I'm currently looking at adding a controller to my system and I like the idea of an open source solution. I'm a programmer and the idea of being able to tinker with my system is very appealing.
My issue is: I'm not sure what to order / plan.
I'm hoping I can outline my setup and wish list here and see if anyone has any insight into what I need.
My tank is a Red Sea Max 250 with a lifereef overflow and 50L sump/fuge. it has a deltec mc500 skimmer and we have a vortech MP10 added to the DT. We also have an aqua ray blue led strip added to the existing 6bulb T5 lighting system that the RSM has in its hood - we use the leds to simulate a dusk and dawn period and as a supplement to the RSM moonlights.
Initially I would like to (ideally) do the following:
1 - automate my top off (at the moment we add RO to the sump almost daily).
2 - control/dim our lighting (if possible)
3 - control pumps / skimmer at feeding time etc (at the moment we have to turn off 2 circulation pumps and also the skimmer and Vortech manually)
4 - monitor and record PH (and other chemistry if possible later)
5 - dose supplements gradually
Things I don't understand or get:
1 - lighting and dimming: can we dim the T5s at all? if so.. what would we need?
2 - pumps: can the RA control my vortech pump speed?
3 - is there a dosing solution using the RA?
Any help / insight would be much appreciated
