Custom Web Chart
Related to the Portal
ganjero
Re: Custom Web Chart
Post by ganjero »
rimai wrote:I changed it so it uses a random color.
Try it again.
Thanks, that looks better. The only weird thing (minor) is that on the legend it puts both, pwma & pwmd, for each line. It doesn't do this for temperature.
It's a bug. Thanks for reporting.
I fixed it. Try again.
ganjero
Post by ganjero »
rimai wrote:It's a bug. Thanks for reporting.
It's fixed, thanks again. Really like my RA equipment and appreciate all you support Roberto.
Wow, the random colors is awesome. Roberto, the only thing this doesn't do that the other web chart does is the link to download link and print (not so usefull...) Can you add the export option to this one? And at that point, does it makes sense to not just combine them to one? :)
I'll change the other one with the same capability, but with the export added to it.
Awesome, I hated having to use screengrab to download the graph :)
Just wanted to say the new charts have been great! And the database fix has been awesome! They load so quick now!!!
Quick question. How do you pull in data for a relay? Like can i map my heater port R6 with T1?
Not possible yet :(
Ideas on how to accomplish this?
Whats the issue? You do it for the relay data chart already...
2 different charts and 2 totally different queries.
The problem is that you can pull filter=R, but you can't OR it to get specific ports.
Isnt the chart software javascript? Couldn't you massage the result of R and OR it in the js before you process the chart? Another way would be to have a separate js/php/ whatever vb..net i think that would break R up in a usable format.
The problem for me is I dont follow how the graphs get the data :)
But I'm sure we can get some json/xml/output to do it, or am I missing something?
Data is collected through JSONP for each filter:
For example T1:
http:\\forum.reefangel.com\status\jsonp.aspx?id=reefangel&filter=T1
You can see the JS that occurs in behind the scene:
[code]
<!DOCTYPE HTML>
<html>
    <head>
        <meta charset="utf-8" />
        <meta name="format-detection" content="telephone=no" />
        <!-- WARNING: for iOS 7, remove the width=device-width and height=device-height attributes. See https://issues.apache.org/jira/browse/CB-4323 -->
        <meta name="viewport" content="user-scalable=no, initial-scale=.5, maximum-scale=.5, minimum-scale=.5, target-densitydpi=device-dpi" />
        <meta name="msapplication-tap-highlight" content="no" />
        <link href='http://code.jquery.com/mobile/1.3.2/jquery.mobile-1.3.2.min.css' rel='stylesheet'>
		<script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/1.6.2/jquery.min.js"></script>
        <script src='http://code.jquery.com/mobile/1.3.2/jquery.mobile-1.3.2.min.js'></script>
        <title>Reef Angel U-App</title>
		<script type="text/javascript">
		    $(function () {
				$.mobile.loading( 'show', {
					text: 'Connecting to Portal',
					textVisible: true,
					theme: 'b',
					html: ""
		        Highcharts.setOptions({
		            global: {
		                useUTC: false
		        var seriesOptions = [],
				yAxisOptions = [],
				seriesCounter = 0,
				seriesID = 0,
				names = [
				'T1'
				colors = Highcharts.getOptions().colors;
		        $.each(names, function (i, name) {
		            $.getJSON('http://forum.reefangel.com/status/jsonp.aspx?id=reefangel&filter=' + name.toLowerCase() + '&callback=?', function (data) {
		                var pcolor;
		                var tname;
		                var ydec;
		                var yunit;
		                if (name == "PH") {
		                    pcolor = '#669900'
		                    tname = 'pH'
		                    ydec = 2
		                    yunit = 'pH'
		                else if (name == "PHE") {
		                    pcolor = '#447700'
		                    tname = 'pH Expansion'
		                    ydec = 2
		                    yunit = 'pH'
		                else if (name == "SAL") {
		                    pcolor = '#000066'
		                    tname = 'Salinity'
		                    ydec = 1
		                    yunit = 'ppt'
		                else if (name == "ORP") {
		                    pcolor = '#330000'
		                    tname = 'ORP'
		                    ydec = 0
		                    yunit = 'mV'
		                else if (name == "T1") {
		                    pcolor = '#FF0000'
		                    tname = 'Temp 1'
		                    ydec = 1
		                    yunit = '°'
		                else if (name == "T2") {
		                    pcolor = '#FF8800'
		                    tname = 'Temp 2'
		                    ydec = 1
		                    yunit = '°'
		                else if (name == "T3") {
		                    pcolor = '#9900CC'
		                    tname = 'Temp 3'
		                    ydec = 1
		                    yunit = '°'
                        else {
		                    pcolor = getRandomColor()
		                    tname = name.toUpperCase()
		                    ydec = 0
		                    yunit = ''
		                if (data.length) {
		                    seriesOptions[seriesID] = {
		                        dataGrouping: {
		                            smoothed: true
		                        color: pcolor,
		                        tooltip: {
		                            yDecimals: ydec,
		                            ySuffix: yunit
		                        data: data
		                    seriesID++;
		                // As we're loading the data asynchronously, we don't know what order it will arrive. So
		                // we keep a counter and create the chart when all the data is loaded.
		                seriesCounter++;
						if(data.length==0)
							$('#container').html("No data to display");
							$.mobile.loading( "hide" );
							if (seriesCounter == names.length) {
								createChart();
		        // create the chart when all data is loaded
		        function createChart() {
		            chart = new Highcharts.StockChart({
		                chart: {
		                    renderTo: 'container',
		                    type: 'spline'
		                title: {
		                    text: 'Reef Angel Controller Web Chart'
		                subtitle: {
		                    text: 'Parameters logged for the past 7 days'
		                credits: {
		                    enabled: false
		                legend: {
		                    enabled: true,
		                    //align: 'right',
		                    //backgroundColor: '#FCFFC5',
		                    borderColor: 'black',
		                    borderWidth: 2,
		                    //layout: 'vertical',
		                    verticalAlign: 'top',
		                    y: 100,
		                    shadow: true
		                rangeSelector: {
		                    buttons: [{
		                        type: 'minute',
		                        count: 60,
		                        text: '1h'
		                        type: 'minute',
		                        count: 720,
		                        text: '12h'
		                        type: 'day',
		                        count: 1,
		                        text: '1d'
		                        type: 'day',
		                        count: 3,
		                        text: '3d'
		                        type: 'all',
		                        text: '7d'
		                    selected: 2,
		                    inputEnabled: false
		                navigator: {
		                    xAxis: {
		                        type: 'datetime',
		                        maxZoom: 3600000, // 1 hour
		                        dateTimeLabelFormats: { // don't display the dummy year
		                            second: '%I:%M:%S %p',
		                            minute: '%I:%M %p',
		                            hour: '%b/%e',
		                            day: '%b/%e',
		                            week: '%b/%e'
		                xAxis: {
		                    type: 'datetime',
		                        minute: '%I:%M %p',
		                        hour: '%I:%M %p',
		                        day: '%b/%e',
		                        week: '%b/%e'
		                yAxis: {
		                    plotLines: [{
		                        value: 0,
		                        width: 1,
		                        color: 'silver'
                        exporting: {
                            url: '/export/index.php',
                            filename: 'Reef Angel Web Chart T1'
		                tooltip: {
		                    borderColor: 'silver',
		                    xDateFormat: '%A, %b %e, %l:%M %p',
		                    pointFormat: '<span style="color:{series.color}">{series.name}</span>: <b>{point.y}</b><br/>'
		                series: seriesOptions
		function getRandomColor() {
			var letters = '0123456789ABCDEF'.split('');
			var color = '#';
			for (var i = 0; i < 6; i++ ) {
				color += letters[Math.floor(Math.random() * 16)];
			return color;
		</script>
	</head>
	<body>
		<script type="text/javascript" src="http://forum.reefangel.com/js/highstock.js"></script>
        <script type="text/javascript" src="http://forum.reefangel.com/js/modules/exporting.js"></script>
		<div id="container" style="height: 500px; min-width: 600px"></div>
	</body>
</html>
So wouldn't you just need jsonp.aspx to have a function to reformat the data if the filter is a relay filter? and then it would just output the R1, R2, R3 etc in the json output?
This is where devs may get confused. Not so much for end users. They never get to see this... But, R1 is actually the variable used for Expansion Box 1 status of all 8 ports and not port 1 of the main box.
I guess you could consider that devs would have a better understanding and not get confused, huh?
Yeah I was just confusing myself in the reply, but I know the variables.
What I do in my php is break that down to separate varaibles for each relay and do the bitwise masks etc to see if they are actually on/off. It's a lot of extra work :)
Do you have specific names for them?
I use the following:
$R=$xml->'{R}';
$RON=$xml->{'RON'};
$ROFF=$xml->{'ROFF'};
$RBIN=getBin($R);
$RMASK=applyMasks($R,$RON,$ROFF);
then I have:
$relay1val=$RBIN[7];
$relay1status=$RMASK[7];
Where relay1val is the auto value for the relay and the relay1status is the actual status of the port.
getBin returns the binary string of the number and applyMasks does the same bitwise operations we do to resolve RelayData and RelayMaskOn/RelayMaskOff.
I can send you (or it's linked in my custom portal page) the php I'm using if it would be helpful...
I guess we better off calling it just like in our libraries.
Port1-Port8, Box1_Port1-Box1_Port etc
Sent from my Galaxy S5 with Tapatalk
That would be intutitive :)
arch
Post by arch »
rimai wrote:We would need to analyze the results of the query record by record to be able to do this.
Remember that this is a SQL query.
I've had a bash at doing this in javascript. I haven't tried it with highcharts yet, but it works with a my modified version of your webcharts using d3.
See http://arch1.github.io/RA_CustomCharts/
and
https://github.com/arch1/RA_CustomCharts
The RFW plot is a good example of plotting data gaps.
Very nice. The only thing you're missing is the mouse-overs to see the details.
arch
Post by arch »
Yes - I'll put on that on the todo list (along with plotting individual relays - maths was easier than I thought it would be).
I've made the charts scrollable in this version (still needs a bit of tidying up - but tooltips shouldn't be too hard):
http://bl.ocks.org/arch1/5c63a184ca638b291df7
(best viewed in new window)
That is really cool. Can we overlap multiple filters? Thanks for showing the HTML in that. I was able to copy that over to my server and switch it to my ID. FYI Celsius to Fahrenheit was a pain but not too bad.
arch
Post by arch »
I'm planning to add multiple filters - but it will take me a while - this is already a major stretch of my javascript/d3 capabilities.
While there are plenty of examples around ( http://bl.ocks.org/mbostock/3884955, http://www.d3noob.org/2014/07/d3js-mult ... matic.html) adding extra features without breaking existing ones is proving a challenge...
arch
Post by arch »
lnevo wrote:Isnt the chart software javascript? Couldn't you massage the result of R and OR it in the js before you process the chart? Another way would be to have a separate js/php/ whatever vb..net i think that would break R up in a usable format.
Here's my first crack at plotting individual relay data from the decimal representation:
http://bl.ocks.org/arch1/9178a77aea3d5775897a
the plotting code isn't very elegant yet (it's hard-coded to main relay and expansion relay box only) - but seems to work OK (with data gaps dealt with too).
Awesome
arch
Post by arch »
AlanM wrote:Right. Is it because you use highstock.js instead of highchart.js? I wouldn't think so, though. Weird.
I can't work out how highcharts deal with irregular data either. Others have lobbied so far ? unsuccessfully for changes re data gaps:
http://forum.highcharts.com/highstock-u ... age15.html
arch
Post by arch »
lnevo wrote:Very nice. The only thing you're missing is the mouse-overs to see the details.
Tooltips added in this version (I'm sure this code could be written in a fraction of the number of lines).
http://bl.ocks.org/arch1/d220e06fc3dcc4ea6d82
saf1
Post by saf1 »
Not sure I understand how the portal charts are supposed to work. I wanted to see how the wave maker was working with regards to my tide code and both PWMA and PWMD are both showing activity - or something with regards to plots in the chart.
Yet on the tank I can clearly see only one RW spinning up and the PWM D at 65% while the PWM A is at 0. What is the web chart actually plotting or do I need to enable something else. I was trying to see if it actually slowed down at night and if the left and right side alternated and at what time. Now I'm totally lost :)
Thanks.
-scott
http://forum.reefangel.com/status/chart ... ilter=PWMA
http://forum.reefangel.com/status/chart ... ilter=PWMD
