Posts: 12857 Joined: Fri Mar 18, 2011 6:47 pm
Post
by rimai » Fri Jul 18, 2014 10:37 am
Hi Everyone,
This is the first prototype of a wireless RANet Ready Dimmable LED driver module.
[youtube]
http://www.youtube.com/watch?v=9mGxHA9Y57A [/youtube]
It's truly a wireless LED mini fixture. It is even powered by a battery to make it the ultimate in mobile fixture
Don't expect the batteries to last long. I just did this to show off
That small battery would only last for about 4 hours.
Posts: 1432 Joined: Fri Mar 29, 2013 3:51 pm
Post
by cosmith71 » Fri Jul 18, 2014 12:22 pm
What's the responsiveness like? Will it do lightning?
cosmith71 on Fri Jul 18, 2014 4:23 pm, edited 1 time in total.
89delta
Posts: 157 Joined: Mon Oct 15, 2012 7:21 pm
Post
by 89delta » Fri Jul 18, 2014 12:23 pm
Very nice Roberto
Post
by rimai » Fri Jul 18, 2014 1:43 pm
cosmith71 wrote: What's the responsiveness like? Will it do lightening?
I'll have to test. I'm not sure it can.
Posts: 5422 Joined: Fri Jul 20, 2012 9:42 am
Post
by lnevo » Fri Jul 18, 2014 4:41 pm
Sweet
jsclownfish
Posts: 375 Joined: Mon Oct 24, 2011 7:52 pm
Post
by jsclownfish » Sun Jul 20, 2014 2:44 pm
I'm already looking for good thunder sound bytes to go along with the lightening.
jegillis
Posts: 86 Joined: Sat Jan 04, 2014 10:26 am
Post
by jegillis » Sun Jul 20, 2014 4:24 pm
How much is all this new stuff going to cost me?
pandimus
Posts: 213 Joined: Mon Apr 01, 2013 7:58 pm
Post
by pandimus » Sun Jul 20, 2014 4:36 pm
What are the specs on it?
Post
by cosmith71 » Sat Jul 26, 2014 3:33 pm
Any way to code this lightning into the current cloud software?
Post
by rimai » Sat Jul 26, 2014 4:00 pm
That sucks
I lost the code. I can't find it.
Post
by rimai » Sun Jul 27, 2014 5:58 pm
I found it
int a=random(5);
for (int i=0;i<a;i++)
int newdata=4095;
Wire.beginTransmission(0x40);
Wire.write(0x8+(4*2));
Wire.write(newdata&0xff);
Wire.write(newdata>>8);
Wire.endTransmission();
delay(20+random(50));
newdata=0;
delay(30+random(20));
delay(random(1000));
Post
by cosmith71 » Sun Jul 27, 2014 6:12 pm
Nice. I might steal it.
Post
by cosmith71 » Mon Jul 28, 2014 7:33 am
So would something like this:
int a=random(5);
for (int i=0; i<a; i++)
analogWrite(daylightPWMPin, 255);
analogWrite(daylightPWMPin, 0);
Essentially taking over for 5 seconds, cause any timing problems with anything else if it hits in the middle of, say, top-off or dosing?
Post
by rimai » Mon Jul 28, 2014 8:35 am
Looks good
Post
by cosmith71 » Mon Jul 28, 2014 10:09 am
It works great! Will try to post a video later.
Post
by lnevo » Mon Jul 28, 2014 10:20 am
Is there a thread of the official(?) cloud/lightning code anywhere? If there is can we sticky it? If not, can we get one posted. Too often I see the requests for it, and no idea where to find it
Colin, you should post your code somewhere if you don't already have it.
Smotz
Posts: 401 Joined: Sat Mar 30, 2013 5:02 pm
Post
by Smotz » Tue Jul 29, 2014 5:06 am
been considering upgrading my lights. I should probably hold off to see what happens here..
GiraffeCat
Posts: 61 Joined: Sun Jun 08, 2014 12:55 pm
Post
by GiraffeCat » Wed Aug 27, 2014 6:47 pm
How many channels is each driver going to have? Is this going to be a RANet Dimming Expansion?
What is the range of voltages it can handle? Fixed voltage input, or selectable/tolerant of 12 to 48 volt range?
LMK.
Thank You,
GC
.....Your forefathers wisely set aside their compassion - Steeled themselves for what needed to be done.......
Post
by rimai » Wed Aug 27, 2014 7:13 pm
Each module has 3 channels capable of delivering anywhere from 350mA to 1000mA each channel.
You can use a power supply from 12V all the way up to 48V, depending on the number of LEDs you want to have in each string.
GiraffeCat
Post
by GiraffeCat » Thu Aug 28, 2014 7:06 pm
Does it need a separate power source to run the electronics, or does it sample from the led source?
Many uses this RANet has. (In Yoda speak)
Late,
GC
Post
by rimai » Thu Aug 28, 2014 9:19 pm
Yes, you will need a power supply to feed power to as many LEDs you wish to light up.
For example, 3 LEDs, you only need 12V, but for 12-13LEDs, you need 48V.
It's the same as the LDD drivers.
Each channel is configured individually so you can set them to run at different amperages if you wish. Anywhere from 250mA to 1000mA each channel.
GiraffeCat
Post
by GiraffeCat » Fri Aug 29, 2014 11:39 am
Forgive me. Let me ask a different way.
Does the RANet LED Driver need a power source of its own - to run the wireless communication portion of the driver. ( Not the LED power source - A separate source independent of the led power source .)
LMK,
GC
Post
by rimai » Fri Aug 29, 2014 11:59 am
No....
It has a built-in DC-DC converter to reduce the 12V-48V down to 5V to run the internal circuit.
GiraffeCat
Post
by GiraffeCat » Sun Aug 31, 2014 4:18 pm
Update? I'm sure more than one person is wondering how it's going.
LUK,
GC
Post
by rimai » Sun Aug 31, 2014 6:27 pm
Someone is already running it on his system
Maybe he will post some pics
jegillis
Post
by jegillis » Mon Sep 01, 2014 8:29 am
rimai wrote: Someone is already running it on his system
Pics will be here shortly dimmer is running great however my cheap ebay power supply burned out. Waiting on a new one to get here to take pics.
Rodasphoto
Posts: 187 Joined: Wed Apr 10, 2013 2:48 pm
Post
by Rodasphoto » Fri Feb 13, 2015 5:37 pm
How much do these cost and how can I order a couple of them?
