need someone to write a code
briank6050
cant for the life of me figure out how to write a code. can someone help me please??!! Thanks
briank6050
Re: need someone to write a code
this is the current code im running. i would like to add a night mode to the vortech pump to ramp down to 35% constant from 9pm to 7am. also would like some sort of a storm mode if possible
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port1,760,775 );
ReefAngel.StandardLights( Port2,20,0,4,0 );
ReefAngel.StandardLights( Port3,10,0,19,0 );
ReefAngel.StandardLights( Port4,9,0,20,0 );
ReefAngel.StandardLights( Port5,10,0,19,0 );
ReefAngel.StandardLights( Port6,9,0,20,0 );
ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,20,0,0,100,0) );
ReefAngel.PWM.SetChannel( 1, PWMParabola(10,0,19,0,0,100,0) );
ReefAngel.PWM.SetChannel( 2, PWMParabola(10,0,19,0,0,100,0) );
ReefAngel.RF.SetMode( NutrientTransport,85,10 );
Lee just gave you this code.
http://forum.reefangel.com/viewtopic.ph ... ead#unread
briank6050
do i just copy and paste it between the custom code lines?
briank6050
and where do i put the times i want?
Correct. Just place it in the custom code inside loop().
The times can be set in the code he gave you.
briank6050
well it went into night mode but now it dont come out of it. the rf changes color but the pump remains in night mode
If you look at the code he gave you:
When it is > 20 hours, the pump will enter night mode
And it will stop night mode when time is > 8 hours.
So, it will only come out of night mode tomorrow morning at 8am.
// Turn off Night Mode
if (hour()>8 && ReefAngel.RF.Mode==Night) ReefAngel.RF.SetMode(Night_Stop,0,0);
// Turn on Night Mode
if (hour()>20 && ReefAngel.RF.Mode!=Night) ReefAngel.RF.SetMode(Night,20,0);
I personally don't like the night mode of the vortech pump drivers.
So, I never use it myself.
I prefer using reefcrest at very slow speed instead.
briank6050
That sounds like a good idea! How would i program that instead?
Use something like this:
if (hour()<8 || hour()>20) ReefAngel.RF.SetMode( ReefCrest,20,10 );
briank6050
Well my vortech pump never went out of night mode this morn. The rf did change color but the pump remains at constant low speed. Sound like a communication prob between rf and ecotech driver?
Was it still blinking white?
How long is the night mode setup on your vortech driver?
Check their manual:
http://ecotechmarine.com/wp-content/upl ... on1.33.pdf
Check their manual:
briank6050
New code is so far so good. I dont suppose you have any ideas for a storm and clouds mode? My blue leds are on one driver and 2 50w white leds on another 2 drivers on my dimming expansion port.
briank6050
They are JR Tronic brand. Model uv3617-50-pwm
Never heard of that one.
Let us know how it responds. Many LED drivers are not fast enough to create a nice effect.
Try this one:
Try this one:
//Start of PWM Expansion Code Header
// This is just how we are going to reference the PWM expansion ports within the code.
// You can change the labels if you would like, just as long as they are changed all throughout the code too.
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
// Initial values to all 6 channels at startup. They will always be 0.
byte PWMChannel[]={
0,0,0,0,0,0};
//End of PWM Expansion Code Header
// ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,20,0,0,100,0) );
// ReefAngel.PWM.SetChannel( 1, PWMParabola(10,0,19,0,0,100,0) );
// ReefAngel.PWM.SetChannel( 2, PWMParabola(10,0,19,0,0,100,0) );
PWMChannel[LEDPWM0]=PWMParabola(9,0,20,0,0,100,PWMChannel[LEDPWM0]);
PWMChannel[LEDPWM1]=PWMParabola(10,0,19,0,0,100,PWMChannel[LEDPWM1]);
PWMChannel[LEDPWM2]=PWMParabola(10,0,19,0,0,100,PWMChannel[LEDPWM2]);
CheckCloud();
ReefAngel.PWM.SetChannel( LEDPWM0, int(2.55*PWMChannel[LEDPWM0]));
ReefAngel.PWM.SetChannel( LEDPWM1, int(2.55*PWMChannel[LEDPWM1]));
ReefAngel.PWM.SetChannel( LEDPWM2, int(2.55*PWMChannel[LEDPWM2]));
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
// Channels used by the actinic LEDs on the PWM Expansion module
// These channels will not be dimmed when the cloud effect is triggered
// Number is a binary form. B001100 means channel 2 and 3 are used for actinics
#define Actinic_Channels B000001
// Channels used by the daylight LEDs on the PWM Expansion module
// These channels will be used for the spike when lightning effect is triggered
// Number is a binary form. B000011 means channel 0 and 1 are used for daylights
#define Daylight_Channels B000110
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
// let's go through all channels to pick which ones will be dimmed
for (int a=0;a<6;a++)
if (bitRead(Actinic_Channels,a)==0)
// this will slope down the channel from the current PWM to 0 within 3minutes.
// then it will stay at 0 for the duration of the cycle
// and finally slope up from 0 to PWM value within 3 minutes
// it is basically an inversed slope
PWMChannel[a]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[a],0,180);
for (int b=0;b<6;b++)
if (bitRead(Daylight_Channels,b)==1)
else lightningstatus=0;
if (lightningstatus) PWMChannel[b]=100;
else PWMChannel[b]=0;
//delay(10);
PWMChannel[b]=20;
cloudindex++;
if (cloudindex < numclouds)
int x=0;
if (lightningchance)
int x=0;
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
briank6050
I will let you know how that code works when my other two drivers get here! One last question then ill quit buggin you for a while, how can iget my vortech pump into feeding mode when i toggle to feeding mode on the ra controller?
