I just bought a RA with pwm from a friend and I am in the process of trying to get going with it, but I'm hitting some trouble.
When I got it, the previous owner had installed code so when I turned it on it had the status screen showing some of the plug (relays) numbers on the flashing red, and the actual relay (plug box) was clicking intermittently.
So I installed the software via the website and then, through the Arduino sketch programme I changed the COM port and board, then opted to install internal memory and upload the 'RA-preloaded' code.
Now, the RA screen just states 'no internal memory found'...
And, when I try to run the Reef Angel Generator from the 'Reef Angel Controller' programme, it shows an error: "problem with shortcut The item 'RAGen.exe' that this shortcut refers to has been changed or moved, so this shortcut will no longer work properly..."
I have tried uninstalling the programme, then reinstalling using the same 'installer' saved on my desktop, but after 3 attempts, I continue to get the same issue...
Is this something simple to fix? Can somebody please point me in the right direction?!
![Wink ;)](./images/smilies/icon_e_wink.gif)
Thanks.
