Can I have a port turn on & then back on & off again later?
PostPosted: Sat Oct 18, 2014 4:49 pm
I have mh as my main lights and want to have my supplemental T5's run before the MH for a while and then come back on again an hour after the mh turn off; how would I do that?
Would this code work? I simply listed Port2 twice, does that work?
    ReefAngel.StandardHeater( Port1,795,800 );  ////2 Heaters
    ReefAngel.StandardLights( Port2,14,0,17,0 ); ////T5 Lights 2pm to 5pm
    ReefAngel.StandardLights( Port2,23,0,24,0 ); ////T5 Lights 11pm to 12am
    ReefAngel.StandardLights( Port3,24,0,15,0 );   ////scrubber lights 12am-3pm  15hrs on 9off
    ReefAngel.StandardLights( Port5,17,0,23,0 ); ////Metal Halide 5pm to 11pm
    ReefAngel.DosingPumpRepeat( Port6,0,660,10 ); /////mag 720min = 11hrs  15ml day
    ReefAngel.DosingPumpRepeat( Port7,0,360,26 );  /////alk 360min = 6hrs  78ml day
    ReefAngel.DosingPumpRepeat( Port8,0,300,21 );  ////cal 300min = 5hrs   78.75ml day 3cups per gal
    ReefAngel.DCPump.SetMode( LongPulse,60,10 );
    if (hour()<8)
Full code if needed too:
    InternalMemory.OverheatTemp_write( 845 );
    if (hour()<8)
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetDaylight(0);
else if (hour()==8 && minute()<4)
ReefAngel.DCPump.SetMode( LongPulse,85,20);
else if (hour()>=8 && hour()<10)
ReefAngel.DCPump.SetMode( ShortPulse,75,40 );
else if (hour()>=10 && hour()<12)
ReefAngel.DCPump.SetMode( LongPulse,85,4 );
else if (hour()>=12 && hour()<14)
ReefAngel.DCPump.SetMode( ReefCrest,56,20 );
else if (hour()>=14 && hour()<16)
ReefAngel.DCPump.SetMode( LongPulse,80,5 );
else if (hour()>=16 && hour()<22)
ReefAngel.DCPump.SetMode( LongPulse,70,14 );
else if (hour()==23 && minute()<4)
ReefAngel.DCPump.SetMode( LongPulse,90,5);
   ReefAngel.AddWifi();
if (ReefAngel.Relay.Status(Port5))
  ReefAngel.StandardFan(Port4,813,820);
  ReefAngel.Relay.Off(Port4);
    ReefAngel.Portal( "davidinga" );
    int x,y;
    // Parameters
    // pH Expansion
    ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,66, "PHE:" );
    ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_MEDIUMSEAGREEN,39,66, 100 );
    // Main Relay Box
    // Date and Time
PostPosted: Sun Oct 19, 2014 7:03 am
I'm not sure if doing it twice will work or not. I don't think it will.
Something like this should. I'm just not sure about how midnight is handled. I think it just rolls over to 0.
    if ((hour()>=14 && hour()<17) || (hour()>=23)) ReefAngel.Relay.On(Port4);
PostPosted: Sun Oct 19, 2014 8:31 am
Yep that should do it.
Putting the command twice for the same port will just end up doing the one that is last.
PostPosted: Sun Oct 19, 2014 10:41 am
OK thanks.
PostPosted: Sun Oct 19, 2014 12:51 pm
Actually, lets change it to this just to be thorough:
    else ReefAngel.Relay.Off(Port4);
PostPosted: Sun Oct 19, 2014 1:08 pm
Actually you'd need that for sure. Good catch Colin!
PostPosted: Sun Oct 19, 2014 1:48 pm
Thanks! :geek:
PostPosted: Sun Oct 19, 2014 2:05 pm
It didn't work. It turned on at 2pm like it should but it was supposed to turn off at 5pm (run 2pm-5pm) but it stayed on...
***Edit...the "else" addition made it work.
Return to How do I code ...
