hedrickms code
hedrickms
hedrickms code
Post by hedrickms »
Ok I am finally giving this a try and posting for all to review/use as necessary. I want to thank everyone on this awesome forum for all the great threads and code samples etc... that hopefully will work (in my code) and that have helped me get this done. I have to admit I was a little scared about attempting this (not a serious coder ... just a fooled around for fun) but after doing some reading/research and studying what has been posted by some very talented folks everything worked out fine and I understand more about this controller. BTW... This is the best purchase I have ever made.
My code: It does all the basic controls...heating/cooling pumping, turn relays, and feeding modes. What is unique is how I am trying to utilize some of these items (nothing fancy). Heating and cooling is based on a seasonal temps (I created my own to try). I set it up so I can adjust every month. The other unique thing is my control of pumps and since my lighting is a reef breeder and not controllable I thought it would be fun to see if I can get a random pump mode (daily) and an occasional storm mode (we'll see if it works).
Please look over and provide any comments/feedback to fix or make better.
Enjoy:
#include <WiFiAlert.h>
//define ports
#define Skimmer 		1
#define ReturnPump		2
#define FugeLight		3
#define WCPump			4
#define Heater			5
#define Jebao_MP10		6
#define Cooling			7
#define ATOpump			8
    int avgph[10];
    unsigned long totalavgph=0;
    byte avgindex=0;
      byte x;
      byte y = 2;
      char text[7];
      // *********** CHANGE TEMP READOUT COLOR DEPENDENT ON FAN AND HEATER STATUS ***********
      int TempColor;        // Color for drawing temperature
      boolean FanOn = ReefAngel.Relay.Status(Cooling);    // Get the status of the fan relay
      boolean HeatOn = ReefAngel.Relay.Status(Heater);   // Get the status of the heater relay
      if (HeatOn)
        TempColor = COLOR_NAVY;    // Blue text, too cold, heater is on
      if (FanOn)
          TempColor = COLOR_RED;   // Red text, too warm, fan is on
      if (!HeatOn && !FanOn)
          TempColor = COLOR_GREEN;  // Green text, no fan or heater on
      ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 30, 2, "Hedrick's REEF");       // Put a banner at the top
      ReefAngel.LCD.DrawDate(6, 119);                                                      // Put the date and time at the bottom
      ReefAngel.LCD.Clear(COLOR_BLACK, 1, 11, 132, 11);                                    // Draw a black line under the banner
      x = 6;
      y += MENU_START_ROW*1.0;                                                               // MENU_START_ROW is 10, according to globals.h, so y=2+10+1=13
      ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+1, "Tank Temp   PH");
      x = 6;
      y = MENU_START_ROW*0.8;
      ConvertNumToString(text, ReefAngel.Params.PH, 100);                                  // Get pH reading and convert
      ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+73, y+12, text, Font8x16);    // Put pH on the screen
      ConvertNumToString(text, ReefAngel.Params.Temp[T1_PROBE], 10);                       // Get T1 temp and convert
      x = 6;
      y += MENU_START_ROW*1.3;
      ReefAngel.LCD.DrawHugeNumbers(COLOR_WHITE, TempColor, x, y, text);                   // Draw the temperature, white numbers on a colored background
      x += 6;
      y += MENU_START_ROW*1.2;
      ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x-6, y+5, "Stand Temp");
      ConvertNumToString(text, ReefAngel.Params.Temp[T2_PROBE], 10);                       // Get T2 temp and convert
      x = 6;
      x += 6;
      y += MENU_START_ROW*2.2;
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,25,y,"ATO",Font8x8);            // Draw the Float switch status
    ReefAngel.LCD.FillCircle(15,y+3,7,COLOR_RED);
  } else {
    ReefAngel.LCD.FillCircle(15,y+3,7,COLOR_GREEN);
  x += 6;
      y += MENU_START_ROW*1.6;
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,25,y,"Skimmate",Font8x8);
  if (!ReefAngel.LowATO.IsActive()) {
  } else {
      byte TempRelay = ReefAngel.Relay.RelayData;                                          // Code for drawing the relay box
      ReefAngel.LCD.DrawOutletBox(12, 100, TempRelay);
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port8Bit;
    ReefAngel.LightsOnPorts = Port3Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit;
    // Feeding and Water Change mode speed
    ReefAngel.DCPump.FeedingSpeed=25;
    // Ports that are always on/off
    ReefAngel.Relay.On( ReturnPump );
    ReefAngel.Relay.Off( WCPump );
    ReefAngel.Relay.On( Jebao_MP10 );
		randomSeed(now()%SECS_PER_DAY);
		//Custom Variable [0] =  Month/Season
		//Custom Variable [1] =  NTM Feeding mode time remaining
		//Custom Variable [2] =  Storm Mode (24/17)
		//Custom Variable [3] =  Pump Mode
}//End Setup
    ReefAngel.StandardLights( FugeLight,21,0,9,0 );
    // seasonal temperatures
    SeasonalTemps();
	// skimmer on with delay
	ReefAngel.DCPump.UseMemory = true; //use Portal Settings
	ReefAngel.DCPump.ActinicChannel=Sync; // portal settings
    ReefAngel.DCPump.DaylightChannel=AntiSync; //  portal setting
    //Set DCPump (Jebao_MP10)
    JebaoMode();
	// Monitor for float switch for sump level (too low) and turn off return
	CheckFloatSwitches();
	//check and set Jebao for Feeding mode and Turn Skimmer Off if ReturnPump off
	SkimmerOffMode(Skimmer);
    //ATO High Switch
    ReefAngel.SingleATOHigh(ATOpump);
    ReefAngel.Portal( "hedrickms", "xxxxxx" );
} //End Loop
void CheckFloatSwitches()
  static boolean atocheck = false;
  static boolean atoalertsent = false;
  static boolean switchalertsent = false;
  static boolean skimmeralertsent = false;
  static unsigned long atotimeout;
  static unsigned long timeout;
  static WiFiAlert atoAlert, switchAlert, skimmerAlert;
  if (ReefAngel.DisplayedMenu==FEEDING_MODE || ReefAngel.DisplayedMenu==WATERCHANGE_MODE)
   return;
  //if ato is on set flag and timer
	  if (ReefAngel.HighATO.IsActive() && ReefAngel.Relay.Status(ATOpump))
	    atocheck = true;
		atotimeout = now();
      if (bitRead(ReefAngel.AlertFlags,ATOTimeOutFlag))
		 if (!atoalertsent)
			atoAlert.Send("ATO+pump+disabled.");
		    atoalertsent = true;
		  ReefAngel.Relay.Override(ATOpump,0);
	   // Turn off return if sump level is low
		  if (ReefAngel.HighATO.IsActive() && now()-timeout>3600) //if the ato float is active for 1 hours turn off return skimmer and ato
		     if (!switchalertsent)
			  switchAlert.Send("Sump+level_low+alarm!+Return+pump+Skimmer+disabled.");
			  ReefAngel.Relay.Override(ReturnPump,0);
			  switchalertsent = true;
		   else switchalertsent = false; //reset switchalert flag so alert can be sent if needed
	     timeout = now();
	     atoalertsent = false; //reset atoalert flag so alert can be sent if needed
		 //run ato for additional 10secs after ato triggered to avoid float bouncing activation
		 if (atocheck && now()-atotimeout<10)
		   ReefAngel.Relay.On(ATOpump);
		  atocheck = false;
		  ReefAngel.Relay.Off(ATOpump);
	  // turn off skimmer if skimmate overflows
      if (!ReefAngel.LowATO.IsActive()) //active by default
	     if (!skimmeralertsent)
           skimmerAlert.Send("Skimmer+Overflow+alarm!+Skimmer+disabled.");
           skimmeralertsent = true;
	     ReefAngel.Relay.Override(Skimmer,0);
	   else skimmeralertsent = false; //reset skimmer flag so alert can be sent if needed
}// End CheckFloatSwitches
void SkimmerOffMode (byte relayport)
  // Turn off relay if Return pump has been shut off
  if (!ReefAngel.Relay.Status(ReturnPump) && ReefAngel.Relay.Status(relayport))
    ReefAngel.Relay.Override(relayport,0);
} //End SkimmerOffModes
void JebaoMode()
     static boolean feedingalert = false;
     static boolean pumpstormalert = false;
	 static unsigned long isfeeding;
	 static byte ranMode = random (30);
 	 static byte ranPumpMode = ranMode%9;
     static WiFiAlert pumpAlert;
    if (ReefAngel.DCPump.Mode == Custom)
			 isfeeding = now();
			 feedingalert = false; //reset feeding flag so alert can be sent if needed
		 if (now()-isfeeding<3600) // Continue for the 60 minutes
		   if (!feedingalert)
    	     pumpAlert.Send("Pump+Mode+NTM+Feeding!+Activated.");
		     feedingalert = true;
		     ReefAngel.PWM.SetDaylight( NutrientTransportMode(30,70,140,true));
		     ReefAngel.PWM.SetActinic( NutrientTransportMode(30,70,140,false));
			 ReefAngel.CustomVar[1]=((now()-isfeeding)/60);
			 if (ReefAngel.CustomVar[1]>0) ReefAngel.CustomVar[1]=0;//reset feed timer portal variable if was in feeding mode;
			 if ((now()%SECS_PER_DAY >= 75600) || (now()%SECS_PER_DAY < 28800)) // night mode 9pm -> 8am
			   if (now()%SECS_PER_DAY == 75600) pumpstormalert = false; //reset pump flag at 9pm so alert can be sent if needed
			   if (!pumpstormalert)
				 pumpAlert.Send("Pump+Mode+Sine+NightMode!+Activated.");
				 pumpstormalert = true;
			   ReefAngel.PWM.SetDaylight(SineMode(25,35,20, true));
			   ReefAngel.PWM.SetActinic(SineMode(25,35,20, false));
			   ReefAngel.CustomVar[3]=99;//night mode = 99
			 }// end night mode 8am
			 else   //  choose a random pump mode (ReefCrest, TidalSwell, ShortPulse, LongPulse, Else) between 0 and 8
			  if (now()%SECS_PER_DAY == 28800)//at 8am set pump mode and determine if storm
				pumpstormalert = false; //reset pump flag so alert can be sent if needed
				//set random pump mode at start of each day (midnight) and determine if storm will occur
				ranMode = random(30);
			  else if (ranMode==27 || ranMode==11)//storm mode only after 8am
					//enter storm mode for pumps (random)
					pumpAlert.Send("Pump+Mode+STORM!+Activated.");
					pumpstormalert = true; //reset pump flag so alert can be sent if needed
				 StormMode();
			     ReefAngel.CustomVar[2]=ranMode;
                 ReefAngel.CustomVar[3]=0;
				  switch (ranPumpMode)
					case 0:
				        pumpAlert.Send("Pump+Mode+ShortPule+case0!+Activated.");
				      ReefAngel.PWM.SetActinic( ShortPulseMode(10,70,600,true) );
					  ReefAngel.PWM.SetDaylight( ShortPulseMode(10,70,600,false) );
					  break;
					 case 1:
				        pumpAlert.Send("Pump+Mode+ReefCrest+case1!+Activated.");
					  ReefAngel.PWM.SetDaylight( ReefCrestMode(50,20,true) );
					  ReefAngel.PWM.SetActinic( ReefCrestMode(50,20,false) );
					  break;
					 case 2:
				        pumpAlert.Send("Pump+Mode+TideMode+case2!+Activated.");
					  ReefAngel.PWM.SetActinic( ShortPulseMode(0,75,800,true) );
					  ReefAngel.PWM.SetDaylight( ShortPulseMode(0,75,800,false) );
					  break;
					 case 3:
				        pumpAlert.Send("Pump+Mode+ElseMode+case3!+Activated.");
					  ReefAngel.PWM.SetDaylight( ElseMode(55,25,true) );
					  ReefAngel.PWM.SetActinic( ElseMode(55,25,false) );
					  break;
					 case 4:
				        pumpAlert.Send("Pump+Mode+TideMode+case4!+Activated.");
					  ReefAngel.PWM.SetDaylight( ReefCrestMode(55,25,true) );
					  ReefAngel.PWM.SetActinic( ReefCrestMode(55,25,false) );
					  break;
					 case 5:
				        pumpAlert.Send("Pump+Mode+LongPulse+case5!+Activated.");
					  ReefAngel.PWM.SetDaylight( LongPulseMode(20,70,10,true) );
					  ReefAngel.PWM.SetActinic( LongPulseMode(20,70,10,false) );
					  break;
					 case 6:
				        pumpAlert.Send("Pump+Mode+ElseMode+case6!+Activated.");
					  ReefAngel.PWM.SetDaylight( ElseMode(50,15,true) );
					  ReefAngel.PWM.SetActinic( ElseMode(50,15,false) );
					  break;
					 case 7:
				        pumpAlert.Send("Pump+Mode+SineWave+case7!+Activated.");
					  ReefAngel.PWM.SetDaylight(SineMode(25,50,20, true));
					  ReefAngel.PWM.SetActinic(SineMode(25,50,20, false));
					  break;
					 case 8:
				        pumpAlert.Send("Pump+Mode+ShortPule+case8!+Activated.");
					  ReefAngel.PWM.SetActinic( ShortPulseMode(20,65,300,true) );
					  ReefAngel.PWM.SetDaylight( ShortPulseMode(20,65,300,false) );
					  break;
				  }//end of random pump mode
				  ReefAngel.CustomVar[3]=ranPumpMode;
			 }//end else switch
			 }//end else pump mode
		 }//end else
	 } //end of DCPump custom
} // End Void JebaoRandomMode()
void StormMode ()
	 if ((now()%SECS_PER_DAY >= 28800) && (now()%SECS_PER_DAY < 43200))    //  8am - 12 pm
		 ReefAngel.PWM.SetDaylight( NutrientTransportMode(40,85,140,true));
		 ReefAngel.PWM.SetActinic( NutrientTransportMode(40,85,140,false));
	 else if ((now()%SECS_PER_DAY >= 43200) && (now()%SECS_PER_DAY < 64800))    //  12pm - 6pm
	  ReefAngel.PWM.SetDaylight( LongPulseMode(30,55,10,true) );
	  ReefAngel.PWM.SetActinic( LongPulseMode(30,55,10,false) );
	 else if ((now()%SECS_PER_DAY >= 64800) && (now()%SECS_PER_DAY < 72000))    //  6pm - 8pm
		 ReefAngel.PWM.SetDaylight( NutrientTransportMode(35,75,260,true));
		 ReefAngel.PWM.SetActinic( NutrientTransportMode(35,75,260,false));
	 else if ((now()%SECS_PER_DAY >= 72000) && (now()%SECS_PER_DAY < 75600))    //  8pm - 9pm
	  ReefAngel.PWM.SetDaylight( ElseMode(65,25,true) );
	  ReefAngel.PWM.SetActinic( ElseMode(65,25,false) );
}//end StormMode
 void SeasonalTemps ()
  ReefAngel.CustomVar[0]=month();
  static int heatArray[][2] = { {792,796},// default in case of error in month=0 (June)
                    {770,774},//January (winter)
                    {774,778},//February (winter)
                    {775,779},//March (early spring)
                    {779,783},//April (spring)
                    {785,789},//May (spring)
                    {792,796},//June (early summer)
                    {799,803},//July (summer)
                    {806,810},//August (summer)
                    {796,801},//September (early fall)
                    {787,791},//October (fall)
                    {780,784},//November (fall)
                    {775,779} };//December (early winter)
  static int coolArray[][2] = { {794,799},// default in case of error in month=0 (June)
                    {772,776},//January (winter)
                    {776,780},//February (winter)
                    {777,781},//March (early spring)
                    {781,785},//April (spring)
                    {787,791},//May (spring)
                    {794,798},//June (early summer)
                    {801,805},//July (summer)
                    {808,812},//August (summer)
                    {798,803},//September (early fall)
                    {789,793},//October (fall)
                    {782,786},//November (fall)
                    {777,781} };//December (early winter)
  ReefAngel.StandardHeater( Heater,heatArray[month()][0],heatArray[month()][1]);
  ReefAngel.StandardFan(Cooling,coolArray[month()][0],coolArray[month()][1]);
 }//end seasonalTemps
      static unsigned long LastChange=millis();        // Set the inital time that the last change occurred
      static int Delay = random( 500, 3000);           // Set the initial delay
      static int NewSpeed = MidPoint;                  // Set the initial speed
      static int AntiSpeed = MidPoint;                 // Set the initial anti sync speed
      if ((millis()-LastChange) > Delay)               // Check if the delay has elapsed
        Delay=random(500,5000);                        // If so, come up with a new delay
        int ChangeUp = random(Offset);                 // Amount to go up or down
        if (random(100)<50)                            // 50/50 chance of speed going up or going down
        LastChange=millis();                           // Reset the time of the last change
      if (WaveSync)
        return NewSpeed;
        return AntiSpeed;
    }//end Elsemode()
89delta
Re: hedrickms code
Post by 89delta »
Love the Seasonal Temps portion of your code...may steal it for mine and go off the temps from the GBR.
hedrickms
Re: hedrickms code
Post by hedrickms »
of course you can. I believe it is working although I have not had the code operational more than a week so I can not confirm that all the months are in fact working. I do not see any reason why they wouldnt
hedrickms
Re: hedrickms code
Post by hedrickms »
I thought about the GBR temps but thought some of temps got pretty cold and didnt want to risk trying it in my tank.
Re: hedrickms code
I love it. The only thing i would do differently is store the season temps in a multidimensional array. It would then be easier to see the temps in one place and make modifications. You also wouldn't need the case statement as you could just do something like this.
ReefAngel.StandardHeater(Heater,heat_temp[month()][0],heat_temp[month()][1]);
Re: hedrickms code
I have to check the actual syntax of that suggestion, but it would still be the same approach.
hedrickms
Re: hedrickms code
Post by hedrickms »
That is a really good suggestion. I will have to play with it to see if I can figure it out. Thanks for the input. If I get it working I will repost my code. Did you see any other potential issues? I plan on removing the notifications once I know it is properly working.
Thanks again.
89delta
Re: hedrickms code
Post by 89delta »
Yeah I saw what the temps were like....kind of worries me as well. But if its thriving there I dont see why it wouldn't work. Although i'm running my LEDs with GPS coordinates to give me my photoperiod duration so it might just work.
// http://www.divethereef.com/Guides/SeasonsF.asp
//Water Temps Based from Great Barrier Reef
//Jan Feb Mar Apr May Jun Jul Aug Sep Oct Nov Dec
//84 84 82 80 79 78 72 72 74 79 80 82
hedrickms
Re: hedrickms code
Post by hedrickms »
ok so I am having trouble trying to figure this multi-dim array out. Any idea where I can check/lookup the syntax etc..?
Thanks again.
hedrickms
Re: hedrickms code
Post by hedrickms »
Update: I am testing it now and it appears to be working so unless anyone can find any issues I think I can say success. :D (amazing I didnt think I could do it)
Ok I did some searching and maybe I'm heading in the right direction. Is this on the right path? Does it look correct?
I will try it out but would like to see if I am doing this properly.
  static int coolArray[][2] = { {794,797},// default in case of error in month=0 (June)
                    {772,775},//January (winter)
                    {776,779},//February (winter)
                    {777,780},//March (early spring)
                    {781,784},//April (spring)
                    {787,790},//May (spring)
                    {794,797},//June (early summer)
                    {801,804},//July (summer)
                    {808,811},//August (summer)
                    {798,802},//September (early fall)
                    {789,792},//October (fall)
                    {782,785},//November (fall)
                    {777,780} };//December (early winter)
Re: hedrickms code
Sweet! Very nice.
Re: hedrickms code
yeah, what lee said....looks good. nice work. :)
Smotz
Re: hedrickms code
Post by Smotz »
I like this! This should be a library, no ?
hedrickms
Re: hedrickms code
Post by hedrickms »
Does anyone know why the random(7) function would always select #5 when the controller reboots? I am not sure if it is always doing this yet (cause I rebooted everyday) but my pumps are not switching modes during the day.
Ideas?
code below:
void JebaoMode()
	 static int ranMode = random (9);
			 isfeeding = now();
		 if (now()-isfeeding<5400) // Continue for the 90 minutes
		   if (!feedingalert)
		 else if ((now()%SECS_PER_DAY >= 82800) || (now()%SECS_PER_DAY < 28800)) // night mode 11pm -> 8am
		   if (now()%SECS_PER_DAY == 82800) pumpstormalert = false; //reset pump flag so alert can be sent if needed
		   ReefAngel.PWM.SetDaylight(SineMode(30,50,20, true));
  		   ReefAngel.PWM.SetActinic(SineMode(30,50,20, false));
			if (ranMode!=29 || ranMode!=17) ranMode = random (9);//if not storm set normal random pump mode
		  if (ranMode==29 || ranMode==17)//storm mode
		     StormMode();
  		      switch (ranMode)
				case 0:
				  ReefAngel.PWM.SetActinic( ShortPulseMode(0,60,400,true) );
				  ReefAngel.PWM.SetDaylight( ShortPulseMode(0,60,400,false) );
				  break;
				 case 1:
				  break;
				 case 2:
				   pumpAlert.Send("Pump+Mode+TidalSwell+case2!+Activated.");
				  ReefAngel.PWM.SetDaylight( TidalSwellMode(70,true) );
				  ReefAngel.PWM.SetActinic( TidalSwellMode(70,false) );
				  break;
				 case 3:
				   pumpAlert.Send("Pump+Mode+TidalSwell+case3!+Activated.");
				  ReefAngel.PWM.SetDaylight( TidalSwellMode(50,true) );
				  ReefAngel.PWM.SetActinic( TidalSwellMode(50,false) );
				  break;
				 case 4:
				  ReefAngel.PWM.SetDaylight( TideMode(50,30,70) );
				  ReefAngel.PWM.SetActinic( TideMode(50,30,70) );
				  break;
				 case 5:
				  ReefAngel.PWM.SetDaylight( LongPulseMode(20,60,10,true) );
				  ReefAngel.PWM.SetActinic( LongPulseMode(20,60,10,false) );
				  break;
				 case 6:
				  ReefAngel.PWM.SetDaylight( ElseMode(50,30,true) );
				  ReefAngel.PWM.SetActinic( ElseMode(50,30,false) );
				  break;
				 case 7:
				  ReefAngel.PWM.SetDaylight(SineMode(40,70,20, true));
				  ReefAngel.PWM.SetActinic(SineMode(40,70,20, false));
				  break;
				 case 8:
				  ReefAngel.PWM.SetActinic( ShortPulseMode(10,50,600,true) );
				  ReefAngel.PWM.SetDaylight( ShortPulseMode(10,50,600,false) );
				  break;
		 }//end else switch
Re: hedrickms code
Because random() isn't seed'ed by default. So if you were troubleshooting something, you'd always have the same stream of random numbers. You will need to seed it with something that would also change, like the current time.
This is what I have:
randomSeed(now()/SECS_PER_DAY);
hedrickms
Re: hedrickms code
Post by hedrickms »
Ahh... got it. Thanks a bunch. Do you seed under Setup ()?
Re: hedrickms code
Yes. My INO is in my signature
hedrickms
Re: hedrickms code
Post by hedrickms »
Awesome... Thanks again!
I should have checked there first (my apologies). Sometimes I get a little trigger happy :lol:
hedrickms
Re: hedrickms code
Post by hedrickms »
ok code updated on first post to include fixes to random mode (thanks Lee!). Everything seems to be working.
Re: hedrickms code
Awesome! Now comes the incessant tweaking and feature adding. :)
hedrickms
Re: hedrickms code
Post by hedrickms »
Already planning the next mod :D
P.S. I already had to order a new cable :) -- all the constant updates ended up pulling/breaking the terminal ends on the cable.
Re: hedrickms code
You may want to consider ordering the bluetooth module :)
hedrickms
Re: hedrickms code
Post by hedrickms »
I'm seriously thinking about it. Is the bluetooth module easy to setup and use?
Does anyone know a good/cheap bluetooth adapter for a windows 8 (cheapo) laptop?
