RANet Ready Dimmable LED Driver
Hi Everyone,
This is the first prototype of a wireless RANet Ready Dimmable LED driver module.
[youtube]http://www.youtube.com/watch?v=9mGxHA9Y57A[/youtube]
It's truly a wireless LED mini fixture. It is even powered by a battery to make it the ultimate in mobile fixture :)
Don't expect the batteries to last long. I just did this to show off :ugeek:
That small battery would only last for about 4 hours.
Re: RANet Ready Dimmable LED Driver
What's the responsiveness like? Will it do lightning?
89delta
Post by 89delta »
Very nice Roberto
cosmith71 wrote:What's the responsiveness like? Will it do lightening?
I'll have to test. I'm not sure it can.
Here is what I was able to achieve:
I think it looks pretty realistic :)
[youtube]http://www.youtube.com/watch?v=V4lR5FkzCyk[/youtube]
Nice!
Sweet
jsclownfish
Post by jsclownfish »
I'm already looking for good thunder sound bytes to go along with the lightening. :)
jegillis
Post by jegillis »
How much is all this new stuff going to cost me?
pandimus
Post by pandimus »
What are the specs on it?
Any way to code this lightning into the current cloud software?
That sucks :(
I lost the code. I can't find it. :? :oops:
I found it :)
  int a=random(5);
  for (int i=0;i<a;i++)
    int newdata=4095;
    Wire.beginTransmission(0x40);
    Wire.write(0x8+(4*2));
    Wire.write(newdata&0xff);
    Wire.write(newdata>>8);
    Wire.endTransmission();
    delay(20+random(50));
    newdata=0;
    delay(30+random(20));
  delay(random(1000));
Nice. I might steal it. ;)
So would something like this:
        int a=random(5);
        for (int i=0; i<a; i++)
          analogWrite(daylightPWMPin, 255);
          analogWrite(daylightPWMPin, 0);
Essentially taking over for 5 seconds, cause any timing problems with anything else if it hits in the middle of, say, top-off or dosing?
Looks good :)
It works great! Will try to post a video later.
Is there a thread of the official(?) cloud/lightning code anywhere? If there is can we sticky it? If not, can we get one posted. Too often I see the requests for it, and no idea where to find it :)
Colin, you should post your code somewhere if you don't already have it.
Smotz
Post by Smotz »
been considering upgrading my lights. I should probably hold off to see what happens here..
GiraffeCat
Post by GiraffeCat »
How many channels is each driver going to have? Is this going to be a RANet Dimming Expansion?
What is the range of voltages it can handle? Fixed voltage input, or selectable/tolerant of 12 to 48 volt range?
LMK.
Thank You,
GC
.....Your forefathers wisely set aside their compassion - Steeled themselves for what needed to be done.......
Each module has 3 channels capable of delivering anywhere from 350mA to 1000mA each channel.
You can use a power supply from 12V all the way up to 48V, depending on the number of LEDs you want to have in each string.
GiraffeCat
Does it need a separate power source to run the electronics, or does it sample from the led source?
Many uses this RANet has. (In Yoda speak)
Late,
GC
Yes, you will need a power supply to feed power to as many LEDs you wish to light up.
For example, 3 LEDs, you only need 12V, but for 12-13LEDs, you need 48V.
It's the same as the LDD drivers.
Each channel is configured individually so you can set them to run at different amperages if you wish. Anywhere from 250mA to 1000mA each channel.
GiraffeCat
Forgive me. Let me ask a different way.
Does the RANet LED Driver need a power source of its own - to run the wireless communication portion of the driver. ( Not the LED power source - A separate source independent of the led power source .)
LMK,
GC
No....
It has a built-in DC-DC converter to reduce the 12V-48V down to 5V to run the internal circuit.
GiraffeCat
Update? I'm sure more than one person is wondering how it's going.
LUK,
GC
Someone is already running it on his system :)
Maybe he will post some pics :)
jegillis
Post by jegillis »
rimai wrote:Someone is already running it on his system :)
Pics will be here shortly dimmer is running great however my cheap ebay power supply burned out. Waiting on a new one to get here to take pics.
Rodasphoto
Post by Rodasphoto »
How much do these cost and how can I order a couple of them?
