control two jabeo with different speeds
imfortney
Post by imfortney »
i am trying to use else mode that i stole from another user on here, cant remember who. The two pumps operate at the same speeds as each other or on anti sync just the opposite of each other. I want one tank to have stronger flow than the other as shown below but they wont go at different speeds.
#define NUMBERS_8x16
ReefAngel.LCD.DrawDate(6, 112);
ReefAngel.LCD.DrawText(COLOR_ORANGERED, COLOR_DEEPSKYBLUE,14,8, "Our Little Oceans");
DrawStatus (20,80);
DrawParams (5,40);
DrawParamsa (0,10);
    ReefAngel.FeedingModePorts = Port2Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port6Bit;
    ReefAngel.LightsOnPorts = Port3Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port7Bit;
    //ReefAngel.CustomLabels[0]="ReturnPump";
    //ReefAngel.CustomLabels[1]="Skimmer";
    //ReefAngel.CustomLabels[2]="Kessil";
    //ReefAngel.CustomLabels[3]="Nick  ATO";
    //ReefAngel.CustomLabels[4]="Steph Fan";
    //ReefAngel.CustomLabels[5]="Steph ATO";
    //ReefAngel.CustomLabels[6]="Refugium";
    //ReefAngel.CustomLabels[7]="Nick  Fan";
    ReefAngel.Relay.DelayedOn( Port2,20 );
    ReefAngel.MHLights( Port3,12,00,22,00,1 );
    ReefAngel.StandardFan( Port5,776,781 );
    ReefAngel.Relay.Set( Port7, !ReefAngel.Relay.Status( Port3 ) );
    ReefAngel.SingleATO( true,Port6,10,0 );
    ReefAngel.SingleATO( false,Port4,10,0 );
    if (ReefAngel.Params.Temp[T2_PROBE] >= 781) ReefAngel.Relay.On(Port8);  // If sensor 1 temperature >= HighTemp - turn on fan
	if (ReefAngel.Params.Temp[T2_PROBE] <= 776) ReefAngel.Relay.Off(Port8);  // If sensor 1 temperature <= LowTemp - turn off fan
    if (hour()>=12 && hour()<22)
    ReefAngel.PWM.SetDaylight( ElseMode(70,30,true) ); // Else Mode at 70% +/- 30% on sync mode
else if (hour()>=22 || hour()<2)
    ReefAngel.PWM.SetDaylight( NutrientTransportMode(40,80,200,true) ); // Nutrient Transport 40%minspeed - 80%maxspeed - 200ms
    else if (hour()>=2 && hour()<12)
    ReefAngel.PWM.SetDaylight( ElseMode(45,15,true) ); // Else Mode at 45% +/- 15% on sync mode
    ReefAngel.PWM.SetActinic( ElseMode(45,35,false) ); // Else Mode at 70% +/- 30% on anti-sync mode
    ReefAngel.PWM.SetActinic( NutrientTransportMode(25,65,200,false) ); // Nutrient Transport 40%minspeed - 80%maxspeed - 200ms
    ReefAngel.PWM.SetActinic( ElseMode(40,15,false) ); // Else Mode at 45% +/- 15% on anti-sync mode
    ReefAngel.Portal( "imFortney" );
void DrawParamsa(int x, int y){
char buf[16];
  ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,x+40,y+10,"Steph:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, x+78, y+10,1);
ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+40,y+20,"Nick:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),APColor, x+78, y+20,1);
void DrawParams(int x, int y) {
  char buf[16];
  ReefAngel.LCD.DrawText(COLOR_INDIGO,DefaultBGColor,x+5,y,"Steph:");
  ReefAngel.LCD.DrawText(COLOR_INDIGO,DefaultBGColor,x+80, y, "Nick:");
  // Temp and PH
  y+=10;
  ConvertNumToString(buf, ReefAngel.Params.Temp[T2_PROBE], 10);
  ReefAngel.LCD.DrawLargeText(T2TempColor, DefaultBGColor, x+80, y, buf, Num8x16);
  y+=5;
void DrawStatus(int x, int y) {
  int t=x;
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,15,y,"Nick",Font8x16);
  ReefAngel.LCD.DrawLargeText(COLOR_ORANGERED,DefaultBGColor,85,y,"Steph",Font8x16);
    ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_ORANGERED);
  } else {
    ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_INDIGO);
  if (ReefAngel.LowATO.IsActive()) {
    ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_ORANGERED);
  } else {
    ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_INDIGO);
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
anyone see anything wrong?
Nick
Re: control two jabeo with different speeds
That is the way it is.
You can't set different speeds for the pumps with the current 1.1.0 libraries.
The new developmental libraries 1.1.1 have and offset built into them.
The latest Dev branch can be located here. https://github.com/reefangel/Libraries/archive/dev.zip
Here is the thread.
http://forum.reefangel.com/viewtopic.php?f=9&t=3801
lnevo wrote:Ok, Steve, you ask and you shall receive.
You can activate the offset for the AntiSync channel by specifying the percent power of the other channel by using a statement like this:
    ReefAngel.DCPump.AntiSyncOffset=75;
This is a percent, so if you were at Constant 100, the Sync channel would be 100 and the AntiSync would be 75.
If you were at Constant 50, the Sync would be at 50 while the AntiSync would be at 37.5 (whatever that rounds to as a byte)
Download the branch from here
I basically cleaned up all of the case statements for each mode. It should make adding a new modes much easier. just set the Sync and AntiSync speeds accordingly and at the end of the case statement it will now call ReefAngel.SetDCPumpChannels(byte SyncSpeed,byte AntiSyncSpeed) which will apply the DCPump.Threshold and the AntiSyncOffset to the speeds and write to the proper channels. There is now also one function that writes the speed to the channel which will make it much easier to add future channels to the list. It should also make adding future channel modes easier, like back-wall or something :)
Let me know if you have any questions. This compiles for me and I have confidence that it should work.
Also with the dev code the code you have for "Else Mode" is not needed. It's been added into the new libraries along with Sine and Gyre.
I don't think that's his issue Steven.
He's not using DCPump, he's using the same ElseMode with two different speeds being called. I think it's because ElseMode tracks the speed setting for each iteration. If you keep changing it, it's going to affect both channels.
AlanM
Post by AlanM »
He could ElseMode to call it Else1 and duplicate it to Else2 and do different pumps totally independently with different variables if he wanted.
That was my thought, but I wasnt 100% sure the issue...but I think that would be the answer
