false contact
hawaiiensis38
false contact
Hello there
I have a problem to use my controller
Indeed, when I connect the daylight and actinic light only daylight lights.
I must move the communication cable that comes on the relay box for the actinic light illuminates.
it looks like a false contact,
on the menu should appear
1.Feeding
2.Water Change
3.Lights
4.Temps
5.Timeouts
6.Setup
7.Version
8.Exit
I do not see 3.the light menu
how do I correct this
Regards
olivier
1.Feeding
2.Water Change
3.Lights
4.Temps
5.Timeouts
6.Setup
7.Version
8.Exit
Regards
olivier
hawaiiensis38
Re: false contact
and another thing i don't find the USB-TTL converter cable
how can i got a new one?
olivier
olivier
Re: false contact
The lights menu will only show up on the preloaded code.
You can get replacement cables on the webstore.
hawaiiensis38
Re: false contact
hello
i cannot buy the cable in canada it's to much
i found one VGA cable that i can use
can i buy this USB-TTL cable?
how much pin?
The latest cable seems to be the good one!!!
=> FTDI USB to TTL Serial Cable +3.3v TTL with TRANSPARENT Moulding with Rx/Tx LEDs
- http://www.ebay.fr/itm/USB-to-TTL-Seria ... 43cc689f91
=> 6pin FTDI FT232RL USB to Serial adapter module USB TO TTL RS232 Arduino Cable
- http://www.ebay.fr/itm/6pin-FTDI-FT232R ... 51bf8b0cd8
=> USB Câble pour TTL PL2303 Module Converter Série
- http://www.ebay.fr/itm/Blanc-USB-Cable- ... 3f2049aee4
=> USB to TTL Serial Converter Cable
FT232RQ Interface Device
Data Transfer Rates from 300baud to 3Mbaud at TTL Levels, UART Interface Support for 7/8 Data Bits
- http://www.ebay.fr/itm/TTL-232R-3V3-Ftd ... 20e08a0e55
Regards
Olivier
how much pin?
Regards
Olivier
hawaiiensis38
Re: false contact
any suggestion?
how many pin have this cable?
hawaii
hawaii
hawaiiensis38
Re: false contact
hello
i buy the usb-ttl cable
i make exactly the procedure for the set up with the computer, but, i don't have :
10.On the menu Tools > Serial Port, make sure the selected serial port is something like '''/dev/tty.usbserial'
what can i do?
hawaii
what can i do?
hawaii
hawaiiensis38
Re: false contact
which drivers?
i follow exactly the manual
hawaii
hawaii
Re: false contact
The FTDI driver.
Do you have any unrecognized device showing in your device manager (I don't know the exact name for MacOSX).
If your computer doesn't recognize the cable and install the device driver correctly, it won't show in the list.
Did you try a different USB port, maybe?
hawaiiensis38
Re: false contact
i will try a another usb port tomorrow
