Hi, I have just received my new pH and Orp expansion module. Do i have to calibrate each one when i set it up with it's own software or i Can just plug it in and start using it?
Thanks in advance
Inviato dal mio GT-I9505 utilizzando Tapatalk
pH and Orp calibration needed at setup?
- Contact:
Re: pH and Orp calibration needed at setup?
You can plug them each in and they will start working, however you may need to calibrate them to get accurate readings for your device/setup. The best answer I can give you is to plug them in and start using them and see what they are reading. If you have manual testers for those then also test and see how the values compare. If the readings are off, then you will definitely want to calibrate each one.mrwlf wrote:Hi, I have just received my new pH and Orp expansion module. Do i have to calibrate each one when i set it up with it's own software or i Can just plug it in and start using it?
Thanks in advance
mrwlf
Thanks i'll try
mrwlf
I think that i'll need calibration for both my pH probe. ( 1 in Ca reactor and 1 in sump).
When i go through the calibration procedure do i need to repeat it for each probe? What's the procedure?
- Contact:
yes, there is a calibration option for each of the probes: pH, pH Expansion, ORPmrwlf wrote:I think that i'll need calibration for both my pH probe. ( 1 in Ca reactor and 1 in sump).
you will need to calibrate each one individually because they use different memory locations to maintain their calibration values.
