PaulTurner911 Code
Remove everything else from the list of options except else mode and then that will be the one that it chooses.
I'm not sure how to.
No way to call it from a memory location manually? Ok, I think I understand. Thanks |
Change this...
To this...
+1
Could someone refresh my memory on how to have Relay 6 run constant, unless Im in feed mode?
I didnt realize it but when I added the skimmer it runs on the same schedule as my MH lamps. I would like it to be on all of the time unless its in feed mode. Any help is greatly apprerciated. Thank you |
You need 2 things....
This in // Ports toggled in Feeding Mode
And then in // Ports that are always on
If you want to delay the start after feeding mode by 10 min so your main pump gets up to speed and your water leve gets back to normal you can add this in the loop section...
Great! Thank you
I HAVE PICKED UP A NEW TANK!!!
Im wondering if I should just run the wizard and start over, but cut and paste some "custom lines" ??? Please advise which would be easier. Ditching a few things - MH (port7&8) FANS (port2) ACTINIC (port3) I have a few things that Id like to add- 3 Ecoray112DX whites/red (port7) Actinics (port8) Chiller (port2) Should function similar to the fan settings? * NEEDS TO SHUT DOWN IN FEED/WATERCHANGE MODES Skimmer (port3) ** Id like it off for 2 hours after feedmode activation ANY AND ALL INPUT IS WELCOMED AND VERY APPRECIATED |
I would keep what you have and go in and manually cut out what you don't want.
Then use the wizard to create the code you want to add and paste it in to your existing code. |
Ill give it a try!! thanks
