PaulTurner911 Code
PostPosted: Wed Jul 23, 2014 3:18 pm
Remove everything else from the list of options except else mode and then that will be the one that it chooses.
PostPosted: Wed Jul 23, 2014 3:41 pm
I'm not sure how to.
No way to call it from a memory location manually?
Ok, I think I understand.
PostPosted: Wed Jul 23, 2014 3:54 pm
Change this...
byte modes[] = { Lagoon, Else, ReefCrest, TidalSwell, ShortPulse, LongPulse, NutrientTransport };
To this...
byte modes[] = { Else };
PostPosted: Wed Jul 23, 2014 4:20 pm
+1
PostPosted: Tue Aug 05, 2014 1:43 pm
Could someone refresh my memory on how to have Relay 6 run constant, unless Im in feed mode?
I didnt realize it but when I added the skimmer it runs on the same schedule as my MH lamps. I would like it to be on all of the time unless its in feed mode.
Any help is greatly apprerciated.
Thank you
PostPosted: Tue Aug 05, 2014 2:00 pm
You need 2 things....
This in // Ports toggled in Feeding Mode
ReefAngel.FeedingModePorts = Port6Bit;
And then in // Ports that are always on
If you want to delay the start after feeding mode by 10 min so your main pump gets up to speed and your water leve gets back to normal you can add this in the loop section...
ReefAngel.Relay.DelayedOn( Port6,10 );
PostPosted: Tue Aug 12, 2014 3:28 pm
Great! Thank you
PostPosted: Tue Oct 28, 2014 12:14 pm
I HAVE PICKED UP A NEW TANK!!!
Im wondering if I should just run the wizard and start over, but cut and paste some "custom lines" ??? Please advise which would be easier.
Ditching a few things -
MH (port7&8)
FANS (port2)
ACTINIC (port3)
I have a few things that Id like to add-
3 Ecoray112DX whites/red (port7) Actinics (port8)
Chiller (port2) Should function similar to the fan settings? * NEEDS TO SHUT DOWN IN FEED/WATERCHANGE MODES
Skimmer (port3) ** Id like it off for 2 hours after feedmode activation
ANY AND ALL INPUT IS WELCOMED AND VERY APPRECIATED
PostPosted: Tue Oct 28, 2014 12:18 pm
I would keep what you have and go in and manually cut out what you don't want.
Then use the wizard to create the code you want to add and paste it in to your existing code.
PostPosted: Tue Oct 28, 2014 12:49 pm
Ill give it a try!! thanks
PreviousNext
Return to My PDE/INO file
