turning on feeding mode with code
Ask in here.
martinresi
Post by martinresi »
Hi,
When I'm away I want the feeding mode to kick on automatically because i have an autofeeder set up. I searched the forum for code and I think I got it...
// enter feeding mode at 11am & 5pm
if (hour()==11 && minute()==00 || hour()==17 && minute()==00)
ReefAngel.FeedingModeStart(); // turn on feeding mode
Does this look right? Thanks!
Re: turning on feeding mode with code
Almost. Use something like this:
 if ( (hour()==11 && minute()==0 && second()==0) || (hour()==17 && minute()==0 && second()==0))
martinresi
Awesome thanks Roberto!
Also, where does RA controller get the time from? Does it get it from the computer that uploads the code, then keep it going with its own internal clock?
martinresi
I also was wondering if there was any way to toggle back and forth between the code where feeding mode turns on at 11 and 5, and the code where it never turns on and I do it manually when at home? or will I need to upload separate code each time I want to switch between the 2?
Thanks for all your help!
Todd
The controller uses its own real time clock and keeps the time using a small battery inside of the controller.
You can change it using the smartphone app.
There are ways of coding what you want.
You can add a relay box expansion code, even though you don't have one, and use the relays as trigger.
Like this:
  if (ReefAngel.Relay.isMaskOn(Box1_Port1))
    // Do whatever you want when at home
Then, everytime you override Box1_Port1 to always on with the smartphone app, it will not trigger the feeding modes automatically.
Returning Box1_Port1 to auto will make the controller start feeding automatically again.
martinresi
Wow! this is wonderful, thanks again Roberto, I'll give this a try
martinresi
The auto feeding code works like a charm! Now I'm trying the toggle code with auto/manual feeding. Does adding box1_port1 require any initialization? note: I coded it backwards from yours in the sense that default is manual mode (do nothing), and override is the auto feeding (at 11am & 5pm).
Ports assignment:
Port1 - N/A
Port2 - Lights - "http://www.reefangel.com/Support.Relay-function-StandardLights.ashx"
Port3 - Skimmer Feed Pump
Port4 - Aux Powerhead
Port5 - Heater - "http://www.reefangel.com/Support.Relay-function-StandardHeater.ashx"
Port6 - Main Powerhead - "http://www.reefangel.com/Support.Activating-a-relay.ashx"
Port7 - Skimmer Air pump
Port8 - Canister Filter
  ReefAngel.Init();
  ReefAngel.FeedingModePorts = Port3Bit | Port4Bit | Port6Bit | Port8Bit; // Turn off Ports 3, 4, 6 and 8 when feeding mode is activated
  ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit; // Turn off Port5, Port6 and Port8 when water change mode is activated
  ReefAngel.Relay.On(Port2); // Turn on Port 2
  ReefAngel.Relay.On(Port3); // Turn on Port 3
  ReefAngel.Relay.On(Port4); // Turn on Port 4
  ReefAngel.Relay.On(Port6); // Turn on Port 6
  ReefAngel.Relay.On(Port7); // Turn on Port 7
  ReefAngel.Relay.On(Port8); // Turn on Port 8
  ReefAngel.StandardHeater(Port5,775,785); // Heater on at 77.5F and off at 78.5F
    if ((hour()==11 && minute()==0 && second()==0) || (hour()==17 && minute()==0 && second()==0))
  ReefAngel.Portal( "martinresi" );
Are you sure you uploaded this code?
Your portal still shows only one relay box.
martinresi
This was the only new line of code i added:
martinresi
Oh i get it, by putting it in the code it then shows up in the portal. Yes, I hadn't uploaded it yet. Ok now I did and I see it in the portal. Amazing! I'll test it but it looks like it's working correctly, thanks
