Proofreading Jebao on ATO.....
Ask in here.
PostPosted: Sat Aug 23, 2014 6:38 pm
Hello,
I was wondering if someone who speaks code fluently :ugeek: could look this over and tell me why my 2 Jebao pumps just run full throttle? It compiles fine, and uploads fine, but they just run. Ordered the cables and requested they be modified for my ATO ports (You did do that , right Roberto? :?: ) Reef angel plus controller, lightning code, etc. If you could look this all over and let me know I would appreciate it.
Thank You,
GC
Dan
byte ActinicPWMValue=0;    // For cloud code
byte DaylightPWMValue=0;   // For cloud code
void CheckCloud()
#define Clouds_Every_X_Days 2 // Frequency in days based on the day of the month - number 2 means every 2 days, for example (day 2,4,6 etc)
#define Cloud_Chance_per_Day 65 // Percentage chance of a cloud happening today
#define Min_Cloud_Duration 7 // Minimum number of minutes for cloud duration.  Don't use max duration of less than 6
#define Max_Cloud_Duration 12 // Maximum number of minutes for the cloud duration. Don't use max duration of more than 255
#define Min_Clouds_per_Day 1 // Minimum number of clouds that can happen per day
#define Max_Clouds_per_Day 2 // Maximum number of clouds that can happen per day
#define Start_Cloud_After NumMins(12,00) // Only start the cloud effect after this setting - In this example, start cloud after noon
#define End_Cloud_Before NumMins(17,00) // Always end the cloud effect before this setting - In this example, end cloud before 9:00pm
#define Lightning_Change_per_Cloud 100 // Percentage chance of a lightning happen for every cloud - use 100 and cause the lightning to have 100% chance of happening
  // Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen results could happen.
    // Add Random Lightning modes
#define Calm 0    // No lightning
#define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4   // Like Mega, but with more lightning
  byte LightningModes[] = { Fast, Mega, Calm, Calm }; // Set which modes you want to use - Example:{ Slow, Fast, Mega, Mega2 } to randomize all four modes.
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
  static byte lightningMode=0;
  static time_t DelayCounter=millis();    // Variable for lightning timing.
  static int DelayTime=random(1000);      // Variable for lightning timimg.
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      randomSeed(millis());    // Seed the random number generator
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
      if (chooseLightning)
        chooseLightning=false;
      switch (lightningMode)
      case Calm:
        break;
      case Mega:
        // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
          int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
          for (int i=0; i<a; i++)
            analogWrite(daylightPWMPin,random(DaylightPWMValue*2.55,255));    // Flash on
            int randy=random(20,80);    // Random number for a delay
            if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
            delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
            analogWrite(daylightPWMPin,DaylightPWMValue*2.55);      // Flash off
            delay(random(30,50));                // Wait from 30 to 49 ms
            wdt_reset();
          DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
          DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
        break;
      case Mega2:
        // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
        if (lightningchance && random(ReversePWMSlope(cloudstart,cloudstart+cloudduration,100,0,180))<2 && (millis()-DelayCounter)>DelayTime)
            wdt_reset();
        break;
      case Fast:
            wdt_reset();
        break;
      case Slow:
        // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
          else lightningstatus=0;
          if (lightningstatus)
            DaylightPWMValue=100;
            DaylightPWMValue=0;
          delay(1);
        break;
      default:
        break;
      cloudindex++;
      if (cloudindex < numclouds)
      int x=0;
      else x=17;
      ReefAngel.CustomVar[3]=cloudstart/60;    // Write the hour of the next cloud to custom variable for Portal reporting
      else x=35;
      ReefAngel.CustomVar[4]=cloudstart%60;    // Write the minute of the next cloud to custom variable for Portal reporting
    ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
    if (lightningchance)
      int x=0;
      else x=57;
      ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
      else x=75;
      ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));    // Write the minute of the next lightning to a custom variable for the Portal
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
    ReefAngel.StandardLights( Port1,17,0,17,2 ); // Top Off Pump
    ReefAngel.StandardLights( Port2,19,0,19,1 ); // Drain Pump
    ReefAngel.StandardLights( Port3,19,2,19,5 ); // Fill Pump
    ReefAngel.StandardHeater( Port4,771,776 ); // Heater, Duh.
    ReefAngel.StandardFan( Port5,781,785 ); // Fan, Duh.
    ReefAngel.StandardLights( Port6,9,0,20,0 ); // Big Lights
    ReefAngel.StandardLights( Port7,8,29,20,31 ); // LED Fans
    ReefAngel.StandardLights( Port8,8,28,20,32 ); // LED Power Supply
    //Lighting Control
    ActinicPWMValue=PWMSlope(8,30,20,30,0,90,60,ActinicPWMValue);
    DaylightPWMValue=PWMSlope(9,0,20,0,0,90,45,DaylightPWMValue);
    CheckCloud();
if (hour()>=9 && hour()<17)
    pinMode(lowATOPin,OUTPUT);
    analogWrite(lowATOPin,LongPulseMode(31,60,8,true)*2.55);
    pinMode(highATOPin, OUTPUT);
    analogWrite(highATOPin,LongPulseMode(31,60,8,false)*2.55);
else if (hour()>=17 && hour()<18)
    analogWrite(lowATOPin, NutrientTransportMode(32,75,500,true)*2.55);
    pinMode(highATOPin,OUTPUT);
    analogWrite(highATOPin, NutrientTransportMode(32,75,500,false)*2.55);
    else if (hour()>=18 && hour()<9)
    analogWrite(lowATOPin,LongPulseMode(32,40,12,true)*2.55);
    analogWrite(highATOPin,LongPulseMode(32,40,12,false)*2.55);
    ReefAngel.Portal( "GiraffeCat" , "passwordgoeshere" );
.....Your forefathers wisely set aside their compassion - Steeled themselves for what needed to be done.......
PostPosted: Sun Aug 24, 2014 3:22 am
Not sure, but here's one problem:
This can never be true.
Also, you can put these lines in setup() once and be done with them. Not sure if it's a problem or not.
PostPosted: Sun Aug 24, 2014 6:07 am
OK, now that I'm awake, here's a couple of things.
Either take this line out or change it to FALSE:
Change this...
to this:
    else if (hour()>=18 || hour()<9)
I think that should do it.
PostPosted: Sun Aug 24, 2014 9:22 am
cosmith71 wrote:OK, now that I'm awake, here's a couple of things.
Change this...
to this:
Uh, why were you up so early? I am rocking the coffee at 0400 hours, but not a minute before.
Line deleted. I actually had it "false " to start with, then changed it when didn't work right.
Changed the "&&" to "||", and all is well in the realm of dragons. Thank you so much. :D :ugeek: (Roberto is off the hook on the cable mods.)
If you are ever bored and want to explain how to make the pumps go bat ship crazy during the lightning storm and then go back to normal afterwards I am game to try. (I need to get some coding school going on. Maybe next year. :( )
PostPosted: Sun Aug 24, 2014 9:30 am
[quote="GiraffeCatIf you are ever bored and want to explain how to make the pumps go bat ship crazy during the lightning storm and then go back to normal afterwards I am game to try. (I need to get some coding school going on. Maybe next year. :( )[/quote]
Had to get up early for work. :D
I've been thinking about the pump mods for the storm mode. I just don't have all the hardware to do it (namely, the dimming expansion) so I haven't put it into practice. It wouldn't be hard. I already have an "else mode" routine that would work great with a little modification.
PostPosted: Sun Aug 24, 2014 9:36 am
Btw the dev libraries which are working well at this time has both ATO ports supported by the DCPump class.
PostPosted: Sun Aug 24, 2014 9:48 am
lnevo wrote:Btw the dev libraries which are working well at this time has both ATO ports supported by the DCPump class.
Are you talking about "ReefAngel.DCPump.LowATOChannel=true" type of thing? If so, I kept getting the 'class DCPumpClass' has no member named 'LowATOChannel" issue, even with using the Dev Libraries off of github thrown in place libraries folder.
LMK,
GC
PostPosted: Sun Aug 24, 2014 10:11 am
Yes. It is definitely in there...are you sure your putting them in the right place. And the latest has support for HighATOChannel...
PostPosted: Sun Aug 24, 2014 12:23 pm
lnevo wrote:Yes. It is definitely in there...are you sure your putting them in the right place. And the latest has support for HighATOChannel...
I saw that it had it in there in the dev branch and not in 1.1, and was hoping it was going to be easy to get them working on the ATO's. Went to https://github.com/reefangel/Libraries/tree/dev,downloaded, unzipped, and swapped out the libraries folder. Saw this when I looked in DCPump.cpp:
DCPumpClass::DCPumpClass()
   UseMemory=true;
   FeedingSpeed=0;
   WaterChangeSpeed=0;
   DaylightChannel=NON;
   ActinicChannel=NON;
   LowATOChannel=NON;
   HighATOChannel=NON;
I thought it would work. It didn't. I have everything you see in the code posted at the beginning - even the things I don't need - AI,PH, ORP, Etc. Never got it to work.
I would willingly take any assistance in this coding arena. So let me know if you have anything for me to try. I am just happy that the two pumps are working as it is coded now. Two more boxes I don't need thanks to my Reef Angel, and several generous members on this forum.
Dan (GC)
PostPosted: Sun Aug 24, 2014 12:51 pm
Pretty straight forward like you said.
2 things to verify that you did download the dev tree and also make sure you restart arduino.
Next
Return to How do I code ...
