Hi..
I have my ATO setup with one float switch...
is there code I can use to delay the switching on of the ATO after using feed mode?
Single Auto Topup switch - delay
Re: Single Auto Topup switch - delay
Start looking at a couple threads:
http://forum.reefangel.com/viewtopic.ph ... mode+delay
Ridwaan
What I want must happen is that the ATO must have a delay of 3 minutes after feeding mode.
because I switch off my return pump during feeding mode. When return pump come back on and fills main display tank, the water level in the last chamber in my sump where the return pump is drops below float switch and then stabilizes within a minute and comes back to normal water level.
I found the following code, but only thing is I have a single float switch connect to low port. What can I modify in the code below
if (ReefAngel.DisplayedMenu==FEEDING_MODE) atoTimer=now();
if (now()-atoTimer < 300) {
ReefAngel.Relay.Off(Port6);
} else {
ReefAngel.StandardATO(Port6,180);
Ridwaan
ok, I thinki found how to code it correctly..
is this code correct for single ATO delay after feeding mode?
Also does the 300 in the code below mean 300 seconds?
static unsigned long atoTimer;
} else {
ReefAngel.SingleATO( true,Port6,60,0 );
}Code: Select all
if (now()-atoTimer < 300) - cosmith71
I think that will work. Alternately, you could use:
That's a single ATO, using the low switch, with the pump on port 6, with a 60 second timeout, and no limit on how often it actuates.
Yes, the 300 is in seconds. Change it to 60 if you want a minute instead.
Here's a good read on float switch operation:
http://forum.reefangel.com/viewtopic.php?f=7&t=240
HTH,
ReefAngel.SingleATOLow(Port6, 60, 0);Yes, the 300 is in seconds. Change it to 60 if you want a minute instead.
HTH,
Ridwaan
Thanks so much cosmith71..appreciate it
