PaulTurner911 Code
PostPosted: Tue Nov 04, 2014 4:53 pm
I decided to keep my code and change a few relays and make it work for the most part. I have the following questions:
Chiller will now be on port 2. It has a 2 deg variance, if I want the tank at 78 i would set this to 80?
ReefAngel.LCD.DrawOutletBox( 12, 80, TempRelay );
Wouldnt it then turn the chiller off when it goes to 79?
Skimmer is on port 6- Does shut off in feedmode , but I would like this to have a 2 hour delay after feed mode. How would i code this?
Thanks guys!
PostPosted: Wed Nov 05, 2014 5:36 am
No that code is for screen drawing. Post your code and I'll be able to help
PostPosted: Wed Nov 05, 2014 6:56 pm
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit ;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit ;
ReefAngel.LightsOnPorts =  Port3Bit | Port7Bit ;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port6Bit | Port7Bit ;
ReefAngel.DayLights( Port1 ); // Return Pump
//Port 2 Chiller
ReefAngel.ActinicLights( Port3 ); // Actinic LEDS
//Port4 Kalk/ATO
//Port5 Kalk Stir
ReefAngel.DayLights( Port6 );// Skimmer
ReefAngel.DayLights( Port7 ); // White LEDS
//Port8 Empty
//Moonlight Phase 9pm-10am (CH4-CH5)
if ( (hour() >=10) && (hour() <21) )
ReefAngel.PWM.SetChannel( 4,(0) );
ReefAngel.PWM.SetChannel( 5,(0) );
//Over Flow Protection
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.Off(Port1);
//ATO Protection
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.Off(Port4);
//Kalk Dose 60sec @ 11pm-12pm (every 15min)
if (hour() >=23 || hour() < 12)
ReefAngel.Relay.Set(Port4, now()%900<65);
//Kalk Stir 12pm-1pm
if (hour() >=12 & hour() < 13)
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.Off(Port5);
///// Place your custom code below here
static int rmode;
// Add Else Mode definition..
const int Else=16;
byte modes[] = { Else, Lagoon, Else, ReefCrest, ShortPulse, LongPulse, NutrientTransport };
changeMode=false;
static unsigned long feeding;
if (now()-feeding<900) {
  // First 15 minutes after feeding mode stops. Return Pump is off
  // First 15 minutes after feeding mode stops. Smart_NTM
} else if (now()-feeding<4500) { // 15 minutes plus 1 hour
  // Continue NTM for the next 60 minutes (75 minutes total)
} else if (now()%SECS_PER_DAY<30600 || now()%SECS_PER_DAY>=81000) { // 8:30am / 10:30pm
  // Night mode (go to 30%)
  ReefAngel.DCPump.Speed=30;
  if (modes[rmode]==Else) {
    ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),25,true );    // ElseMode on sync mode, Portal Speed Setting +/- 25%
  } else {
    ReefAngel.DCPump.Mode=modes[rmode];  // Put the mode to the random mode :)
} else {
ReefAngel.Portal( "paulturner911" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
  static unsigned long LastChange=millis();        // Set the inital time that the last change occurred
  static int Delay = random( 500, 3000);           // Set the initial delay
  static int NewSpeed = MidPoint;                  // Set the initial speed
  static int AntiSpeed = MidPoint;                 // Set the initial anti sync speed
  if ((millis()-LastChange) > Delay)               // Check if the delay has elapsed
    Delay=random(500,5000);                        // If so, come up with a new delay
    int ChangeUp = random(Offset);                 // Amount to go up or down
    if (random(100)<50)                            // 50/50 chance of speed going up or going down
    LastChange=millis();                           // Reset the time of the last change
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
PostPosted: Thu Nov 06, 2014 8:33 am
I've noticed that the skimmer (port6) is functioning like the old mh ports 7/8 as far as off and on schedule.
Is like this to run 24/7 unless water change or feed mode has been activated.
PostPosted: Thu Nov 06, 2014 8:52 am
Port 6 is included in Feeding, Water Change and Overheating off.
You also have it as Always on.
The one line of code that refers to Port 6 that I see has no time associated to it.
it just this...
PostPosted: Thu Nov 06, 2014 10:16 am
Port 6 definatly does not run 24/7
It does shut off for WC and feed mode correct.
I would like it to stay off for 2 hours after either.
What should it read? It's currently shitting down with the "daylight" LEDs.
Thank you
PostPosted: Thu Nov 06, 2014 12:47 pm
I think it has to do with this ReefAngel.DayLights( Port6 );// Skimmer
Just remove this line ReefAngel.DayLights( Port6 );// Skimmer and it should stay on all the time except Feeding, Water Change and Overheat because of this...
You can probably remove i the Port6Bit from the Overheat as well, you don't need to turn off the skimmer during an overheat situation.
PostPosted: Thu Nov 06, 2014 4:19 pm
He wanted a delay so use DelayedOn instead of On and put 120 as the second argument for 2 hours.
PostPosted: Thu Nov 06, 2014 5:55 pm
ReefAngel.Relay.DelayedOn( Port6 );120;
will this work?
PostPosted: Thu Nov 06, 2014 8:36 pm
ReefAngel.Relay.DelayedOn(Port6, 120);
PreviousNext
Return to My PDE/INO file
