Change Length of time when Feedmode
Ask in here.
g6gang
Post by g6gang »
1) Change you change the behavior to something else besides 15 minutes?
2) How to detect if when in and out of feed mode in
// How to detect when enter feed mode
// How to detect when exit feed mode
Re: Change Length of time when Feedmode
Do you have the Android app?
You can change the length of the feed mode by going into the Memory Pages and in the drop down box find "Feeding Mode Time" and then enter in the value in seconds and write the value.
You can do it through a web browser too, but I forgot the command.
g6gang
Post by g6gang »
Thanks - I was looking for a way to do it with code. But will try this. Will this new timer be used even after a power loss?
Yes.
I don't think it can be done with code since it's an internal memory setting.
I may be wrong about that though.
Put this in setup():
  ReefAngel.Timer[FEEDING_TIMER].SetInterval(600);      // Set feeding mode to 10 minutes
The number is in seconds.
There is a way to tell if you're in feeding mode, but I can't remember it. I'll see if I can dig it up.
OK, found it.
  // do some stuff
