ok, moved the ground from dimmer to -v on ps. still no success. If someone can look at my wiring to make sure everything looks ok would be great. I think my jumpers are correct for 5v pwm. Maybe I should try taking that lone jumper off to change from 40 to 41?
If everything looks ok, then I guess next step is looking at programing. Worst thing in world is thinking everything is good to go and once power is turned on, nothing happens.
It's the opposite.
You cannot use the jumper.
Jumper On = 0x41 - It will be used by the 16ch custom dimming expansion module
Jumper Off = 0x40 - To be used on the current 6ch dimming expansion module
