Right which only sets the channel during your StandardLights time otherwise it uses the channels previous value.
The easiest thing to do if you want it to behave as expected is to set it to 0 before that line.
Ah. I see.
From a user's point of view, returning to the pre-override value makes more sense.
From a technical point of view letting the INO set the % makes more sense
Let me see what I can figure out..
What would happen though if you were to set an override during your light on time and then you clear it during lights off time. You'd end up being stuck at whatever % it was at before.
Thats why the current behavior is preferred. Your just missing a "default" % in your INO. Maybe we should have the wizard set the default to 0%
I've been thinking of a "Light" class that would have modes you could choose like DCPump. This way too we could set an overall intensity like the radion code has and set modes (Slope, Parabola, lightning
I get what you're saying.
Maybe we should have a default set, uh, by default?
For those of you Android users that also utilize the Portal for their notifications, I have created a Notification Manager app for Android that allows you to read/edit your notifications on the portal.
http://forum.reefangel.com/viewtopic.php?f=8&t=4891
If you have not checked it out, you may want to look at it. It does not replace any notifications in my Android Status app. This is simply an Android interface to the Portal notifications.
Not sure if this has been mentioned. I realized when/why I am receiving so many error 22: XML I/O messages on my android....
If my app is set to Away (update via my WAN IP) but I am connected to my network via wifi then I receive this error message every time my phone tries to update.
Besides changing between AWay/Home is there any fix for this?
well, i thought i figured out a solution but I apparently did not. i have an idea of what else to try but i have not had a chance to try it out.
Sent from my Moto X
Sent from my Moto X
It could be your router doesn't implement NAT loopback.
I found this while googling for your reference and to understand better what may be happening.
http://help.screenconnect.com/Cannot_ac ... s_from_LAN
I have this same problem because my router doesn't allow me to loopback
Interesting....
Good news, looking into this I realized my router supports DDNS which I have setup and is working...
Bad news, apparently using DDNS should avoid NAT Loopback issues however it has not fixed my issue.
i have ddns setup on my router and it works.ReEfnWrX wrote:Interesting....
i run ddwrt on my router. to get loopback support to work, I had to use a custom firewall command. it works just fine for me and I've been using it for years.
Sent from my Moto X
So it seems I can't download labels from the Portal now. I always get "Error 13: Unexpected code Response(protocol=http/1.1,code=401,message=Unauthorized,url=http://forum.reefangel.com/status/label ... =cosmith71)". Is this due to authentication?
Ooops, that was my transcription error of the message.
Colin'
Are you using the Andoid App?
If so, do you have the Device under settings set for Controller or Portal?
I've notices that I can't download the labels unless I switch it to Portal and then switch it back to Controller.
Yup, with authentication enabled I have to switch over to "Portal". With it disabled, I don't.
So you got your labels?
Maybe Binder can look into this.
hmmm...that's interesting. it could be that im using the authentication credentials when trying to download the labels. i will have to look at it more to see if i can find anything.
Yes, it is.cosmith71 wrote:So it seems I can't download labels from the Portal now. I always get "Error 13: Unexpected code Response(protocol=http/1.1,code=401,message=Unauthorized,url=http://forum.reefangel.com/status/label ... =cosmith71)". Is this due to authentication?
I have finally gotten back into updating the app and giving it a face lift. (yep, it's been a while) In the process, I looked into this problem and could repeat it on my end. The problem is related to having authentication enabled. If you disable authentication it will work just fine.
Here's what is happening...
When you click the download labels button, a request is generated to download the labels from the portal. As I get everything setup to query the portal, I am checking to see if device authentication is enabled. If it is enabled, I set the request to utilize it. I ONLY check if it is enabled. I do not check if we are only getting the labels from the portal.
So, to fix the issue, I simply had to add a check if device authentication is enabled AND if we are not getting the labels from the portal, then I enable authentication. BUT if we are getting the labels from the portal, I simply do not enable authentication and it proceeds.
It's fixed in my development, but not released yet. I still have to polish off the user interface and make sure that all features are working as expected before I can release a new version. I still have to create a better "first run" screen to configure the app.
I will have a test version for people to try out that will run alongside the existing app before I officially push out a test.
Awesome! I know you have a life outside of that app, but I sure do look forward to the updates.
Me also... Are you going to get dc modes implemented in this patch?
Ummm....I'm not sure. I have not looked into the dc modes much. I know I have an image of the dc mode section from the portal. So I honestly do not have a definite answer for you. I will look into it more and see what all is needed. I know this functionality has been desired for a while now and I'd like to make sure you guys get functionality that you want.pandimus wrote:Me also... Are you going to get dc modes implemented in this patch?
I looked at the dc modes just now and it is a little more complicated than simply adding another page. I'm currently not storing the dc pump values from the controller in the app. So I would have to add storage location for the dc pump values in addition to creating the page to display it. It's not hard to do this, it just needs to be done.
I will implement this once I get some of the other simple interface tweaks finished. So if it's not in the next release with the new interface, it will be coming right after that since it's an easy addition.
Thanks alot. I wish I could help you, but I don't know how to code...binder wrote:I looked at the dc modes just now and it is a little more complicated than simply adding another page. I'm currently not storing the dc pump values from the controller in the app. So I would have to add storage location for the dc pump values in addition to creating the page to display it. It's not hard to do this, it just needs to be done.
It's ok. My "code" is somewhat chaotic, especially during this overhaul.pandimus wrote:Thanks alot. I wish I could help you, but I don't know how to code...binder wrote:I looked at the dc modes just now and it is a little more complicated than simply adding another page. I'm currently not storing the dc pump values from the controller in the app. So I would have to add storage location for the dc pump values in addition to creating the page to display it. It's not hard to do this, it just needs to be done.
Turns out, I had already started working on the DC Pump page with the old/existing framework. I just have to migrate that over to the new framework. So it should be easier than I originally thought (even though it was going to be fairly easy). haha.
Another silly idea.. But is there any way to change up the icon.. I use it and the universal app, and I can't keep them in same folder or I get them mixed up
haha... yeah, I see your point. i dont use the labels on my homescreens and so i know what you mean. i can check into this some more and see if i can use a different logo or icon instead. one problem though is i am no good with graphics. so if it's not something I can scale or easily tweak, i cannot do it.pandimus wrote:Another silly idea.. But is there any way to change up the icon.. I use it and the universal app, and I can't keep them in same folder or I get them mixed up
Sent from my Nexus 7 using Tapatalk
Thanks.. Maybe I'll see if I can find some kind of icon program and work on something to help ease your burden
Thanks for the work Curt.
No go back to enjoying your life.
what about using the white reef angel logo?? the one when you view the app page in the play store. it's different and unique. thoughts?
Sent from my Moto X
Sent from my Moto X
