Temp 0.0 and timeout on first line of code
imfortney
Post by imfortney »
Does anything look wrong here? I used this code for 2 days with no problems. I woke up today and temp says 0.0 so I tried to reload the code, but it times out on the first orange line of code uploading.
// Define Relay Ports by Name
#define Return_Pump 1
#define Skimmer 2
#define Kessil 3
#define Nick_WP10 4
#define unused 5
#define Steph_ATO 6
#define Refugium 7
#define Steph_WP10 8
//ReefAngel.CustomLabels[0]="ReturnPump";
//ReefAngel.CustomLabels[1]="Skimmer";
//ReefAngel.CustomLabels[2]="Kessil";
//ReefAngel.CustomLabels[3]="Nick WP10";
//ReefAngel.CustomLabels[4]="None";
//ReefAngel.CustomLabels[5]="Steph ATO";
//ReefAngel.CustomLabels[6]="Refugium";
//ReefAngel.CustomLabels[7]="Steph WP10";
#define NUMBERS_8x16
ReefAngel.LCD.DrawText(COLOR_ORANGERED, COLOR_DEEPSKYBLUE,14,8, "Fortney Money Pit");
DrawStatus (20,80);
DrawParams (5,40);
DrawParamsa (0,10);
ReefAngel.FeedingModePorts = Port2Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port6Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port3Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port4Bit | Port8Bit | Port7Bit;
ReefAngel.Relay.On( Return_Pump );
ReefAngel.Relay.On( Nick_WP10 );
ReefAngel.Relay.On( Steph_WP10 );
ReefAngel.Relay.DelayedOn( Skimmer,60 );
ReefAngel.MHLights( Kessil,8,00,20,00,1 );
ReefAngel.Relay.Set( Refugium, !ReefAngel.Relay.Status( Kessil ) );
ReefAngel.StandardATO(6, 40);
if (hour()>=8 && hour()<20)
ReefAngel.PWM.SetDaylight( ElseMode(70,30,true) ); // Else Mode at 70% +/- 30% on sync mode
else if (hour()>=20 && hour()<23)
ReefAngel.PWM.SetDaylight( NutrientTransportMode(40,80,200,true) ); // Nutrient Transport 40%minspeed - 80%maxspeed - 200ms
else if (hour()>=23 || hour()<8)
ReefAngel.PWM.SetDaylight( ElseMode(45,15,true) ); // Else Mode at 45% +/- 15% on sync mode
if (hour()>=11 && hour()<22)
ReefAngel.PWM.SetActinic( ElseMode(70,30,false) ); // Else Mode at 70% +/- 30% on anti-sync mode
else if (hour()>=22 || hour()<1)
ReefAngel.PWM.SetActinic( NutrientTransportMode(40,80,200,false) ); // Nutrient Transport 40%minspeed - 80%maxspeed - 200ms
else if (hour()>=1 && hour()<11)
ReefAngel.PWM.SetActinic( ElseMode(45,15,false) ); // Else Mode at 45% +/- 15% on anti-sync mode
ReefAngel.Portal( "imFortney" );
void DrawParamsa(int x, int y){
char buf[16];
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,x+40,y+10,"Steph:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, x+78, y+10,1);
ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+40,y+20,"Nick:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),APColor, x+78, y+20,1);
void DrawParams(int x, int y) {
char buf[16];
ReefAngel.LCD.DrawText(COLOR_INDIGO,DefaultBGColor,x+5,y,"Temp:");
ReefAngel.LCD.DrawText(COLOR_INDIGO,DefaultBGColor,x+80, y, "PH:");
// Temp and PH
y+=10;
y+=5;
void DrawStatus(int x, int y) {
int t=x;
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,15,y,"High",Font8x16);
ReefAngel.LCD.DrawLargeText(COLOR_ORANGERED,DefaultBGColor,85,y,"Low",Font8x16);
ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_INDIGO);
} else {
ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_ORANGERED);
ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_ORANGERED);
} else {
ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_INDIGO);
if (WaveSync)
return NewSpeed;
return AntiSpeed;
Thanks guys
Re: Temp 0.0 and timeout on first line of code
Bad temp sensor? Try unplugging the temp sensor and see if it uploads.
imfortney
Post by imfortney »
unplugging the temp sensor was my first try. now i have unplugged everything and it is being powered by the usb cable. i got the error message that it set.
Watchdog Timer
Version Menu
Dimming Signal
Date/Time Setup Menu
Standard Menu
Binary sketch size: 41,188 bytes (of a 258,048 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM4 -b115200 -D -V -Uflash:w:C:\Users\Owner\AppData\Local\Temp\build2718938394513701128.tmp\RA_Preloaded.cpp.hex:i
avrdude: Version 6.0, compiled on Apr  6 2012 at 19:29:19
         Copyright (c) 2000-2005 Brian Dean,
         Using Port                    : \\.\COM4
         Using Programmer              : stk500v2
         Overriding Baud Rate          : 115200
avrdude: Recv:
avrdude done.  Thank you.
now i am going to leave it unplugged overnight i guess. and try reprogramming in the am. Any suggestions?
thanks
Are you sure that the COM4 port is the one?
imfortney
Post by imfortney »
yes, com3 says cannot communicate with device. com4 reboots the unit tries to start uploading code and fails.
imfortney
Post by imfortney »
i was excited for a second it started to go...
Watchdog Timer
Version Menu
Dimming Signal
Standard Menu
avrdude: Recv: . [1b]
avrdude: Recv: . [01]
avrdude: Recv: . [00]
avrdude: Recv: . [0b]
avrdude: Recv: . [0e]
avrdude: Recv: . [08]
avrdude: Recv: A [41]
avrdude: Recv: V [56]
avrdude: Recv: R [52]
avrdude: Recv: I [49]
avrdude: Recv: S [53]
avrdude: Recv: P [50]
avrdude: Recv: _ [5f]
avrdude: Recv: 2 [32]
avrdude: Recv: t [74]
avrdude: stk500v2_getsync(): found AVRISP programmer
         AVR Part                      : ATMEGA2560
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
           flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500V2
         Description     : Atmel STK500 Version 2.x firmware
         Programmer Model: AVRISP
avrdude: Send: . [1b] . [02] . [00] . [02] . [0e] . [03] . [90] . [86]
avrdude: Recv: . [02]
avrdude: Recv: . [03]
avrdude: Recv: . [0f]
avrdude: Recv: . [18]
avrdude: Send: . [1b] . [03] . [00] . [02] . [0e] . [03] . [91] . [86]
avrdude: Recv: . [14]
avrdude: Send: . [1b] . [04] . [00] . [02] . [0e] . [03] . [92] . [82]
avrdude: Recv: . [04]
avrdude: Recv: . [0a]
         Hardware Version: 15
         Firmware Version Master : 2.10
avrdude: Send: . [1b] . [05] . [00] . [02] . [0e] . [03] . [94] . [85]
avrdude: Recv: . [05]
avrdude: Recv: . [10]
         Vtarget         : 0.0 V
         SCK period      : 0.1 us
avrdude: Send: . [1b] . [06] . [00] . [0c] . [0e] . [10] . [c8] d [64] . [19]   [20] . [00] S [53] . [03] . [ac] S [53] . [00] . [00] 5 [35]
avrdude: Recv: . [06]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: . [1b] . [07] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] 0 [30] . [00] . [00] . [00] 7 [37]
avrdude: Recv: . [07]
avrdude: Recv: . [1d]
avrdude: Recv: 0 [30]
avrdude: Recv: . [1e]
avrdude: Recv: & [26]
avrdude: Send: . [1b] . [08] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] 0 [30] . [00] . [01] . [00] 9 [39]
avrdude: Recv: . [98]
avrdude: Recv: . [af]
################avrdude: Send: . [1b] . [09] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] 0 [30] . [00] . [02] . [00] ; [3b]
avrdude: Recv: . [09]
avrdude: Recv: 7 [37]
################################## | 100% 0.05s
avrdude: Device signature = 0x1e9801
avrdude: Send: . [1b] . [0a] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] . [a0] . [0f] . [fc] . [00] Y [59]
avrdude: Recv: . [a0]
avrdude: Recv: . [a5]
avrdude: Send: . [1b] . [0b] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] . [a0] . [0f] . [fd] . [00] Y [59]
avrdude: Recv: . [a4]
avrdude: Send: . [1b] . [0c] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] . [a0] . [0f] . [fe] . [00] ] [5d]
avrdude: Recv: . [0c]
avrdude: Recv: . [a3]
avrdude: Send: . [1b] . [0d] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] . [a0] . [0f] . [ff] . [00] ] [5d]
avrdude: Recv: . [0d]
avrdude: Recv: . [a2]
avrdude: reading input file "C:\Users\Owner\AppData\Local\Temp\build2718938394513701128.tmp\RA_Preloaded.cpp.hex"
avrdude: writing flash (41188 bytes):
Writing | avrdude: Send: . [1b] . [0e] . [00] . [05] . [0e] . [06] . [80] . [00] . [00] . [00] . [98]
avrdude: Recv: . [1f]
avrdude: Send: . [1b] . [0f] . [01] . [0a] . [0e] . [13] . [01] . [00] . [c1] . [0a] @ [40] L [4c]   [20] . [00] . [00] . [9d] . [c4] . [00] . [00] . [c8] . [c4] . [00] . [00] . [c6] . [c4] . [00] . [00] . [c4] . [c4] . [00] . [00] . [c2] . [c4] . [00] . [00] . [c0] . [c4] . [00] . [00] . [be] . [c4] . [00] . [00] . [bc] . [c4] . [00] . [00] . [ba] . [c4] . [00] . [00] . [0c] . [94] . [bc] + [2b] . [b6] . [c4] . [00] . [00] . [b4] . [c4] . [00] . [00] . [b2] . [c4] . [00] . [00] . [b0] . [c4] . [00] . [00] . [ae] . [c4] . [00] . [00] . [ac] . [c4] . [00] . [00] . [aa] . [c4] . [00] . [00] . [a8] . [c4] . [00] . [00] . [a6] . [c4] . [00] . [00] . [a4] . [c4] . [00] . [00] . [a2] . [c4] . [00] . [00] . [a0] . [c4] . [00] . [00] . [9e] . [c4] . [00] . [00] . [0c] . [94] . [c1] B [42] . [9a] . [c4] . [00] . [00] . [0c] . [94] . [03] F [46] . [0c] . [94] + [2b] G [47] . [94] . [c4] . [00] . [00] . [92] . [c4] . [00] . [00] . [90] . [c4] . [00] . [00] . [8e] . [c4] . [00] . [00] . [8c] . [c4] . [00] . [00] . [8a] . [c4] . [00] . [00] . [88] . [c4] . [00] . [00] . [86] . [c4] . [00] . [00] . [84] . [c4] . [00] . [00] . [0c] . [94] < [3c] F [46] . [0c] . [94] j [6a] G [47] ~ [7e] . [c4] . [00] . [00] . [0c] . [94] l [6c] . [13] z [7a] . [c4] . [00] . [00] x [78] . [c4] . [00] . [00] v [76] . [c4] . [00] . [00] t [74] . [c4] . [00] . [00] r [72] . [c4] . [00] . [00] p [70] . [c4] . [00] . [00] n [6e] . [c4] . [00] . [00] l [6c] . [c4] . [00] . [00] j [6a] . [c4] . [00] . [00] h [68] . [c4] . [00] . [00] f [66] . [c4] . [00] . [00] . [0c] . [94] u [75] F [46] . [0c] . [94] . [a9] G [47] ` [60] . [c4] . [00] . [00] . [0c] . [94] . [ae] F [46] . [0c] . [94] . [e8] G [47] Z [5a] . [c4] . [00] . [00] . [2e] . [0a] 7 [37] . [0a] A [41] . [0a] E [45] . [0b] E [45] . [0b] u [75] . [0f] r [72] . [0d] . [7f] . [0d] . [b1] . [0a] . [b1] . [0a] w [77] . [0e] . [7f] . [0e] . [8b] . [0e] u [75] . [0f] | [7c]
avrdude: Recv: . [13]
avrdude: Send: . [1b] . [10] . [01] . [0a] . [0e] . [13] . [01] . [00] . [c1] . [0a] @ [40] L [4c]   [20] . [00] . [00] . [a5] . [0e] . [aa] . [0e] . [f7] . [0c] . [af] . [0e] . [b4] . [0e] . [86] . [0e] f [66] . [0c] . [b9] . [0e] E [45] . [0b] . [be] . [0e] . [d3] . [0e] . [05] . [a8] L [4c] . [cd] . [b2] . [d4] N [4e] . [b9] 8 [38] 6 [36] . [a9] . [02] . [0c] P [50] . [b9] . [91] . [86] . [88] . [08] < [3c] . [a6] . [aa] . [aa] * [2a] . [be] . [00] . [00] . [00] . [80] ? [3f] G [47] E [45] T [54]   [20] / [2f] s [73] t [74] a [61] t [74] u [75] s [73] / [2f] s [73] u [75] b [62] m [6d] i [69] t [74] p [70] . [2e] a [61] s [73] p [70] x [78] ? [3f] t [74] 1 [31] = [3d] . [00] & [26] t [74] 2 [32] = [3d] . [00] & [26] t [74] 3 [33] = [3d] . [00] & [26] p [70] h [68] = [3d] . [00] & [26] i [69] d [64] = [3d] . [00] & [26] e [65] m [6d] = [3d] . [00] & [26] e [65] m [6d] 1 [31] = [3d] . [00] & [26] r [72] e [65] m [6d] = [3d] . [00] & [26] k [6b] e [65] y [79] = [3d] . [00] & [26] a [61] f [66] = [3d] . [00] & [26] s [73] f [66] = [3d] . [00] & [26] a [61] t [74] o [6f] h [68] i [69] g [67] h [68] = [3d] . [00] & [26] a [61] t [74] o [6f] l [6c] o [6f] w [77] = [3d] . [00] & [26] r [72] . [00] & [26] r [72] o [6f] n [6e] . [00] & [26] r [72] o [6f] f [66] f [66] . [00] & [26] p [70] w [77] m [6d] a [61] = [3d] . [00] & [26] p [70] w [77] m [6d] d [64] = [3d] . [00] & [26] p [70] w [77] m [6d] a [61] o [6f] = [3d] . [00] & [26] p [70] w [77] m [6d] d [64] o [6f] = [3d] . [00] { [7b] " [22] j [6a] s [73] o [6f] n [6e] " [22] : [3a] { [7b] . [00] I [49] D [44] . [00] T [54] 1 [31] . [00] T [54] 2 [32] . [00] T [54] 3 [33] . [00] P [50] H [48] . [00] R [52] . [00] R [52] O [4f] N [4e] . [00] R [52] O [4f] F [46] F [46] . [00] A [41] T [54] O [4f] L [4c] O [4f] W [57] . [00] A [41] T [54] O [4f] H [48] I [49] G [47] H [48] . [00] E [45] M [4d] . [00] E [45] M [4d] 1 [31] . [00] R [52] . [c0]
avrdude: Recv:
avrdude: Send: . [1b] . [10] . [00] . [01] . [0e] . [01] . [05]
avrdude: Recv:
avrdude: stk500v2_command(): failed miserably to execute command 0x13
avrdude: stk500v2_paged_write: write command failed
avrdude: Send: . [1b] . [10] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] @ [40] . [00] . [00] . [9d] . [cd]
avrdude: Recv:
avrdude: Recv:
avrdude: stk500v2_command(): failed miserably to execute command 0x1d
avrdude: stk500v2_cmd(): failed to send command
avrdude: Send: . [1b] . [10] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] H [48] . [00] . [00] . [c4] . [9c]
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [10] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] @ [40] . [00] . [01] . [00] Q [51]
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [10] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] H [48] . [00] . [01] . [00] Y [59]
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [10] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] @ [40] . [00] . [02] . [c8] . [9a]
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [10] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] H [48] . [00] . [02] . [c4] . [9e]
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [10] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] @ [40] . [00] . [03] . [00] S [53]
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [10] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] H [48] . [00] . [03] . [00] [ [5b]
imfortney
Post by imfortney »
its still trying and timing out. should i disconect?
Does it fail like that if you try to upload another code?
Try something simple like the Template code in the Example Codes.
imfortney
Post by imfortney »
yes i tried the template...
Watchdog Timer
Version Menu
Simple Menu
Binary sketch size: 34,110 bytes (of a 258,048 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM4 -b115200 -D -V -Uflash:w:C:\Users\Owner\AppData\Local\Temp\build2718938394513701128.tmp\Template.cpp.hex:i
         PAGEL                         : PD7
         BS2                           : PA0
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Vtarget         : 0.0 V
         SCK period      : 0.1 us
avrdude: reading input file "C:\Users\Owner\AppData\Local\Temp\build2718938394513701128.tmp\Template.cpp.hex"
avrdude: writing flash (34110 bytes):
avrdude: Send: . [1b] . [0f] . [01] . [0a] . [0e] . [13] . [01] . [00] . [c1] . [0a] @ [40] L [4c]   [20] . [00] . [00] - [2d] . [c4] . [00] . [00] X [58] . [c4] . [00] . [00] V [56] . [c4] . [00] . [00] T [54] . [c4] . [00] . [00] R [52] . [c4] . [00] . [00] P [50] . [c4] . [00] . [00] N [4e] . [c4] . [00] . [00] L [4c] . [c4] . [00] . [00] J [4a] . [c4] . [00] . [00] . [0c] . [94] . [93] ' [27] F [46] . [c4] . [00] . [00] D [44] . [c4] . [00] . [00] B [42] . [c4] . [00] . [00] @ [40] . [c4] . [00] . [00] > [3e] . [c4] . [00] . [00] < [3c] . [c4] . [00] . [00] : [3a] . [c4] . [00] . [00] 8 [38] . [c4] . [00] . [00] 6 [36] . [c4] . [00] . [00] 4 [34] . [c4] . [00] . [00] 2 [32] . [c4] . [00] . [00] 0 [30] . [c4] . [00] . [00] . [2e] . [c4] . [00] . [00] . [0c] . [94] . [d2] 5 [35] * [2a] . [c4] . [00] . [00] . [0c] . [94] . [14] 9 [39] . [0c] . [94] < [3c] : [3a] $ [24] . [c4] . [00] . [00] " [22] . [c4] . [00] . [00]   [20] . [c4] . [00] . [00] . [1e] . [c4] . [00] . [00] . [1c] . [c4] . [00] . [00] . [1a] . [c4] . [00] . [00] . [18] . [c4] . [00] . [00] . [16] . [c4] . [00] . [00] . [14] . [c4] . [00] . [00] . [0c] . [94] M [4d] 9 [39] . [0c] . [94] { [7b] : [3a] . [0e] . [c4] . [00] . [00] . [0c] . [94] . [91] . [11] . [0a] . [c4] . [00] . [00] . [08] . [c4] . [00] . [00] . [06] . [c4] . [00] . [00] . [04] . [c4] . [00] . [00] . [02] . [c4] . [00] . [00] . [00] . [c4] . [00] . [00] . [fe] . [c3] . [00] . [00] . [fc] . [c3] . [00] . [00] . [fa] . [c3] . [00] . [00] . [f8] . [c3] . [00] . [00] . [f6] . [c3] . [00] . [00] . [0c] . [94] . [86] 9 [39] . [0c] . [94] . [ba] : [3a] . [f0] . [c3] . [00] . [00] . [0c] . [94] . [bf] 9 [39] . [0c] . [94] . [f9] : [3a] . [ea] . [c3] . [00] . [00] S [53] . [08] \ [5c] . [08] f [66] . [08] j [6a] . [09] j [6a] . [09] . [9a] . [0d] . [97] . [0b] . [a4] . [0b] . [d6] . [08] . [d6] . [08] . [9c] . [0c] . [a4] . [0c] . [b0] . [0c] . [9a] . [0d] . [e7]
avrdude: Send: . [1b] . [10] . [01] . [0a] . [0e] . [13] . [01] . [00] . [c1] . [0a] @ [40] L [4c]   [20] . [00] . [00] . [ca] . [0c] . [cf] . [0c] . [1c] . [0b] . [d4] . [0c] . [d9] . [0c] . [ab] . [0c] . [8b] . [0a] . [de] . [0c] j [6a] . [09] . [e3] . [0c] . [f8] . [0c] G [47] E [45] T [54]   [20] / [2f] s [73] t [74] a [61] t [74] u [75] s [73] / [2f] s [73] u [75] b [62] m [6d] i [69] t [74] p [70] . [2e] a [61] s [73] p [70] x [78] ? [3f] t [74] 1 [31] = [3d] . [00] & [26] t [74] 2 [32] = [3d] . [00] & [26] t [74] 3 [33] = [3d] . [00] & [26] p [70] h [68] = [3d] . [00] & [26] i [69] d [64] = [3d] . [00] & [26] e [65] m [6d] = [3d] . [00] & [26] e [65] m [6d] 1 [31] = [3d] . [00] & [26] r [72] e [65] m [6d] = [3d] . [00] & [26] k [6b] e [65] y [79] = [3d] . [00] & [26] a [61] f [66] = [3d] . [00] & [26] s [73] f [66] = [3d] . [00] & [26] a [61] t [74] o [6f] h [68] i [69] g [67] h [68] = [3d] . [00] & [26] a [61] t [74] o [6f] l [6c] o [6f] w [77] = [3d] . [00] & [26] r [72] . [00] & [26] r [72] o [6f] n [6e] . [00] & [26] r [72] o [6f] f [66] f [66] . [00] & [26] p [70] w [77] m [6d] a [61] = [3d] . [00] & [26] p [70] w [77] m [6d] d [64] = [3d] . [00] & [26] p [70] w [77] m [6d] a [61] o [6f] = [3d] . [00] & [26] p [70] w [77] m [6d] d [64] o [6f] = [3d] . [00] { [7b] " [22] j [6a] s [73] o [6f] n [6e] " [22] : [3a] { [7b] . [00] I [49] D [44] . [00] T [54] 1 [31] . [00] T [54] 2 [32] . [00] T [54] 3 [33] . [00] P [50] H [48] . [00] R [52] . [00] R [52] O [4f] N [4e] . [00] R [52] O [4f] F [46] F [46] . [00] A [41] T [54] O [4f] L [4c] O [4f] W [57] . [00] A [41] T [54] O [4f] H [48] I [49] G [47] H [48] . [00] E [45] M [4d] . [00] E [45] M [4d] 1 [31] . [00] R [52] E [45] M [4d] . [00] A [41] F [46] . [00] S [53] F [46] . [00] P [50] W [57] M [4d] A [41] . [00] P [50] W [57] M [4d] D [44] . [00] } [7d] } [7d] . [00] < [3c] R [52] A [41] > [3e] < [3c] I [49] D [44] > [3e] . [10]
avrdude: Send: . [1b] . [11] . [01] . [0a] . [0e] . [13] . [01] . [00] . [c1] . [0a] @ [40] L [4c]   [20] . [00] . [00] . [00] < [3c] / [2f] I [49] D [44] > [3e] < [3c] T [54] 1 [31] > [3e] . [00] < [3c] / [2f] T [54] 1 [31] > [3e] < [3c] T [54] 2 [32] > [3e] . [00] < [3c] / [2f] T [54] 2 [32] > [3e] < [3c] T [54] 3 [33] > [3e] . [00] < [3c] / [2f] T [54] 3 [33] > [3e] < [3c] P [50] H [48] > [3e] . [00] < [3c] / [2f] P [50] H [48] > [3e] < [3c] R [52] > [3e] . [00] < [3c] / [2f] R [52] > [3e] < [3c] R [52] O [4f] N [4e] > [3e] . [00] < [3c] / [2f] R [52] O [4f] N [4e] > [3e] < [3c] R [52] O [4f] F [46] F [46] > [3e] . [00] < [3c] / [2f] R [52] . [00] O [4f] F [46] F [46] . [00] > [3e] . [00] < [3c] A [41] T [54] O [4f] L [4c] O [4f] W [57] > [3e] . [00] < [3c] / [2f] A [41] T [54] O [4f] L [4c] O [4f] W [57] > [3e] < [3c] A [41] T [54] O [4f] H [48] I [49] G [47] H [48] > [3e] . [00] < [3c] / [2f] A [41] T [54] O [4f] H [48] I [49] G [47] H [48] > [3e] < [3c] E [45] M [4d] > [3e] . [00] < [3c] / [2f] E [45] M [4d] > [3e] < [3c] E [45] M [4d] 1 [31] > [3e] . [00] < [3c] / [2f] E [45] M [4d] 1 [31] > [3e] < [3c] R [52] E [45] M [4d] > [3e] . [00] < [3c] / [2f] R [52] E [45] M [4d] > [3e] < [3c] A [41] F [46] > [3e] . [00] < [3c] / [2f] A [41] F [46] > [3e] < [3c] S [53] F [46] > [3e] . [00] < [3c] / [2f] S [53] F [46] > [3e] . [00] < [3c] P [50] W [57] M [4d] A [41] > [3e] . [00] < [3c] / [2f] P [50] W [57] M [4d] A [41] > [3e] < [3c] P [50] W [57] M [4d] D [44] > [3e] . [00] < [3c] / [2f] P [50] W [57] M [4d] D [44] > [3e] < [3c] P [50] W [57] M [4d] A [41] O [4f] > [3e] . [00] < [3c] / [2f] P [50] W [57] M [4d] A [41] O [4f] > [3e] < [3c] P [50] W [57] M [4d] D [44] O [4f] > [3e] . [00] < [3c] / [2f] P [50] W [57] M [4d] D [44] O [4f] > [3e] . [00] < [3c] / [2f] R [52] A [41] > [3e] . [00] A [41] B [42] C [43] D [44] E [45] F [46] G [47] H [48] I [49] J [4a] K [4b] L [4c] M [4d] . [a5]
avrdude: Recv: . [11]
avrdude: Recv: . [15]
#avrdude: Send: . [1b] . [12] . [01] . [0a] . [0e] . [13] . [01] . [00] . [c1] . [0a] @ [40] L [4c]   [20] . [00] . [00] N [4e] O [4f] P [50] Q [51] R [52] S [53] T [54] U [55] V [56] W [57] X [58] Y [59] Z [5a] a [61] b [62] c [63] d [64] e [65] f [66] g [67] h [68] i [69] j [6a] k [6b] l [6c] m [6d] n [6e] o [6f] p [70] q [71] r [72] s [73] t [74] u [75] v [76] w [77] x [78] y [79] z [7a] 0 [30] 1 [31] 2 [32] 3 [33] 4 [34] 5 [35] 6 [36] 7 [37] 8 [38] 9 [39] + [2b] / [2f] . [00] H [48] T [54] T [54] P [50] / [2f] 1 [31] . [2e] 1 [31]   [20] 2 [32] 0 [30] 0 [30]   [20] O [4f] K [4b] . [0d] . [0a] S [53] e [65] r [72] v [76] e [65] r [72] : [3a]   [20] R [52] e [65] e [65] f [66] A [41] n [6e] g [67] e [65] l [6c] . [0d] . [0a] C [43] a [61] c [63] h [68] e [65] - [2d] C [43] o [6f] n [6e] t [74] r [72] o [6f] l [6c] : [3a]   [20] n [6e] o [6f] - [2d] s [73] t [74] o [6f] r [72] e [65] , [2c]   [20] n [6e] o [6f] - [2d] c [63] a [61] c [63] h [68] e [65] , [2c]   [20] m [6d] u [75] s [73] t [74] - [2d] r [72] e [65] v [76] a [61] l [6c] i [69] d [64] a [61] t [74] e [65] . [0d] . [0a] P [50] r [72] a [61] g [67] m [6d] a [61] : [3a]   [20] n [6e] o [6f] - [2d] c [63] a [61] c [63] h [68] e [65] . [0d] . [0a] C [43] o [6f] n [6e] n [6e] e [65] c [63] t [74] i [69] o [6f] n [6e] : [3a]   [20] c [63] l [6c] o [6f] s [73] e [65] . [0d] . [0a] C [43] o [6f] n [6e] t [74] e [65] n [6e] t [74] - [2d] T [54] y [79] p [70] e [65] : [3a]   [20] t [74] e [65] x [78] t [74] / [2f] . [00] . [0d] . [0a] C [43] o [6f] n [6e] t [74] e [65] n [6e] t [74] - [2d] L [4c] e [65] n [6e] g [67] t [74] h [68] : [3a]   [20] . [00] < [3c] h [68] 1 [31] > [3e] R [52] e [65] e [65] f [66]   [20] A [41] n [6e] g [67] e [65] l [6c]   [20] C [43] o [6f] n [6e] t [74] r [72] o [6f] l [6c] l [6c] e [65] r [72]   [20] W [57] e [65] b [62]   [20] S [53] e [65] r [72] v [76] e [65] r [72] < [3c] / [2f] h [68] 1 [31] . [e7]
avrdude: Recv: . [12]
avrdude: Recv: . [16]
avrdude: Send: . [1b] . [13] . [01] . [0a] . [0e] . [13] . [01] . [00] . [c1] . [0a] @ [40] L [4c]   [20] . [00] . [00] > [3e] . [00] < [3c] ! [21] D [44] O [4f] C [43] T [54] Y [59] P [50] E [45]   [20] h [68] t [74] m [6d] l [6c] > [3e] < [3c] s [73] c [63] r [72] i [69] p [70] t [74]   [20] s [73] r [72] c [63] = [3d] ' [27] h [68] t [74] t [74] p [70] : [3a] / [2f] / [2f] w [77] w [77] w [77] . [2e] r [72] e [65] e [65] f [66] a [61] n [6e] g [67] e [65] l [6c] . [2e] c [63] o [6f] m [6d] / [2f] w [77] i [69] f [66] i [69] / [2f] r [72] a [61] 2 [32] . [2e] j [6a] s [73] ' [27] > [3e] < [3c] / [2f] s [73] c [63] r [72] i [69] p [70] t [74] > [3e] . [00] < [3c] M [4d] . [00] O [4f] K [4b] . [00] < [3c] / [2f] M [4d] . [00] E [45] R [52] R [52] . [00] < [3c] P [50] . [00] < [3c] / [2f] P [50] . [00] < [3c] M [4d] E [45] M [4d] > [3e] . [00] < [3c] / [2f] M [4d] E [45] M [4d] > [3e] . [00] < [3c] D [44] > [3e] . [00] < [3c] / [2f] D [44] > [3e] . [00] < [3c] M [4d] O [4f] D [44] E [45] > [3e] . [00] < [3c] / [2f] M [4d] O [4f] D [44] E [45] > [3e] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [06] _ [5f] . [06] . [00] . [07] . [03] . [00] . [07] . [03] $ [24] ~ [7e] $ [24] ~ [7e] $ [24] $ [24] + [2b] j [6a] . [12] . [00] c [63] . [13] . [08] d [64] c [63] 6 [36] I [49] V [56]   [20] P [50] . [00] . [07] . [03] . [00] . [00] . [00] > [3e] A [41] . [00] . [00] . [00] A [41] > [3e] . [00] . [00] . [08] > [3e] . [1c] > [3e] . [08] . [08] . [08] > [3e] . [08] . [08] . [00] . [e0] ` [60] . [00] . [00] . [08] . [08] . [08] . [08] . [08] . [00] ` [60] ` [60] . [00] . [00]   [20] . [10] . [08] . [04] . [02] > [3e] Q [51] I [49] E [45] > [3e] . [00] B [42] . [7f] @ [40] . [00] b [62] Q [51] I [49] I [49] F [46] " [22] I [49] I [49] I [49] 6 [36] . [18] . [14] . [12] . [7f] . [10] / [2f] I [49] I [49] I [49] 1 [31] < [3c] J [4a] I [49] I [49] 0 [30] . [01] q [71] . [09] . [05] . [03] ] [5d]
avrdude: Recv: . [17]
avrdude: Send: . [1b] . [14] . [01] . [0a] . [0e] . [13] . [01] . [00] . [c1] . [0a] @ [40] L [4c]   [20] . [00] . [00] 6 [36] I [49] I [49] I [49] 6 [36] . [06] I [49] I [49] ) [29] . [1e] . [00] l [6c] l [6c] . [00] . [00] . [00] . [ec] l [6c] . [00] . [00] . [08] . [14] " [22] A [41] . [00] $ [24] $ [24] $ [24] $ [24] $ [24] . [00] A [41] " [22] . [14] . [08] . [02] . [01] Y [59] . [09] . [06] > [3e] A [41] ] [5d] U [55] . [1e] ~ [7e] . [09] . [09] . [09] ~ [7e] . [7f] I [49] I [49] I [49] 6 [36] > [3e] A [41] A [41] A [41] " [22] . [7f] A [41] A [41] A [41] > [3e] . [7f] I [49] I [49] I [49] A [41] . [7f] . [09] . [09] . [09] . [01] > [3e] A [41] I [49] I [49] z [7a] . [7f] . [08] . [08] . [08] . [7f] . [00] A [41] . [7f] A [41] . [00] 0 [30] @ [40] @ [40] @ [40] ? [3f] . [7f] . [08] . [14] " [22] A [41] . [7f] @ [40] @ [40] @ [40] @ [40] . [7f] . [02] . [04] . [02] . [7f] . [7f] . [02] . [04] . [08] . [7f] > [3e] A [41] A [41] A [41] > [3e] . [7f] . [09] . [09] . [09] . [06] > [3e] A [41] Q [51] ! [21] ^ [5e] . [7f] . [09] . [09] . [19] f [66] & [26] I [49] I [49] I [49] 2 [32] . [01] . [01] . [7f] . [01] . [01] ? [3f] @ [40] @ [40] @ [40] ? [3f] . [1f]   [20] @ [40]   [20] . [1f] ? [3f] @ [40] < [3c] @ [40] ? [3f] c [63] . [14] . [08] . [14] c [63] . [07] . [08] p [70] . [08] . [07] q [71] I [49] E [45] C [43] . [00] . [00] . [7f] A [41] A [41] . [00] . [02] . [04] . [08] . [10]   [20] . [00] A [41] A [41] . [7f] . [00] . [04] . [02] . [01] . [02] . [04] . [80] . [80] . [80] . [80] . [80]   [20] @ [40] . [80] @ [40]   [20]   [20] T [54] T [54] T [54] x [78] . [7f] D [44] D [44] D [44] 8 [38] 8 [38] D [44] D [44] D [44] ( [28] 8 [38] D [44] D [44] D [44] . [7f] 8 [38] T [54] T [54] T [54] . [18] . [08] ~ [7e] . [09] . [09] . [00] . [18] . [a4] . [a4] . [a4] | [7c] . [7f] . [04] . [04] x [78] . [00] . [00] . [00] } [7d] . [00] . [00] @ [40] . [80] . [84] } [7d] . [00] . [7f] . [a2]
#avrdude: Send: . [1b] . [15] . [01] . [0a] . [0e] . [13] . [01] . [00] . [c1] . [0a] @ [40] L [4c]   [20] . [00] . [00] . [10] ( [28] D [44] . [00] . [00] . [00] . [7f] @ [40] . [00] | [7c] . [04] . [18] . [04] x [78] | [7c] . [04] . [04] x [78] . [00] 8 [38] D [44] D [44] D [44] 8 [38] . [fc] D [44] D [44] D [44] 8 [38] 8 [38] D [44] D [44] D [44] . [fc] D [44] x [78] D [44] . [04] . [08] . [08] T [54] T [54] T [54]   [20] . [04] > [3e] D [44] $ [24] . [00] < [3c] @ [40]   [20] | [7c] . [00] . [1c]   [20] @ [40]   [20] . [1c] < [3c] ` [60] 0 [30] ` [60] < [3c] l [6c] . [10] . [10] l [6c] . [00] . [9c] . [a0] ` [60] < [3c] . [00] d [64] T [54] T [54] L [4c] . [00] 3 [33] f [66] . [cc] f [66] 3 [33] . [00] . [00] . [7f] . [00] . [00] . [cc] f [66] 3 [33] f [66] . [cc] . [02] . [01] . [02] . [01] . [00] , [2c] . [02] . [01]   [20] . [0f] & [26] . [0f] ( [28] . [01] . [2e] E [45] . [00] S [53] . [00] . [10] . [03] $ [24] " [22] 0 [30] = [3d] 2 [32] . [0e] @ [40] . [80] B [42] . [00] . [83] C [43] . [00] . [83] 4 [34] . [8d] * [2a] E [45] + [2b] i [69] " [22] . [11] U [55] . [00] V [56] . [00] W [57] . [9f] Y [59] . [00] . [00] . [9f] . [00] Q [51] . [11] . [03] ) [29] . [13] ! [21] N [4e] o [6f]   [20] I [49] n [6e] t [74] e [65] r [72] n [6e] a [61] l [6c]   [20] M [4d] e [65] m [6d] o [6f] r [72] y [79] . [00] F [46] o [6f] u [75] n [6e] d [64] . [00] . [c7] . [06] . [cf] . [06] . [dc] . [06] . [e6] . [06] . [f5] . [06] . [04] . [07] . [10] . [07] . [18] . [07] . [1e] . [07] + [2b] . [07] F [46] e [65] e [65] d [64] i [69] n [6e] g [67] . [00] W [57] a [61] t [74] e [65] r [72]   [20] C [43] h [68] a [61] n [6e] g [67] e [65] . [00] A [41] T [54] O [4f]   [20] C [43] l [6c] e [65] a [61] r [72] . [00] O [4f] v [76] e [65] r [72] h [68] e [65] a [61] t [74]   [20] C [43] l [6c] e [65] a [61] r [72] . [00] P [50] H [48]   [20] C [43] a [61] l [6c] i [69] b [62] r [72] a [61] t [74] . [ed]
avrdude: Recv:
avrdude: Send: . [1b] . [15] . [00] . [01] . [0e] . [01] . [00]
avrdude: Recv:
avrdude: Send: . [1b] . [15] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] @ [40] . [00] . [00] - [2d] x [78]
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [15] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] H [48] . [00] . [00] . [c4] . [99]
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [15] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] @ [40] . [00] . [01] . [00] T [54]
avrdude: Recv:
imfortney
Post by imfortney »
i tried the new cable that i bought from RA and the old cable. with the new cable i got this message:
Watchdog Timer
Version Menu
Simple Menu
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM5 -b115200 -D -V -Uflash:w:C:\Users\Owner\AppData\Local\Temp\build7422261211813710313.tmp\Template.cpp.hex:i
         Using Port                    : \\.\COM5
avrdude: Recv:
imfortney
Post by imfortney »
now all i get is
avrdude: Recv:
I know that the unit was rebooting on its own through out the day, because my skimmer is set to 60 min delay and when i got home the skimmer was off. not to mention the skimmate cup was empty.
this is frustrating. i had to send it back once before only to be told there is nothing wrong with it. When i received it back the unit functioned perfectly and i was able to program it.
i am leaving it unpowered over night maybe i will be able to reprogram it in the am.
what is the button inside on the main board to the right of the screen? Is there someway to reset the unit and start with blank memory?
Everytime you program the unit, it will erase the previous one. So, it's like having a fresh memory everytime.
There seems to be something definitely wrong with this unit. It is not supposed to be doing all that.
PM me for RMA.
