity>=335) lastGoodSal=now();
    // Counter hasn't been updating in 300 seconds..
    if (now()-lastGoodSal>300) {
      lowSalFlag=true; // Salinity is definitely below 33.5
    } else {
      lowSalFlag=false; // Salinity back to normal
    // Disable ATO if lowSalFlag is true
    if (lowSalFlag) ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);
  // Disable ATO if ATO High IsActive()
// Add random mode if we set to Mode to Custom in portal
static int rmode;
// Add Else Mode definition..
const int Else=16;
byte modes[] = { ReefCrest, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else };
if (now()%SECS_PER_DAY==0 || changeMode==true) { // Change at midnight or if controller rebooted
rmode=random(100)%sizeof(modes); // Change the mode once per day to pick from our array
changeMode=false;
static unsigned long feeding;
if (now()-feeding<3600) {
  // Continue NTM for the 60 minutes
  ReefAngel.DCPump.Mode=NutrientTransport;
} else if (now()%SECS_PER_DAY<43200 || now()%SECS_PER_DAY>=79200) { // 12pm / 10pm
  // Night mode (go to 30%)
  ReefAngel.DCPump.Mode=Constant;
  ReefAngel.DCPump.Speed=30;
} else if (InternalMemory.DCPumpMode_read()==11) {
  if (modes[rmode]==Else) {
    ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),20,true );    // ElseMode on sync mode, Portal Speed Setting +/- 20%
  } else {
    ReefAngel.DCPump.Mode=modes[rmode];  // Put the mode to the random mode :)
} else {
  ReefAngel.Portal( "Sacohen","xxxxxxxx );
int x,y;
// Parameters
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,57, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,57, ReefAngel.WaterLevel.GetLevel() );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,66,66, "WL 1:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, ReefAngel.WaterLevel.GetLevel(1) );
//Salinity
  strcat(text,"  ");
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,39,75,"Salinity:");
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,99,75,text);
// Main Relay Box
ReefAngel.LCD.DrawOutletBox(12, 104, TempRelay);
// Date and Time
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
lnevo wrote:time_t stopTime = 0;
Lee;
Is the time_t stop Time function in the 1.1.0 libraries or were they pur into the 1.1 1 libraries?
Replace it with static unsigned long. Forgot to put the static in before. And i think for the test you just want to do see if now()<stopTime
You just need to protect the assignment of stopTime to make sure its only run once or it will contnue updating as long as the reservoir is full.
This is what I put in and I'm still getting the same error message...
static unsigned long Kalk_Mixing = 0;
Error message is ...
The error is not in that code IMO. Try going back...
And theres still logic errors there, let me write you up something more comprehensive tomorrow.
The error is not in that code.
It comes up in the next line of code for my Auto Feeder. The part I may Blue.
//Mix Kalkwasser
//AutoFeeder
} else {
autofeeding = 0;
Ok, the error is in my code
to
if (stopTime-now() < 3600) { ReefAngel.Relay.On(Port3); } else { ReefAngel.Relay.Off(Port3); }
But here's your better code :
//Mix Kalkwasser
static unsigned long stopTime = 0;
static byte prevWL=0;
if (ReefAngel.WaterLevel.GetLevel(1)>=100 && preWL<100) {
  stopTime=now()+3600; // Get time one hour from now.
prevWL = WaterLevel.GetLevel(1); // Store the water level
if (now() < 3600) { ReefAngel.Relay.On(Port3); } else { ReefAngel.Relay.Off(Port3); }
//AutoFeeder
} else {
autofeeding = 0;
I added a variable for the previous water level to help make sure this only runs once it's been filled. Hopefully it works.
Thanks. I'll try it tonight.
Lee;
I just tried the code you put up yesterday and the error message I'm getting now is...
'preWL' was not declared in this scope
but I see static byte prevWL=0; in the code.
I tried it as static byte prevWL = 0; and got the same message.
Because the error is preWL without the V... I made a typo somewhere else...
Change this:
to
if (ReefAngel.WaterLevel.GetLevel(1)>=100 && prevWL<100) {
Now I'm getting 'WaterLevel' was not declared in this scope.
The line in Blue is the one that is highlighted...
//Mix Kalkwasser
if (now() < 3600) { ReefAngel.Relay.On(Kalkwasser); } else { ReefAngel.Relay.Off(Kalkwasser); }
I changed it to this and it compiled with now errors.
Is this the way it should be?
prevWL = ReefAngel.WaterLevel.GetLevel(1); // Store the water level
It doesn't seem to be working.
I have the ATO reservoir filled and I re-calibrated the sensor because even full it was reading 95%
It's now reading 100% on the RA menu and on my phone, but is reading 0 on the Portal and Port3 has not turned on.
Yes you got the code right. Here's the scenario. The water level needs to be below the 100 percent mark and then hit 100 and it will then set stopTime to 3600 seconds in the future. Also found and error. it should be now()<stopTime not 3600. Carryover from the initial example. Sorry for always clutzing up on you. I code on my phone...
That looks like it did it after I fixed that last coding issue.
No problem with the mess ups, I just appreciate the help.
Besides I did figured some things (well 1) out on my own.
I'm starting to pick this up, but still have a long way to go.
Sacohen wrote:That looks like it did it after I fixed that last coding issue.
no worries there. it is a continuous learning experience. i even have issues at times too! :-)
glad you were able to get things figured out.
Thanks. Curt. It was Lee that did it, but I was proud that I was able to figure out what was wrong when he mis-coded something. That's 1000x better then when I started in here.
The final working code is...
//Mix Kalkwasser
if (now() < stopTime) { ReefAngel.Relay.On(Kalkwasser); } else { ReefAngel.Relay.Off(Kalkwasser); }
Lee thanks again for this code.
There seems to be some problems with it still.
When the Water Level reaches 0 the Kalkwasser pump (Port4) turns on.
That shouldn't happen because there is not enough water in the Reservoir to have it run without cavitating.
Also when the water is below 0 or at 0 for too long it starts reporting the WL at 200%.
This is not problem with the code I think it's an issue with the design of the WL sensors or when the ATO pulls more water and actually falls below the calibrated 0 level.
This causes another problem with the line of code that says and previous WL is less than 100, because it doesn't stay at less than 100.
I tried changing the code to equal to 100 and got "value required as left operand of assignment"
if (ReefAngel.WaterLevel.GetLevel(1)=100 && prevWL<100) {
You need == that causes the error you had.
Its an issue with the water level sensor code. I'll have to check but yeah it wraps around to 200...and at 0 its probably jumping to 200 where you can't see it.
OK. That did it.
I don't think it's jumping to 200% right away, but that would make sense because it gets to 0, jumps to 200 and turn on the port since it is above 100 like the code says to.
That 200% thing is going to cause an issue since it will not start the hour stirring process if the last level was not below 100.
This is the first step in automating my RO/DI and SW container refills.
My thought was when WL reaches 0% the RO/DI water turns on and starts filling whichever reservoir is low and calling for it to be turned on.
When it reaches 100% it shuts of the RO/DI maker and turns on the pump for an hour (Maybe 2 for the SW) and then the water in each reservoir is ready to use.
Obviously I would try to build in something that disables the ATO or AWC while the reservoir is refiling and mixing.
I would not start anything at the 0% mark :) i'd even suggest recalibrating so that 0% has some amount of liquid in it. But yeah it's like debouncing any other sensors, you may not see it because the screen refreshes every 5 seconds i believe but the sensor definitely has some bounce in it so it could be bouncing to 200 and you wouldnt se it necessarily. We need to fix that part. Maybe need to change the result to an int so we can get a negative percent.
Another thing we can do is read the raw value from the sensor and check if we're lower than the calibrated minimum...i'm not sure that function exists, but I've wanted it a few times...
