Controllable Automatic Fish Feeder?
paperdesk
I was in the process of purchasing an automatic fish feeder to use when I go on vacation, and happened across the Apex Auto Feeding Station. It looks amazing, however, it got me to wondering: Why pay for electronics in a feeder I already have a RA?
Isn't there a simple feeder that could be actuated by the RA? Anyone have a success story?
Ted
Ted
Re: Controllable Automatic Fish Feeder?
You can try one of these:
http://www.super-feeder.com/asfmodel.html
paperdesk
Neat looking feeder, not much in terms of cost saving though.
paperdesk
I'm looking into the Super Feeder, it seems to be pretty large, not sure I have space for something that size, but I can measure when I get home. Anyone know of other options? Seems there might be a simple digital feeder you could "modify" to actuate via the dimming ports . . .
- Sacohen
People have connected the EHEIM "FEED-AIR" DIGITAL AQUARIUM FISH FEEDER to the Reef Angel.
http://www.aquacave.com/eheim-feed-air- ... 7AodbBUA6A
Here a couple of threads on it.
http://forum.reefangel.com/viewtopic.php?f=4&t=1415
http://forum.reefangel.com/viewtopic.ph ... ilit=Eheim
paperdesk
Thanks Steve, I'm reading through the posts now!Sacohen wrote:People have connected the EHEIM "FEED-AIR" DIGITAL AQUARIUM FISH FEEDER to the Reef Angel.
paperdesk
Would the Eheim Everyday Feeder work too or just the "Feed-Air"? Or possibly any feeder that has a "feed" button?
- Sacohen
Theoretically, any feeder with a feed button, but you would need to figure out the modification on it.
paperdesk
The two Eheim feeders mentioned above look almost exactly the same, but I don't know how the wiring compares. I haven't heard anyone particularly liking the air system, I'm hoping the "Everyday Feeder" would work the same.
On another note, would the Apex feeder even work with the RA?
paperdesk
Well I decided to order the "air" one in the hopes of replicating success!
The feeder that apex uses is from lifegard aquatics.
http://www.lifegardaquatics.com/product ... sh-feeder/
It's pretty simple to mod it too. All you need is a small relay to close those 2 contacts to simulate the press of the button.
paperdesk
- cosmith71
I think the "Everyday Feeder" is just a newer version/packaging of the "Feed Air". They're both model 3581.
Theres another one i've seen posts on RC for that cost like $15 on ebay. Some chinese brand that looks pretty easy to hack.
paperdesk
I ordered the eheim, but like the look of the intelli-feed. The eheim was under $30 so probably it's a better model to play with in case I toast something!
- Sacohen
I toasted my first one because I suck at soldering.
I haven't attempted it again on the 2nd one yet.
paperdesk
Yah, I'm not very good either, especially with the really small stuff. However, I'm getting better with practice, and hope I can pull this off.
- Sacohen
It' not that they are small solder point (which they are) it that they are SMD (Surface Mounted) so then tend to unsolder and slide off where they are supposed to be.
I think I melted the push button switch on my first feeder.
I was taught to solder by letting the things being soldered get hot and the put the solder on them.
Obviously SMD has to be done differently.
I think you have to tin the soldering iron and the wires you are adding to the contacts and use flux on the contacts that you are soldering to and then just touch the iron to the area to be soldered, and the solder will transfer off the iron to the area that is fluxed.
paperdesk
I'm with you on this! I just discovered the same thing on a recent project. It turned out quite nicely after I figured it out! Still, I don't feel very confident working on these kinds of things.Sacohen wrote:It' not that they are small solder point (which they are) it that they are SMD (Surface Mounted) so then tend to unsolder and slide off where they are supposed to be.
Ted
Damion
What relay would you recommend?rimai wrote:The feeder that apex uses is from lifegard aquatics.
paperdesk
A Reef Angel!Damion wrote:What relay would you recommend?rimai wrote:The feeder that apex uses is from lifegard aquatics.
Damion
Roberto, what specific relay would you recommend on the intelli-feeder?
Use something like this to be safe:
http://m.ebay.com/itm/310566336050?nav=SEARCH
Sent from my Galaxy S5 with Tapatalk
Damion
Damion
Are you shorting the output of the relay to simulate a button press or applying voltage?
- Sacohen
The way it has been done on the Ehiem Auto Feeder is we are applying 12v current to a relay that in turn is closing the connection for the feeder button and rotating the feeder chamber. Simulating a push of the button.
Damion
Thanks Steve,
I think I understand, you're using a relay to activate their relay?
- Sacohen
wideawake
I have some relays similar to this and honestly I have no idea how to wire it and program it with the RA.rimai wrote:Use something like this to be safe:
Any low level tips or links to a tutorial site would be much appreciated.
