if (hour()>22 && hour()<10) // between 10pm and 10am
ReefAngel.Relay.Off( tunze1 );
ReefAngel.Relay.Off( tunze2 );
} else {
ReefAngel.Relay.On( tunze1 );
ReefAngel.Relay.On( tunze2 );
// ports by name
#define halide 1
#define actinics 2
#define uvlight 3
#define unused 4
#define jebao1 5
#define tunze1 6
#define doser1 7
#define doser2 8
#define ato Box1_Port1
#define heater1 Box1_Port2
#define skimmer Box1_Port3
#define heater2 Box1_Port4
#define jebao2 Box1_Port5
#define tunze2 Box1_Port6
#define gfo Box1_Port7
#define mainPump Box1_Port8
// InternalMemory.LCDID_write(0);
// mainPump, skimmer, tunzes, ato, gfo
// ReefAngel.FeedingModePorts = Port5Bit | Port6Bit;
ReefAngel.FeedingModePortsE[0] = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
// mainPump, Skimmer, all 4 pumps, all 2 dosers, ato, gfo
ReefAngel.WaterChangePorts =  Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
// metal halide, uv, tunze pumps,
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port2Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.On( mainPump );
ReefAngel.Relay.On( skimmer );
// ReefAngel.Relay.On( tunze1 );
// ReefAngel.Relay.On( tunze2 );
ReefAngel.Relay.On( jebao1 );
ReefAngel.Relay.On( jebao2 );
ReefAngel.Relay.On( gfo );
ReefAngel.Relay.On( uvlight );
ReefAngel.DayLights( halide );
ReefAngel.ActinicLights( actinics );
ReefAngel.DosingPumpRepeat1( doser1 );
ReefAngel.DosingPumpRepeat2( doser2 );
// ReefAngel.StandardATO( ato );
ReefAngel.StandardHeater( heater1 );
ReefAngel.StandardHeater( heater2 );
// set single ato
ReefAngel.SingleATO(true,ato,60,0);
if (ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(ato);
ReefAngel.Relay.DelayedOn( skimmer );
ReefAngel.Relay.DelayedOn( gfo );
// turn off tunze when the lights go out
} else {
ReefAngel.Portal( "neuro" );
int x,y;
// Parameters
// Main Relay Box
// Relay Expansion
// Date and Time
