Hello,
it's been long time and i'm trying with no success
i have the wifi attachment and i see that wifi is not working
today i make a tcpdump on a laptop connected to the same wifi and i see
UDP packets coming from the wifi attachment from port 2000 to 255.255.255.255 and port 5000
ontecnt is as below:
4k.....&.....p..
.Time NOT SET..WiFly Ver 2.38.3, 01-15-2012ReefAngelWifi.....................................4k.....+.....x..
.Time NOT SET..WiFly Ver 2.38.3, 01-15-2012ReefAngelWifi.....................................4k.....'........
.Time NOT SET..WiFly Ver 2.38.3, 01-15-2012ReefAngelWifi.....................................4k.....6........
any ideas or how to troubleshoot it
wifi not upating the portal
waelaase
[img]/status/banner_3.aspx?id=waelaase&t=2[/img]
waelaase
Re: wifi not upating the portal
Hello ,
i am not sure what you mean connect by serial and to what?
A serial program to connect directly to the wifi module. You can get Tera Term to do that. Once you have that you can run commands on the wifi module to help troubleshoot.
