Dual Tank, single controller
Ask in here.
imfortney
Post by imfortney »
Well guys i want to control ATO, Fan (chiller), and Overheat functions for 2 different tanks.
I am hoping that you guys can help me with this.
Here is what I want to try:
#define NUMBERS_8x16
ReefAngel.LCD.DrawText(COLOR_ORANGERED, COLOR_DEEPSKYBLUE,14,8, "Fortney Money Pit");
DrawStatus (20,80);
DrawParams (5,40);
DrawParamsa (0,10);
    ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.FeedingModePorts = Port2Bit | Port6Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port6Bit | Port8Bit;
    ReefAngel.LightsOnPorts = Port3Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port7Bit;
    //ReefAngel.CustomLabels[0]="ReturnPump";
    //ReefAngel.CustomLabels[1]="Skimmer";
    //ReefAngel.CustomLabels[2]="Kessil";
    //ReefAngel.CustomLabels[3]="Nick  Fan";
    //ReefAngel.CustomLabels[4]="Steph Fan";
    //ReefAngel.CustomLabels[5]="Steph ATO";
    //ReefAngel.CustomLabels[6]="Refugium";
    //ReefAngel.CustomLabels[7]="Nick  ATO";
    ReefAngel.Relay.DelayedOn( Port2,20 );
    ReefAngel.MHLights( Port3,11,00,21,00,0 );
    ReefAngel.StandardFan( Port5,776,781 );
    ReefAngel.Relay.Set( Port7, !ReefAngel.Relay.Status( Port3 ) );
    ReefAngel.SingleATO( true,Port6,10,0 );
    ReefAngel.SingleATO( false,Port8,10,0 );
    if (ReefAngel.Params.Temp[T2_PROBE]>800) ReefAngel.Relay.Off(Port4);
    if (ReefAngel.Params.Temp[T2_PROBE]<790) ReefAngel.Relay.On(Port4);
    if (hour()>=8 && hour()<20)
    ReefAngel.PWM.SetDaylight( ElseMode(70,30,true) ); // Else Mode at 70% +/- 30% on sync mode
else if (hour()>=20 && hour()<23)
    ReefAngel.PWM.SetDaylight( NutrientTransportMode(40,80,200,true) ); // Nutrient Transport 40%minspeed - 80%maxspeed - 200ms
    else if (hour()>=23 || hour()<8)
    ReefAngel.PWM.SetDaylight( ElseMode(45,15,true) ); // Else Mode at 45% +/- 15% on sync mode
if (hour()>=11 && hour()<22)
    ReefAngel.PWM.SetActinic( ElseMode(70,30,false) ); // Else Mode at 70% +/- 30% on anti-sync mode
else if (hour()>=22 || hour()<1)
    ReefAngel.PWM.SetActinic( NutrientTransportMode(40,80,200,false) ); // Nutrient Transport 40%minspeed - 80%maxspeed - 200ms
    else if (hour()>=1 && hour()<11)
    ReefAngel.PWM.SetActinic( ElseMode(45,15,false) ); // Else Mode at 45% +/- 15% on anti-sync mode
    ReefAngel.Portal( "imFortney" );
void DrawParamsa(int x, int y){
char buf[16];
  ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,x+40,y+10,"Steph:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, x+78, y+10,1);
ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+40,y+20,"Nick:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),APColor, x+78, y+20,1);
void DrawParams(int x, int y) {
  char buf[16];
  ReefAngel.LCD.DrawText(COLOR_INDIGO,DefaultBGColor,x+5,y,"Temp:");
  ReefAngel.LCD.DrawText(COLOR_INDIGO,DefaultBGColor,x+80, y, "PH:");
  // Temp and PH
  y+=10;
  y+=5;
void DrawStatus(int x, int y) {
  int t=x;
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,15,y,"High",Font8x16);
  ReefAngel.LCD.DrawLargeText(COLOR_ORANGERED,DefaultBGColor,85,y,"Low",Font8x16);
    ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_INDIGO);
  } else {
    ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_ORANGERED);
    ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_ORANGERED);
  } else {
    ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_INDIGO);
  static unsigned long LastChange=millis();        // Set the inital time that the last change occurred
  static int Delay = random( 500, 3000);           // Set the initial delay
  static int NewSpeed = MidPoint;                  // Set the initial speed
  static int AntiSpeed = MidPoint;                 // Set the initial anti sync speed
  if ((millis()-LastChange) > Delay)               // Check if the delay has elapsed
    Delay=random(500,5000);                        // If so, come up with a new delay
    int ChangeUp = random(Offset);                 // Amount to go up or down
    if (random(100)<50)                            // 50/50 chance of speed going up or going down
    LastChange=millis();                           // Reset the time of the last change
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
I know i missed something somewhere.
Thanks for the help guys
imfortney
Re: Dual Tank, single controller
Post by imfortney »
well i am running two fans on two temp probes and i am also running two separate single ATO. the only thing i am missing is two separate overheat functions.
ReefAngel.LCD.DrawText(COLOR_ORANGERED, COLOR_DEEPSKYBLUE,14,8, "Our Little Oceans");
DrawStatus (20,80);
DrawParams (5,40);
DrawParamsa (0,10);
    //ReefAngel.CustomLabels[3]="Nick  ATO";
    //ReefAngel.CustomLabels[7]="Nick  Fan";
    ReefAngel.SingleATO( false,Port4,10,0 );
    if (ReefAngel.Params.Temp[T2_PROBE]>776) ReefAngel.Relay.On(Port8);
    if (ReefAngel.Params.Temp[T2_PROBE]<781) ReefAngel.Relay.Off(Port8);
char buf[16];
  char buf[16];
  ReefAngel.LCD.DrawText(COLOR_INDIGO,DefaultBGColor,x+5,y,"Steph:");
  ReefAngel.LCD.DrawText(COLOR_INDIGO,DefaultBGColor,x+80, y, "Nick:");
  // Temp and PH
  y+=10;
  ConvertNumToString(buf, ReefAngel.Params.Temp[T2_PROBE], 10);
  ReefAngel.LCD.DrawLargeText(T2TempColor, DefaultBGColor, x+80, y, buf, Num8x16);
  y+=5;
  int t=x;
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,15,y,"Nick",Font8x16);
  ReefAngel.LCD.DrawLargeText(COLOR_ORANGERED,DefaultBGColor,85,y,"Steph",Font8x16);
  } else {
  } else {
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
if you are missing the overheat functions, you will want to look at the libraries and specifically reefangel/reefangel.cpp file to see how the overheat checks are performed. then you will want to replicate that for your second temp probe.
i cant give you any examples currently as im on my ipad but i should be able to later tonight if someone else hasnt chimed in.
Ok. I created the second overheat check function for you. It allows you to independently control what ports get shutoff when the second overheat check happens. So you can control both separately. The only downside is that the overheat clearing will have to be coded in differently because the function is a custom function. Anyways, here's the start of it:
place these lines above the setup and init functions (above the ///Place global variable code above here)
time_t Overheatmillis2;
byte OverheatShutoffPorts2;
then, inside the setup() function, you can initialize the shutoffports:
void setup() {
// ... other code
    // set this just like the ReefAngel.OverheatShutoffPorts is set
    OverheatShutoffPorts2 = 0;
Now copy and paste these functions somewhere in the INO file, probably towards the bottom. It's set to operate on the 2nd temp probe. This can be changed though. It's also set to use the same overheat temp as the regular overheat check function. if you need an additional overheat temperature, we can easily add that in for you too.
void OverheatCheck2()
	// if overheat probe exceeds the temp
       // use T1_PROBE, T2_PROBE or T3_PROBE
	if ( ReefAngel.Params.Temp[T2_PROBE] <= InternalMemory.OverheatTemp_read() )
		Overheatmillis2=millis();
	if (millis()-Overheatmillis2>3000) // Only flag overheat if we have overheat for 3 seconds
		LED.On();
		bitSet(ReefAngel.AlertFlags,OverheatFlag);
#ifdef ENABLE_EXCEED_FLAGS
		InternalMemory.write(Overheat_Exceed_Flag, 1);
#endif  // ENABLE_EXCEED_FLAGS
		// invert the ports that are activated
		ReefAngel.Relay.RelayMaskOff &= ~OverheatShutoffPorts2;
void OverheatClear2()
	LED.Off();
	bitClear(ReefAngel.AlertFlags,OverheatFlag);
	InternalMemory.write(Overheat_Exceed_Flag, 0);
	ReefAngel.Relay.RelayMaskOff |= OverheatShutoffPorts2;
	ReefAngel.Relay.Write();
the last thing you will need to do is inside the loop() function, you will need to call the overheatcheck function towards the bottom, above your portal line
void loop() {
// ...other code
    OverheatCheck2();
    // Portal()
    // ShowInterface()
Let me know if you have trouble placing this in your INO file and I can place it for you. I opted not for simplicity and to explain each code block a little bit.
Like I was saying earlier, you cannot easily clear the overheat check and restore the flagged off ports because you cannot call OverheatClear2(). You would have to either: a) add a menu item to call that function or b) setup a memory location that if it is set to 1, it calls the function and then resets itself back to 0 to clear the overheat.
i can help with the second option (b), later if that's what you want (which it probably will be). Otherwise, we will have to modify the libraries to make things work properly for you...it can be done but would mean you would have to re-add your changes every time you upgraded the libraries...so it's not really recommended. option B is probably your best choice.
I should be able to help with that tomorrow when I have some time to sit down and write it out.
imfortney
Post by imfortney »
Wow! Thank you very much! I will play with that tomorrow.
I have had to make some changes to my INO due to not following instructions causing my 2nd fan to rapidly toggle. I fixed it by copy and paste from another thread, I believe from Roberto. Now if only this stupid goni would open up I'd be really happy
